What does this code mean?
Discussion in 'Gen 2 Prius Technical Discussion' started by KCS79, Dec 3, 2020.
  1. KCS79
    KCS79 New Member
    OR, USA
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You mean other than "The hybrid battery system voltage is low." ??
    It likely means that your HV battery is failing or the connections are corroded.
    It certainly means that you need to have someone who KNOWS what that means to have a look at it.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    MONITOR DESCRIPTION
    The battery ECU monitors a voltage of the battery blocks to detect an open malfunction in internal battery
    voltage sensor circuits of the battery ECU and the wire harness between each battery block and battery
    ECU. If a voltage at one of the battery blocks is below a standard level or of all the battery blocks is within
    a specified range, the battery ECU judges that there is an open in the internal sensor circuit(s) or wire
    harness. The battery ECU then illuminates the MIL and sets a DTC.
    Now, in laymans terms, as mentioned above, it's basically saying you likely have a problem with a module voltage, the busbars that connect the battery modules together, the voltage sensing harness or the ecu in the HV battery.
    #3 TMR-JWAP, Dec 3, 2020
  4. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Usually when I get this code the first thing I do is look for corrosion in the hyrbid battery ECU where the voltage sensing harness plugs in. IF you're lucky you clean the pins with sandpaper and clean away all the corrosion. If you're unlucky you have to replace voltage sensing harness ($50 new) and sometimes the ECU itself ($100 used or $800 new)
  5. KCS79
    KCS79 New Member
    OR, USA
    Thanks
    Thanks
    #5 KCS79, Dec 3, 2020
  6. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Maybe this will help...
    SFO and Raytheeagle like this.
  7. KCS79
    KCS79 New Member
    OR, USA
    Thanks, that helps.
