What does this warning light mean?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kingbhoy, Jun 27, 2019.
  1. Kingbhoy
    Kingbhoy Junior Member
    UK
    We've had a dreaded beep that seemed to be due to the rear seat detecting someone sitting in the middle when there actually isn't (the beep and middle seat belt light both go off when the middle seatbelt is plugged in)
    However, a second light with the person outside of the car still stays and takes up the entire info display.
    I've tried plugging in all the seat belts but nothing changes,
    Any idea what this one means?
    Thanks
    52,740
    you can get the trouble codes read, but you might want to start with a check of your 12v health
  3. Kingbhoy
    UK
    I've just done a OBD scan today and nothing came up, I'm heading down to a Toyota dealer for an Aircon recharge in a couple of weeks, I'll mention it then and see what they think.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Just conjecture on my part. I suspect the switch telling the car if someone is in the middle rear seat has an intermittent malfunction. If it thinks someone is in the seat when there isn't, you're successfully fooling it by buckling the seatbelt. But the, if the switch works but the belt is buckled with no occupant, it give that second indicator with the belt fastened but the passenger outside the vehicle.
    I'm just guessing because there is no indicator like that shown in the manual for my '13 PiP. Since I no longer have that car, I can't test the idea.
    Kingbhoy likes this.
  5. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Maybe US versions don’t have these rear occupant sensors?
    fuzzy1 and Grit like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Correct, My rear seats out and there were no electrical connectors to disconnect.
    jerrymildred and RMB like this.
  7. Mendel Leisk
    42,217
    There's some Toyota UK owner's manuals available for download here:
    My Toyota | Toyota UK
    Puzzling, the earliest Prius manual available is 2012. I took a quick look, not much though; it only mentions detection of unbuckled seat belts in the front seats.
    A screen grab from page 490 of 2012 manual, fwiw:
  8. Kingbhoy
    UK
    Thanks guys, it is very strange.
    I've been through the entire manual with no luck.
    I'm also clueless as to where the pressure sensors for the rear seats actually are...the bank removes easily and has no wires so they aren't built into there.
    I've had a push around on the upright rear seat part but don't seem to be able to find anything that affects the lights there either, my best guess is on the frame of the car under the rear bank, but even there I can't see anything.
    odd!
  9. ASRDogman
    ASRDogman Senior Member
    8,005
    4,065
    Sure it's not the FRONT seat?
    I put a cooler on my front passenger seat. And every once in a while I hear this faint beeping.
    Eventually, I figure it out. I guess it's heavy enough when I go over a little bump, it thinks there is someone in the seat and the alarm goes off. I move it off the seat and it still thinks someone is sitting there. I have to
    buckle the seat belt to get it to shut up!
    #9 ASRDogman, Jun 29, 2019
    Kingbhoy and jerrymildred like this.
  10. Kingbhoy
    UK
    It could well be, I'll report back once toyota have taken a look in case anyone else runs in the same problem.
    jerrymildred likes this.
  11. fuzzy1
    10,687
    His first included picture makes quite clear that is is a rear belt. It must be something specific to his UK- or Euro-market car, as we haven't heard of any rear seat warnings on North American market cars.
  12. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    2020 Corolla has the rear seat warning, probably some of the newest models in 2019 Rav4 or Camry too?
  13. ASRDogman
    8,005
    4,065
    The only photo shows a dot on the roof. Without seeing the dots placements, difficult to make a judgement front or rear.
    Rear seat belt warnings for the rear must be new.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I see a dot on car floor
  15. fuzzy1
    10,687
    I see two photos. The first includes the words "REAR SEATBELT", which ought to eliminate any difficulty in making a judgement of front or rear.
