What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    OK I'll bite: what is a "spark plug anti-fouler" and how does it relate to a failed CAT ??
    Sometimes a CAT will burn up and then pieces will come loose inside and plug up later.
    I've heard that muffler shops can provide CATs that meet minimum requirements for about $200.....installed, I think.
  2. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    YES!! One of the first Amazon shipments I got in for stuff for mine was the Heat shield. VERY good at blocking the sun from the front windshield. I like the little side flaps that cover the 2 small side windows by the mirrors. And the white interior side is nice. I roll mine up with the white side showing; don't get blinded by the reflective side of the Heat shield. Pricy but worth it since it's a great fit and cut down on interior temperature quite a bit.
    srellim234 likes this.
  3. stpeterick
    stpeterick Junior Member
    st pete fl
    Link to the Amazon product please.
  4. Priusguy78213
    94
    30
    San Antonio, TX
    Toyota Prius Prius V 2010 2011 2012 2013 2014 2015 Heatshield Sunshade | eBay
    Looks like it was Ebay, not Amazon. Been getting aftermarket parts from both; and a few other sources recommended here on PriusChat. Can't go wrong with this. I've noticed a big changed in temp. when I go out to the car when it's been sitting all morning. No carport or garage so this is a BIG help with the heat.
  5. WVPriusCZ2
    WVPriusCZ2 New Member
    Z2 - WV
    2014 Prius c
    I have a good noob question, this may have been addressed however I failed to read the whole thread.
    What is the best way to utlize the engine brake? Should I be shifting my C into B mode to slow down from high speeds, low speeds, downhill, or just when coming to a complete stop?
  6. qdllc
    qdllc Senior Member
    1,375
    400
    As I understand it, B is only really meant to impose engine braking on long downhill runs where your speed would run away without it.
    For example, if I'm on cruise control and am going downhill, the Prius will use regenerative braking to keep the speed controlled. I've yet to see what happens if the battery is maxed, but if such a situation would cancel all regenerative braking, I'd be forced to either use the brakes manually or go to B to prevent needless wear on the brake pads.
    Any regenerative braking you get from "coasting" is cancelled if the battery is maxed (IIRC), and regenerative braking from non-cruise control coasting is not all that much to start with as it's intended to recapture energy without needlessly slowing you down.
    WVPriusCZ2 likes this.
  7. USArmy31B30AntiHybrid
    Las Vegas
    2016 Prius v wagon
    Awesome!!! This is my first post and I hope, after I armed myself with the wealth of knowledge in this forum, I would finally venture into the DARK SIDE and purchase a Prius v (lowercase v for the Prius v wagon) and become a proud "HYBRIDITES":D
    usnavystgc likes this.
  8. ShaAnn
    ShaAnn Member
    94
    42
    2014 Prius c
    I just bought my first ever Prius c Four....just filled up the gas tank....$20.00...Calif prices.....love the little car..so zippy and quick...have had no trouble giving it the gas when needed....hope you enjoy your Prius v
    Rizzy Aqua likes this.
  9. PriusBandi
    PriusBandi Junior Member
    SoCal
    Thanks for the good info!
  10. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    I also just bought a C 4 :D Much slower than my last car ( Escape Titanium with turbo ) but still not bad. I have always been kinda anti-prius but I have just vowed to drive it like its not one :p
  11. tommytrant20
    tommytrant20 New Member
    HCM
    2001 Prius
    Four Touring
    I think you need to check the label to record and safer
  12. Soybeanmike
    Soybeanmike Junior Member
    Connecticut
    Four Touring
    Hi all- new reader and user. Great tips. Wish I knew about not jumping others with Prius :/. Hope it didnt affect my 07 Prius..it just wont start! Reading up how to fix or address. I'm not technical :)
  13. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Try a different 12v battery or charge the one you have.
    It's probably ok to jump some cars directly from the battery while the Prius is off. You just don't want to strain the DC / DC converter by turning the Prius on.
  14. Najeeb
    Najeeb Junior Member
    Ontario, Canada
    Technology
    Hello everyone,
    New member here. Is there anything I should note that would make driving the Prius different from a typical ICE vehicle (e.g. regen braking)?
    Should be getting my Prius very soon; upgrading from a Corolla.
