What exactly causes the HG to blow?
Discussion in 'Gen 3 Prius Technical Discussion' started by Higgins909, Sep 24, 2023.
  1. Higgins909
    Higgins909 Member
    289
    71
    I'm trying to remember how the Gen3 engine exactly fails.
    Is it that the piston rings block the oil hole and or oil gums it up and it starts to burn oil. That then sends carbon to the EGR and cat? When the EGR gets clogged up too much, excessive oil pressure happens and blows the head gasket?
    Maybe someone can clear that up or make it make more sense. As long as I keep the EGR clean, could the engine hit 300k? Is that the only thing I really have to watch out for? I guess the cat will eventually clog as well.
    Right now I'm trying to remember how the carbon even builds up in the EGR. Where does it exactly come from? I kinda remember the EGR radiator being connected to the exhaust manifold. Is that were it all comes from? The exhaust is spitting out carbon/oil?
    Thanks,
    Higgins909
  2. ChapmanF
    19,025
    According to a recently-discussed European TSB where Toyota addresses the issue more directly than we've otherwise seen them do, they seem to have pinned it on the programming for the variable-speed water pump, allowing certain spots of the head/block interface to get extra hot in certain patterns of engine use.
    JC91006 and mikey_t like this.
    52,858
    it's the rings, no, it's the egr circuit, no wait, it's the 10,000 mile oil changes, no, it's the untested acidic coolant, no, it's the design of the head gasket, no...
  4. PriusCamper
    PriusCamper Senior Member
    13,466
    5,432
    Pacific Northwest, USA
    Lol... Ya'll getting tricked and are replying to an early generation AI software post not based on a real person but a broken computer program that is long since outdated. They're using robots to test the respondents for how easily they're fooled.
    Or rather to be clear, the use of the word "remember" is not used in a logical or rational way and maybe if this was a person in a foreign country perhaps they'd deserve the benefit of the doubt, but in Texas? I don't think so...
    So enjoy your time talking to a fake AI robot that's seriously lacking in intelligence. As in even a village idiot knows the difference between the meaning of the phrase "I'd like to remember" and "I'd like to learn."
    And don't get me wrong @Higgins909 was a legit participant back in the multiple posts in Late July and early August, but that's not the robot you're talking to right now in this thread.
  5. ChapmanF
    19,025
    Meh. Some other reader may come along any day and read the thread. So it doesn't hurt to have information there.
  6. Mendel Leisk
    42,349
    For head gasket preservation, my money's primarily on keeping the EGR components (including intake manifold) from clogging up with carbon. I'd recommend to do this at least every 50K miles. More info in my signature (on a phone turn it landscape to see signature.)
    Just for giggles I also:
    1. Do oil changes every 6 months or 8K kms (5K miles), whichever comes first. (This is Toyota Canada's stipulated oil-change interval for 3rd gen Prius, btw)
    2. Have a quality oil catch can installed in the PCV circuit. Drain it at every oil change. Two actually, in series...
    3. Have the Toyota Block Heater installed, and use it virtually without exception, for a couple of hours, before the first cold-start of the day.
    #6 Mendel Leisk, Sep 25, 2023
  7. Higgins909
    Higgins909 Member
    289
    71
    So here's the short version of my findings. There is really nothing you can do to prevent the head gasket from failing. It seems it's because it's a hybrid and heat cycles so much that it just wears it out. I speculate if you live up north, you may benefit from grill blocking or risk early head gasket failure, compared to a southern car.
    So, the PCV catch can solution probably does next to nothing. If you look down your throttle body and see the bottom of the intake is clean, a catch can probably isn't going to help. The vapor that it generally catches is minimal to the problem down below. This minimal vapor can contribute to dirty valves, clogged cat, clogged EGR system, including the intake's EGR ports and channel.
    The EGR stuff. So the EGR connects to the exhaust and to the intake manifold, with the 1 channel running to the 4 ports that get carboned up. Also has 2-4 coolant inlets/outlets. So the carbon is coming from the exhaust, goes into the EGR radiator, valve, then pipe iirc, and then into the intake and comes out those 4 holes.
