What do you set yours at?
Discussion in 'Gen 3 Prius Main Forum' started by markabele, Jun 7, 2012.
  1. markabele
    5,084
    1,782
    Nebraska
    What do you set your thermostat at? (both car and home)
    Prius: Summer 74/Winter ?
    Home: Summer 76/Winter 68
  2. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Prius: Depends on season, humidity, amount of sunshine (or not) that's getting into car and passenger preference.
    Home: Fall, Winter, Spring thermostats set at 68F day and 60-65F night. Daytime during these cooler seasons, amount of sunshine can increase house interior temperature significantly. Summer? Sometimes 78-79F, sometimes 76. Depends a lot on activity and occupant preference at the time. Ceiling fans allow comfort at higher Summer (78-79F) settings.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I usually have my home set to around 74-76 depending on the day. In my car it depends much more greatly on the conditions. I usually don't set my A/C below 74, but if I have a lot of passengers I will to make sure they're comfortable.
  4. d in tx
    d in tx Junior Member
    North Texas
    In the Prius - if it is over 90 outside (which it has been for several months), then Auto at 80. Once it gets to 100 or over, I'll probably up it to 85 or so.. haven't been through a winter with it yet!
    At home - in the summer, usually at 80 (with ceiling fans going!), in the winter, 65 (with the fireplace insert going!)
  5. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Summer: Prius - 77-81 Home - 77 day - 73 night
    Winter: Prius - 68-71 (depending how thick my coat is) Home - 71 day - 65 night
  6. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Prius set at 75.
    Home, don't have AC, just ceiling fans in every room.
  7. fuzzy1
    10,687
    Home: 66-68 in winter (little or no night setback since installing mini-split heat pump), Off in summer.
    Car: 65 when heat is needed, 76-78 when cooling is needed, LO the rest of the time.
  8. plam0ne
    plam0ne Ninja
    70
    florida
    summer - 76-78
  9. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    prius summer 72 winter 75
    home a/c 72 when home / 78 night or daytime when not home
    home heat when home 72-73 when not home or at night 63
  10. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Summer -- Prius: 75 (higher if it's hotter) / home: off
    Winter -- Prius: 69 - 71 (depending on my coat) / home: 69-ish.
  11. markabele
    5,084
    1,782
    Nebraska
    Love seeing these numbers and how it relates to where you live!
  12. NiHaoMike
    NiHaoMike Member
    98
    16
    In the car: 78F or so (adjusted a lot) if A/C in use, LO most of the time, heat at minimum needed
    At home: 82F or so with fans on if A/C in use, windows open when possible, heat at about 60F or so (gives a nice boost in electronics performance).
    At work: Set to 73F (as measured at temperature probe points) year round by lab manager. Actual temperature at desk closer to 78F due to heat from equipment.
  13. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Keep in mind, I live in the Arizona Desert. A/C is a huge part of my energy costs.
    Both my car and my home during the day are generally 78˚F Summer, 68˚F in the Winter. My home at night is 65˚F for heat.
    My car will sometimes be bumped to 71˚F heat, 76˚F A/C during earlier spring or if humidity is higher.
    I've looked at the scan gauge fuel flow on my car with the cruise control set to highway speeds, and the difference between A/C on and off is about 0.2gph (fuel flow is usually 1 GPH or less at a reasonable speed (1gph at 50mph is 50mpg)). Keeping higher temperatures (which are still far lower than 100˚F+ heat) helps A/C load to drop more quickly, which has a direct impact on fuel consumption.
    Same goes for heat. Lower heat settings require the engine to run less to keep coolant at a usable temperature. Fuel consumption improves, especially in city driving, with lower heat demand.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I generally do not use the A/C unless it is over 100F. I do not use the heater unless the windows are fogging up.
    When I HAVE to use the A/C because my girlfriend is in the car I set it to 75/78F depending on what she finds comfortable. I pretty much give up on fuel efficiency when she is riding in the car and just try to keep her happy. :) My mpg average usually drops by 5mpg or more due to speed and A/C use. lol
    sdtundra likes this.
  15. markabele
    5,084
    1,782
    Nebraska
    In theory, if you are driving a long distance on the interstate at 60+ mph then it probably doesn't matter how much you use the heater since it is just pulling excess heat off the ICE, right?
  16. WE0H
    WE0H Senior Member
    3,247
    528
    Home: Summer 72F -- Winter 74F
    Prius: Summer Cold -- Winter she is stored at 40F in our garage until spring :)
    Mike [​IMG]
  17. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I live in the valley of the sun (phoenix metro).
    Summers are brutal.
    Prius: My AC I just use the up and down button leaving it on 75. I don't think I have it on auto though.
    Winters are mild here. I just use it early in the morning mostly. I just turn it up to high and put the up and down vent button on the lowest setting after it warms up.
    Home: Try to keep at as high as possible and try to be comfortable with 80, when i go to bed i need to drop it to 77-78. Winter it gets very cold in my unit so around 72-73 is comfortable. Leaving it in the 60s is just too cold for me but at night aside from a few cold weeks in Dec and possibly January, I turn my heat off.
  18. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Prius is set at 72
    My home is not airconditioned, but the heat is set at 70 daytime and is off at night.
    I live in Southern California near the beach.:)
  19. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    A/C on, closed system, 70 degrees, never touch it.
  20. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    House: 76 A/C (this year, I'm at 75 because I'm starting home brewing) and 68 Winter
    Car: A/C fluctuates between 74-80 depending upon situation. Heat? What's that? Usually 68, but only if others are in the car or it's a long trip or conditions make it necessary. Otherwise, it's off.
