What does the Wheel Weigh??
Discussion in 'Gen 2 Prius Main Forum' started by yes.ittransforms, Sep 1, 2008.
  1. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    haha - they are $10,000 (yes Ten thousand) for a set of 4...
    I wish i could afford them.
  2. Loki2x
    Loki2x Junior Member
    Boston
    ^ better take good care of those. :D
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The stored rotational inertia is proportional to the square of the wheel's rpm, and proportional to the moment of inertia (derived from the static weight and shape).
    So it is significant at high speeds. Expensive wheels may not ultimately pay for mpg decrease, but may win a race.
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    It would fit perfectly, if the "offset" is the same.
  5. PriusTech
    PriusTech Active Member
    264
    122
    Reno
    When you go to a ++ size like 17" or 18" the low profile tires that fit these wheels have higher speed ratings so they weigh more than the factory tires. You have to weigh the tire/wheel package to make a valid weight comparison.
    Factory wheels are very aerodynamic with the trim ring. Most any aftermarket wheel is not as aerodynamic. You will be lucky if you break even on mileage when you make a tire/wheel change from stock.
    Also an FYI. The 16" factory Touring wheels are magnesium, not aluminum
    Shelby profita likes this.
  6. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    you may notice the acceleration also the bigger wheels mean bigger tyres and more mass further out ( means faster when moving) also don't forget tyre speed ratings the higher the speed rating the more heavy steel in the beads to retain the tyre on rims should a slide happen. I always get H rated tyres for the Prius
