What does code PO3018 mean-Block ?
Discussion in 'Gen 2 Prius Technical Discussion' started by PriusVirgin, Aug 26, 2018.
  1. PriusVirgin
    PriusVirgin Junior Member
    Mission Viejo, CA
    Pulled code po3018-block 8 mean? Battery issue in a certain section of the HV battery. Also many of my individual battery cells at testing at 8.22V which seem on the high side to me? Thanks
    52,858
    you will probably do well to read through some battery rebuilding threads. are you using tech stream?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    If you are getting the block 8 becomes weak code, that means the two modules in block 8 need to be investigated ;).
    8.22 volts is not that high and within what I’ve seen:).
    Good luck and keep us posted (y).
  4. JC91006
    16,936
    8,647
    It means your HV battery has failed and the computer has picked up block number 8 as the failure.
    Each block contains 1 pair of modules. Block 1 is counted from the opposite end of all the battery electronics and ECU. So just count the pairs, it's the 8th pair that has a problem
    Raytheeagle likes this.
