What engines are compatible with my 2013 Prius trim level two 1.8L
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Nov 13, 2019.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    I've been searching all over for engine swap compatibility but haven't found much. How do I know if an engine will work in my car? Will any generation 3 prius engine work?
    51,985
    any gen 3, and even gen 4, with some shoe horning
    best gen 3 is 15, and 14 is better than earlier
  3. ChapmanF
    18,248
    Any Gen 3 (unless you consider the c part of the 3rd generation; the c engine is not the same).
    People installing Gen 4 engines have been doing some creative mods to make it work.
    jerrymildred likes this.
  4. Allison Meggison
    71
    El cajon
    Thank you ! I just looked at a 2013 prius C engine 1.5L on ebay that said my vehicle was compatible after I put in the year, make, model and type of my vehicle. This is probably incorrect right?
  5. bisco
    51,985
    right
  6. Leadfoot J. McCoalroller
    8,092
    7,577
    Pennsylvania
    2018 Prius c
    c engine can swap to 2nd generation prius but not the 3rd.
    The one you are looking for is officially named the 2ZR-FXE.
  7. Allison Meggison
    71
    El cajon
    OH thank you so much! That is helpful!
  8. Mendel Leisk
    41,497
    Try LKQ auto parts.
  9. Allison Meggison
    71
    El cajon
    When I type in 2zr-fxe into ebay it pops a lot of prius v engines, are these compatible with mine?
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Yes, the Prius v uses the same engine as the regular Gen 3. Maybe one of the v owners can speak to any mods that may or may not be needed.
  11. Mendel Leisk
    41,497
    Yeah I was thinking that too, a little reluctant to stick my neck out though.
    Corroboration: @Ragingfit has done a couple of 4th gen into third engine transplants. Same transplant engine type both times: one went into a regular third gen Prius, the other into a Prius v.
    I believe the transaxles are internally different, 3rd gen Prius vs Prius v. But that's irrelevant.
  12. Allison Meggison
    71
    El cajon
    Thank you ! If I went to a pick and pull yard how would I test the engine to make sure it works? On the phone they said I would have to ask the yard when I arrive but I'm thinking if the vehicles don't have any fluids and are missing a lot of other parts like batteries etc, how am I supposed to test it to see if it works?
  13. Leadfoot J. McCoalroller
    8,092
    7,577
    Pennsylvania
    2018 Prius c
    You generally can’t test them; so you don’t buy them from a shady dude dealing it out of the back of his truck on a vacant lot. :)
    Generally pick & pulls are good, word gets around fast if they’re selling garbage.
  14. Allison Meggison
    71
    El cajon
    Yea this is an LKQ pick and pull place, it seems legit. They have 3 locations in San Diego and I think are nation wide. Should I just look it over and try to turn the crankshaft?
  15. ChapmanF
    18,248
    I guess if you had an air compressor and a leakdown test kit, that's a test that could be done without a lot of trouble, at least if the yard staff didn't feel like scowling at you the whole time.
    But for the most part, it's about understanding it's to some extent a gamble of some n hundred dollars, and the odds are at least as decent as on various other things people gamble on.
    Ed Beaty likes this.
  16. Mendel Leisk
    41,497
    LKQ shows the odometer reading of the car the engine was taken from. And I suspect they're on the level.
    That's worth something, when assessing.
