What do you set yours at?
Discussion in 'Gen 3 Prius Main Forum' started by markabele, Jun 7, 2012.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The Apt does not have a thermostat.
    Prius is 74 in the winter and 72 in the spring/fall/summer.
    In comparison to what is being posted, I probably waste a ton of fuel. :D
    iPhone ?
  2. WE0H
    WE0H Senior Member
    3,247
    528
    What YA homebrewing? Moonshine for the Prius to run on? :)
    Mike [​IMG]
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Prius usually 75 degrees if it is sunny I might go down to 73 degrees, in ECO mode.
    My home is not air conditioned, the thermostat is windows open or windows closed.
    Posted from my iPhone via the Tapatalk app.
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Beer. I got the Mr Beer kit (it looks good for beginners). Moonshine is WAY too valuable to burn in the Prius.
    If the beer thing works out, I plan to upgrade to a larger kit and maybe at some point make my own recipes.
    I just turned my A/C on at home last night, other than a few days in March/April/May where we got 80s+ temps.
  5. wick1ert
    1,311
    183
    Delawhere
    That was the a/c in my Geo Metro when I first got it when I was 17. I upgraded the A/C to include a sun roof a year later.
    I might make another trip down the islands next year, btw. Probably to the Big Island, though.
  6. Much More Better
    Much More Better Active Member
    655
    163
    I don't use any A/C or fan. Crack the windows down couple inches is good enough. It's not hot enough here yet.
  7. fuzzy1
    10,630
    Even hypermilers in non-hybrids have found improved performance in cold weather by blocking the grill, reducing engine compartment heat loss. It seems that in some of those conditions, heat loss from the engine block can provide more than enough cooling, so some extra fuel must be burned to keep up the temperature.
    Because hybrids throw away even less heat than nonhybrids, they will more frequently need to burn extra fuel to keep up the temperature. In these cases, there really is no excess heat, so using the cabin heater will increase fuel consumption.
    At other times, there is more than enough excess heat, so cabin heat really is free. Unfortunately, these times are biased towards the times you don't need cabin heat.
    HTMLSpinnr likes this.
  8. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Rarely use A/C in the Prius unless i'm on the freeway for long periods of time and its warm out or the gf is in the car. Then it's usually set between 70-75 depending on the outside temps. Only use A/C in the house if its above 100 and even then its rare unless its crazy humid but usually opening windows front and rear and having a north facing house on a hill thats 400 ft above the valley below helps with the heat...those in the valley at 100+ with no a/c in older houses...good luck.
  9. vday
    vday Member
    312
    Israel
    Usually 20-22 C 68-72 F- lower when the hot sun is beating down higher in the eve.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Yes, that's the theory, unless it's extremely cold outside - at which point you should probably consider grille blocking anyway.
  11. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Prius: 68 or 69 year round.
    House winter: 68 day, 66 night
    House summer: 74 day, 73 night
    Currently have people in the house all day.
  12. lovemypriustoo
    lovemypriustoo Junior Member
    36
    Lake County, Illinois
    Prius: Summer 67 / Winter 68
    Home: Summer 73 / Winter 70
  13. mjones12
    mjones12 Member
    115
    26
    North Carolina
    In my 07 Camry Hybrid, I could never get warm in the winter time, even here in temperate North Carolina. For my 49-mile trip, I would set the heat as high as it would go, and the car would never get better than lukewarm. Service guys said nothing wrong with the heater. I'm just hoping the new Prius will keep me warmer in the winter. At least it has heated seats.
  14. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    House: 76 Summer, 68 Winter
    Prius: Auto Mode and temp typically set at 72
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Prius 70 summer/ 70 winter
    Home 75-80 summer/ 60-65 winter
    Bedroom 63-67 summer/60-65 winter
  16. yeldogt
    yeldogt Active Member
    810
    313
    NE
    On my other cars w ACC I normally keep them at 70-72 and rarely touch them -- I notice with the Prius that you have to often drop the control to get the AC to kick on and the reverse to bring the heat up ... I asked the dealer and he said that the Toyota single systems are like that ... VS the duel systems in the Lexus vehicles. I very rarely drive with the windows open ... wish the Prius system was a bit more automatic!
    I have one employee that gets 58 and now 60mpg on his long trips -- so the AC is not a problem getting great MPG.
