What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. Prius23years
    Prius23years Junior Member
    Derby England
    2021 Prius PHV
    Business Ed. Plus
    I've just joined this forum having been a member of the UK based EcoCarsUK group and its predecessors for many years. I got my first NHW11 Prius back in March 2001, being fascinated by the then revolutionary technology with its Atkinson Miller cycle engine, regen braking etc. I was one of the first 200 people in the UK to have a Prius (I know because the UK government back then had a £1000 money back scheme to promote the adoption of hybrid vehicles). I kept the NHW11 until 2009 when I sold it to my brother. He still has it, it's still going strong as he does very little mileage and it is still passing its annual MoT test (a mandatory annual car safety test in the UK) with its original corroded but still acceptable stainless steel exhaust system! Not bad after 23 years!. I then got a 2009 Prius, followed by a 2016 Prius and since 2021 I've had a plug-in hybrid Prius, the Business Edition Plus with the smaller more efficient 15" wheels. It's the first PHV Prius I've had and the nominal 34 miles EV range is more than sufficient for my usual daily driving needs, but I've got the economy of the hybrid engine for longer journeys. I find the EV range drops to about 29 miles in winter, whilst at the moment during the warmer weather it's showing just over 36 miles. One of the other threads stated in a post by user Gokhan that the real battery EV only capacity of the 8.8kWh (total) battery in the Gen 4 PHV (Prime in the US) is 6.34kWh. Which means that in terms of miles per kWh I'm getting between 4.5 (in winter) to 5.7 in Summer, pretty impressive! On longer journeys such as a 2000 mile motoring trip to the Alps including high speed German autobahns and steep mountain roads (obviously benefitting from the regen on the downhill sections) overall I got about 66miles per (UK Imperial gallon), which I thing equates to about 55 miles per US gallon.
    The one thing I don't like in recent years is the trend to getting rid of the space saver tyre/tire. I don't like just having a repair kit with gunk, which only works for some punctures and which means after use the tyre can't be repaired and has to be scrapped. So I bought a 2nd hand space saver on ebay for £50 which I take with me if I'm going on longer journeys.
    Looking forward to reading and contributing to this forum.
  2. Darlene Deffes
    Darlene Deffes New Member
    Jacksonville
    2015 Prius v wagon
    Would it be possible to fill up drive somewhere, make note of the miles before and after the drive then fill up again and calculate to find the mileage?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    That is normally how it's done. But the person you're responding to has a 2nd generation Prius, which has a bladder in the gas tank. That makes every fill up a unique experience.
    Doug McC likes this.
  4. ChapmanF
    19,034
    Even so, the law of large numbers will still do that voodoo that it do so well.
    jerrymildred and Doug McC like this.
  5. jerrymildred
    11,517
    14,170
    Tampa, FL
    In other words, it'll average out over the long run. ;)
  6. Mendel Leisk
    42,355
    Exactly. Due to vagaries of gas station pump shut off, compounded by Gen 2 bladder tank, the mpg calculation for a single tank can be off, but stick at it for 2~3 tanks and it averages out.
    Maple Leaf (Toyota Prius) | Fuelly
  7. ruikangzhu1990
    ruikangzhu1990 New Member
    los angelos
    2025 Prius Plug-in
    SE
    thanks for the info!
  8. davev1pa
    davev1pa Junior Member
    34
    Lincoln,NE
    Two Eco
    I’ve used B mode extensively. I tow occasionally and it’s great. I also use it daily when approaching intersections that are loaded with stopped traffic…. Rather than annoy the drivers behind me by flashing brake lights I “B” mode it so I don’t have to come to a complete stop and restart at the intersections… my understanding is that there’s no regeneration of the hybrid battery when in B mode but I’m thinking it’s better than a dead start up at the intersection.with power usage. I of course use the B when towing down a steep hill , mountains etc
  9. P0Valik
    P0Valik New Member
    Moscow
    2014 Nissan LEAF
    Welcome! I am also new here and I am looking really hard to contribute to this forum!
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    I am not sure how much a Nissan LEAF EV owner can contribute to a Toyota Prius Hybrid forum, but welcome.
    I am a former Prius owner but currently own a 2025 Toyota Camry Hybrid so some parts are still useful.
  11. Jon Batchelor
    Jon Batchelor Junior Member
    25
    FL
    Interestingly, I have run out of gas once or twice in almost every car I've ever owned. Except for my Prius. I have never run out of gas in my Prius, even when driving 30 or 40 miles more, after the estimated range says 0. I try not to let it get too close, but things happen (like the only gas station in an area has no fuel, for example) ... but somehow it's still never run out. I'm very confused, but very happily so.
  12. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I don't think having a different brand and model should necessarily limit someone's ability to contribute — I feel there are plenty of skills that are cross compatible between the two, and I think it's important to have multiple lines of experience to consider :D
  13. Prodigyplace
    12,715
    11,848
    Central Virginia
    True, but the whole drivetrain is designed differently, apart from brakes, perhaps.
  14. Billy boy SD
    Billy boy SD New Member
    2014 Prius c
    Thank you for this !!
