What does this switch do?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Benj, Aug 19, 2020.
  1. Benj
    Benj New Member
    Australia
    i-Tech
    Just purchased this JDM PIP and I've worked out most of the controls, but there is a rocker switch, above the dash dimmer control (dash dimmer doesn't make much difference?) And next to the sound effect silencer button. I can't think what this rocker switch does?
    52,891
    welcome!
    your pic isn't working, and we don't get that in n/a. hopefully, someone with a jdm will chime in.
    all the best!(y)
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I believe the only rocker switch that would be expected in that area would be for the left/right mirror adjustment switch, so if it's not that I suspect something aftermarket - but without the picture we can only guess.
    Elektroingenieur likes this.
  4. CookieGuru
    CookieGuru Member
    104
    22
    Seattle
    2013 Prius Plug-in
    Nothing a little URL-foo can't fix :)
    The dash dimmer only has an effect when the headlights are on. DRLs can be on and the dimmer won't adjust anything.
    The ♪ button turns off the low-speed noisemaker. There's a video about it here, which ironically is in Japanese and was uploaded to the PriusChat channel.
    And I'm curious what that thing is just above the hood release.
  5. ChapmanF
    19,054
    Have you tried asking it to open the pod bay doors?
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    The pictorial index in the Owner’s Manual (PDF, in Japanese) shows the headlamp cleaner switch or the manual headlight beam axis adjustment dial in that position. Neither of those controls (shown on pages 293 and 307) looks like yours, however, so I agree with @QuantumFireball: it’s probably an aftermarket installation.
    If the switch has both left-right and up-down controls, perhaps it’s the target designator.
    It’s an onboard unit for the electronic toll collection (ETC) system used in Japan. If you were in Japan and had an ETC smart card, you’d insert it there to pay for expressway tolls automatically.