  15. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The Prius does not recharge the big Battery in N, you want to avoid N if at all possible. (If you find that the brakes get rusty, doing a high speed stop in N can clear the rust)
    You want to shift to B at the top of long steep downhills, otherwise you can ignore B.
    Long slow gentle braking will yield better MPGs than panic braking.
    EV mode is mostly a gimmick, it does have uses in a parking lot so that the engine never starts.
    ECO, PWR and normal mode are 'user interface' changes and do not change the engine capability. (ECO does 'tone down' A/C activity)
    Drive it normally for several tankfuls, do not worry about MPG.
    If you have not purchased a prius yet and are purchasing new, read the Customization chapter and request your preferences BEFORE you buy. The sales man will get the Service Department to make the customization. http://www.toyota.com/t3Portal/document/om-s/OM47A29U/pdf/OM47A29U.pdf page 752
    #695 JimboPalmer, Jun 19, 2016
  16. Najeeb
    Ontario, Canada
    Technology
    Thanks for the response JimboPalmer.
    In case you're wondering, it's a used Gen 3 with Technology Package :) ), so no need to worry about customization.
    It's good to know that I don't have to worry about braking any differently than any other car. Since it has the regen system, I thought I would have had to press on the brake pedal later, and with more force. Guess it's not needed.
    As for fuel economy, I'll only be able to get a clear picture once I start driving it more regularly. Currently the figures are quite dismal, but that's with a) short drives in the neighborhood, b) the AC running full blast, and c) spirited driving. Hope to see those 50mpg figures with some practice.
    As for my initial impressions after two days, here's what I have to say:
    1. Who even needs to think about keys with the smart key system? You don't need to worry about unlocking the car even; and it's got the engine start/stop button, of course. Leave them and forget them until you leave the car.
    2. Since mine has the solar roof package, I must say it's very useful. I often come back to the car to find it whirring away and cooling the car while it's off.
    3. Toyota has made parking somewhat more confusing without the park mode on the joystick/gear shifter. From my understanding, it appears that you just have to depress the foot operated handbrake and press power. Looks like the P button on the dash is unnecessary as the car enables the parking pawl automatically.
    On the flip side, I have ATP with Intelligent Park Assist, so hey, at least the car can steer itself into the parking spot :) .
    4. I would have thought the suspension would be more absorbent. Not so. I'm quite surprised to say that my old (2009) Corolla's suspension is far softer. Besides to target a younger audience, is there any other reason Toyota might have done this?
    5. The 6 disk changer system is really cool, period. The best part is, my navi screen comes out to expose it.
  17. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Long gentle braking is better, as the amount of energy that can be absorbed by the battery is limited. Most of hard braking will just be heat, not electricity.
  18. Redpoint5
    1,026
    509
    Portland, OR
    I occasionally use the park button when I jump out to check the mail. It also comes in handy when there is a long wait, such as the other day when a crash on I-5 south in Portland had me stopped for 2 hours. Leaving the car on but parked was handy, as it was 97 degrees outside and I could run the AC from the battery.
    eye144 likes this.
  19. Justin Ortega
    Justin Ortega New Member
    Virginia Beach, VA
    I recently bought a used 2004 Prius. It's in good condition. I was driving it last night and noticed that the lights on the steering wheel for the audio and climate control switches weren't lit. Also, the lights on the "POWER" switch, headlight and turn signal switches, wiper and washer switches, electronic shift lever (R, N, D, B), "P" switch, cruise control, Km/h or MPH button, trip meter reset button, emergency flasher switch, the hazard switch, smart entry and start cancel system switch, car audio, and power door switches weren't lit as well. I turned the instrument panel light control dial switch all the way up too and still nothing is lit. The good thing is the dashboard lights up and displays great. The clock works fine as well. Has anyone ever encountered this problem before? If so, is there any fuse connected that can be located to fix these luminous problems? Would greatly appreciate the help!
  20. XiaoBai
    XiaoBai New Member
    Singapore
    2015 Chevy Volt
    Is there a personality that just has to push the gas to it's limits?
    I had a co-worker who constantly ran on the edge with a gas can in the back of his wagon, just in case. I would see his wife driving south and I knew he ran out of gas, again, on a Mail route. The same route he drove every day for years. Got me?
