What else to change while changing struts/shocks?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Matt98svt, Sep 1, 2024.
  1. Matt98svt
    Matt98svt Junior Member
    85
    South Carolina
    2015 Prius v wagon
    I am looking at replacing the struts and rear shocks on my 2013 prius V. I know the dust boots need to be replaced as they have torn but is are there any other rubber parts that need to be replaced while im in there? Trying to see if its going to be cheaper just to do the ready to go strut assemblies or just the struts. Also any sway parts or end link parts? Thanks in advance
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,992
    6,890
    Texas Hill Country
    You will need a spring compressor to replace just the inside strut portion rather than the easier and less dangerous complete assembly. You should also go oem if you want them to last. Finally if they are not leaking oil, new ones won’t improve handling or ride assuming you have oem now. Only exception would be if a spring was causing a sag on one corner which would still be the same answer for me, complete oem assemblies.
    Matt98svt likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What is the odometer at? Our Gen3 hatchback front sway bar end link bushings were worn through at nearly 130K.
    As far as using a spring compressor tool, that's scary stuff. I had to compress a front strut spring on a 2010 Toyota Camry to replace the top mounting plate with a broken stud, and I was worried that somethings was going to slip or break while compressing the spring.
    SM-G781V ?
