What does that code means
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fssalfi, Oct 5, 2019.
  1. fssalfi
    fssalfi Junior Member
    24
    karachi
    It's comes 3rd time after computer clear reset in a week 20190928_132241.jpeg 20191005_122802.jpeg 20190913_134405.jpeg
  2. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  3. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    P0A80 - replace HV battery
    P0A7F- battery deterioration
    My guess time for a new hybrid battery pack
    Or a trustworthy expert to build and repair unless you want to learn to do it yourself but to be properly diagnosed it really needs to have techstream ran on it and get a good look at the health check freeze frame data off the HV battery to see everything more clearly...cell voltage, live battery condition...etc
    More than likely you have some cell or possibly cells needing replacement and a good grid charge ran after replacing cells and cleaning your bus bars, fan, etc
    Good luck and theres alot of us here to help you
    #3 Sharnold, Oct 5, 2019
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Most likely, it means what it says, time for a new hybrid battery. But it's also possible that there are bad connections in the sensing wires or corrosion in the buss bars causing the computer to misread the battery conditions.
    Sharnold likes this.
  5. bisco
    52,886
  6. fssalfi
    24
    karachi
  7. bisco
    52,886
    sorry to hear it. is it hot in karachi?
  8. fssalfi
    24
    karachi
    Yes some times 45 c but normally 30 to 37 c
  9. fssalfi
    24
    karachi
    Bro what u suggest in 129000 km my model is 2013 hy battry can finish
    Its 7 years and 129000 km
  10. bisco
    52,886
    agreed, its not an impressive statistic. that's why i'm a big fan of the 10/150 warranty, and trade before they are up.