    So, where does this carbon come from? It would seem it's the piston rings. They do not form to the cylinder correctly after getting gummed/carboned up and then do not wipe the cylinder walls correctly, allowing oil into the combustion chamber. Which then goes out the exhaust manifold, into the cats and EGR system to clogged them.
    Why this doesn't damage the head gasket? None of these are really connected to the head gasket. The head gasket usually fails right inbetween cylinder 1 and 2. Which happens to be right next to a coolant channel, iirc. If the EGR gets clogged up, it actually suffocates the engine "at low rpm" and any of that extra pressure on the exhaust, well goes out the exhaust instead of the EGR radiator.
    If the PCV valve is stuck open, it can allow oil into the bottom of the intake manifold that eventually gets sucked up into the engine. Worst case this bends a rod or locks the engine up. Can definitely run the engine dry of oil. If it gets stuck close, it can cause extra pressure in the engine. However there is no way for this to get into the combustion chamber. You might think well what about the oil passages through the head gasket (which now that I think about it, is this even a thing?) If the pressure from the crank gets to those areas, its no where near as much pressure as a combustion cycle. But this can put extra pressure on other seals not made for high pressure.
  8. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    So the european tsb states overheating causes the hg failure, of course along with the head gasket being upgraded later on, right? So in other words hg fails for one of the main reasons everyone already knows since 1925. Two main reasons, overheating and inadequate head gasket quality. So Toyota’s fix is to speed up the water pump under harsh conditions. I guess that assumes a non leaking system for that fix, so back to square one imo.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    With that being said, you’d disagree with grill blocking Higgins 909 ?
  10. Higgins909
    Higgins909 Member
    289
    71
    So, in my experience, I think grill blocking is ok. This way the engine gets heat cycled less. When it's 40-60F outside, all day, on my little 7 mile drive to work and then 7 back home, my engine got around 160F. I think I was full grill blocking or at least half. (Bottom grill) Which is nowhere near the 195F~ that the thermostat opens at. Watching the engine temp jump up and down from 140-160F the whole drive. I think the highest temp I've ever seen was 205F, on a hot Texas summer, up a hill.
    Now, if your engine hits that 240-250F mark, from what I can remember about Asian engines, is that's a guaranteed warped head. Which then causes the HG to not seal right and and blows the HG.
    I don't get why the Prius has 2 water pumps and at least 1 thermostat. I wonder why they didn't just have a water pump and turn it on as needed, for the engine. But in the action of grill blocking and you're not hitting that temp to open the thermostat, it wouldn't change anything, if it was overheating in certain areas of the engine, from my understanding... I think that last sentence makes sense, I need to wake up some more.
  11. bisco
    52,858
    if the main cause is hybrid heat cycling, why wasn't it as big an issue on gen 2?
    Mendel Leisk and Brian1954 like this.
  12. ChapmanF
    19,025
    Which Prius do you have in mind?
    Leaving out the water pump for the inverter (that's a whole separate system), and the pump for the thermos in Gen 2, there were 2 water pumps serving the engine in Gen 1 and Gen 2. One was the usual mechanical one run by a belt, and one was electric, only to keep the warm water flowing when the engine was off but you wanted heat in the cabin.
    Gen 3 got rid of the extra one just for the heater, and the one on the engine is electric, and variable speed, so they did what you wonder why they didn't. Not only can they turn it on when needed, they can turn it on at whatever speed is needed. And they can keep it on when the engine is off, if you want heat in the cabin.
    The recently-mentioned European TSB puts responsibility on the code in the ECM that decides how fast the variable-speed water pump should run. So, none of that existed in Gen 2.
    From the way they wrote the TSB, it doesn't sound like "overheating" is really the issue, in the sense of the overall coolant temperature ever looking too hot. Of course the thermostat opens wider, the ECM runs the pump faster, and at a point the fans even come on, the hotter the coolant gets.
    The TSB seems to be more about the overall coolant temperature always looking ok, but where there is too little coolant flow sometimes (too low a pump speed) for the coolant to even out the temperature between the engine's hotter and cooler places. So the hotter places get too hot (and the temperature contrasts get too big), even though the coolant temperature measured in the one spot where the ECT sensor is never looks too hot.
  13. Leadfoot J. McCoalroller
    8,289
    7,803
    Pennsylvania
    2018 Prius c
    Hot-spotting was eventually accepted as the cause for head gasket failures in the last Japanese-made aluminum engine I studied to any real depth.
    It's a little comforting to find simple causes for these problems.
    I do wonder if the electric water pump in the Toyota 1.8L could be gamed into running a little more, either with a spoofed ECT or a cloned/augmented PWM to the pump motor.
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    One theory for HG failure, that hadn't been brought up completely, is that the EGR gases (oily carbon gunk), slowly builds up in the intake manifold passages. Contributing to the problem, the buildup is uneven across the intake ports, with the heaviest buildup usually occuring at cylinder 1 > cylinder 2, and so on.
    Since EGR gases are added to the intake charge to cool the combustion process to keep NOX emissions down, cylinder one will eventually run hotter and hotter. The HG typically fails at the thin section between cylinder 1 and 2.
  15. ChapmanF
    19,025
    Very few theories have been brought up more completely or more incessantly on PriusChat than that one, for some years now.
    The European TSB from Toyota seems a relatively less-discussed addition to the conversation.
    mikey_t likes this.
  16. Mendel Leisk
    42,349
    I think your inference is that makes it less credible?
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,113
    6,970
    Texas Hill Country
    Low tension rings dramatically increase blow by which returns via the egr and pcv, also a bad design due to its placement. Toyota acknowledged the ring problem and quietly replaced rings and pistons free for a couple of years. With no class action suit across many models with low tension rings, Toyota spent their rehab money on flawed inverters and brake boosters.
    So why don’t low tension ring Corollas and Camrys slightly leak coolant past the metal head gaskets embedded black seal? Prius thermal cycling, demonstrated to reach deltas of 50f at times.
    So why don’t gen4s have death rattles leading to expensive hg and engine replacements. Dramatic improvements to cooling around the cylinders and heads combined with a special insulator. Plus more head gasket sealing material embedded in the gasket. Once Toyota figured this out, hybrids show up in minivans, trucks and Corollas.
    Gen4 Insulator
    Gen3 PM? New pistons and rings combined with cleaned up head, valve seals and egr cooler. Older models benefit from the revised intake. A pro rebuilt engine usually possible for less than a dealer hg or used engine.
    #17 rjparker, Oct 14, 2023
  18. ChapmanF
    19,025
    I would never suggest that anything becomes less credible simply because of frequency of repetition.
    Or more credible, absent something else happening, like a visible progress where later repetitions supply additional evidence, address earlier gaps, and so on.
    Nothing requires that credibility and frequency of repetition have anything to do with one another.
  19. Mendel Leisk
    42,349
    There’s always carbon coming out of the cylinders; doesn’t have to be an oil-burner.
    V Sport Wagon likes this.
  20. james wang 20
    james wang 20 Junior Member
    65
    fiji
    In my opinion, a cylinder explosion occurs when an object that cannot be compressed, such as water or oil, enters a running cylinder, causing problems with the connecting rod, cylinder or cylinder head. The purpose of egr is to lower the combustion temperature, thereby reducing the emission of nitrogen oxides. If there is a problem, it may lead to high engine temperature. The materials of the cylinder and the cylinder head are different, and their thermal expansion coefficients are also different. When the temperature changes drastically, the contact surfaces (cylinder gasket) may move imperceptibly with each other, and tearing will damage the cylinder gasket structure and cause damage. Due to its design, the prius works with engine clearance, so the engine temperature changes more than that of ordinary vehicles, and the chance of cylinder head damage is greater. So reducing the temperature change rate and the cylinder gasket material may be the key. Under normal circumstances, do not step on the accelerator pedal vigorously for a period of time when the engine is just started, and frequently check the coolant, cooling pump and EGR system, which may reduce the chance of major failures.
