What Exactly does EV Auto Do?
Discussion in 'Prime Technical Discussion' started by mr88cet, Jan 26, 2017.
Tags:
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I apologize in advance if this has been answered already and my searches have not found that answer, but I don't recall seeing anybody reporting in detail what, under moderate weather conditions, the "EV Auto" mode does.
    That, especially in terms of at what speeds or at what acceleration rates, the engine kicks in.
    Again, that, under comparatively moderate weather conditions, since it's certainly not going to be winter forever (arguably it's hardly ever winter here in Austin, TX!). That, also assuming that you start with a full battery.
    Thanks, Primers!
    52,740
    it decides for you, the most efficient way to use ev vs hv. there are no data details, because every trip is different.
    however, it cannot foretell what you are planning in your head, or road/traffic conditions. so, it's just a feature for people who don't want to decide for themselves.
    it won't be as efficient as a good driver with prime experience.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The word "exactly" in your question makes it hard (impossible) to give a good answer.
    Prime owners can give you a general answer based on their experiences but even they don't know "exactly".
    Tightwad77 and EV-ish like this.
  4. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    I like your reference to us as "Primers".
    thatoneraccoon likes this.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    So I gather it's a complex question. Do you often see it in HV mode below, say, 50MPH?
  6. jgspears
    jgspears Junior Member
    30
    Conover, NC
    I use EV Auto when I know that I am going on a trip that is longer than my EV range. This way the Prime makes the decision when to use hybrid mode when it thinks that is more efficient, for example when going up a steep long hill. If I know I can get to a charger with the range left I switch to EV to be sure to take advantage of EV driving.
    Gcoletta, goluchowski and Trollbait like this.
  7. Db17
    Db17 Member
    188
    92
    Visalia, CA
    I figure I paid for it, I'm gonna let it do all the work and then not worry that I might have missed an additional percent of efficiency.
    Tightwad77 and ruby like this.
  8. bisco
    52,740
    prime evil.
    you won't see it if you don't select it. it is a mode selection: ev/ ev auto/ hv/ hv charge
  9. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    EV auto is a power thing, not an efficiency thing. It recruits the engine when needed in high power situations, like passing.
    #9 MikeDee, Jan 26, 2017
    Tightwad77, EspressoFueled and Wattup like this.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    So, my more-specific question was whether, in EV Auto mode at under 50MPH, do you often see it choose hybrid operation (i.e., engine on)? I wouldn't be terribly surprised if it would conclude that HV operation is more efficient than EV operation at above 50MPH.
  11. bisco
    52,740
    okay, i can't answer that one, since i don't own one. but my feeling is, if you start the car and press ev auto, the engine is going to go through the warm up phase so it's ready to go when needed.
    then it will probably use throttle pressure to decide when hv is needed, such as going uphill or higher acceleration.
    if you use it on your regular commute, idk if the 'learning' feature might apply.
  12. mr88cet
    2,313
    1,335
    Austin, TX
    Speaking in very-broad generalizations, all Prii (plural of Prius :)) try to drive on electric until the requested power exceeds that available electrically. Previous Prii almost immediately run out of electrical oomph, whereas the Prime finally has enough battery capacity and electric drive strength to not have to turn on the engine much at all. So, where do they draw that line, now that it's ... a little more subjective?
    Well, OK, perhaps the simplest way to ask my original question would be this: If you were to drive a P.Prime in EV Auto mode for an extended period of time, recharging once or twice a day, in moderate weather conditions, about what percent of the time would you estimate the engine runs?
    Tightwad77 likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Being an Energi owner with a very similar design, there is no definitive answer. It just depends on numerous variables: battery SOC, battery temp (big factor), ambient temps, load (uphill, flooring it), etc. Nice weather, full batt, level ground, it will go to 84mph full throttle in EV but it will take awhile since EV is slower than hybrid mode.
    Back to your <50mph scenario, EV AUTO should stay in EV nearly 100% of the time unless one or more of the above variables is surpassed. You can go for weeks without burning gas but eventually the software will run the ICE to both condition the oil and use up the gas before it goes bad.
    Trollbait likes this.
  14. Trollbait
    12,798
    Like the PiP, there is multiple variables that could trigger the ICE. The bigger battery just make them less likely.
  15. MikeDee
    1,581
    597
    EV is always more efficient. 133 mpge vs 55 mpg (or whatever).
  16. MikeDee
    1,581
    597
    I'll try that if I can remember. My guess is the engine stays off though.
  17. bisco
    52,740
    why would ev auto try to stay in ev? you have ev mode for that. i could be wrong, but i think it would try to do whatever is most efficient.
    the new pacifica phev is basically ev auto all the time. i hope it doesn't just use up the ev, then switch to hv.
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    Why would it NOT ????
    If the power you are using comes from the grid instead of from gasoline, the assumption is that it is much less expensive.
    Some people prefer to leave the settings alone and JUST DRIVE THE CAR. (A lot really I suspect.)
    Thus, EV Auto.
  19. bisco
    52,740
    the people who programmed the car don't know what the fuel costs are, where and when the car is being used.
    they have to decide what driving circumstances are more efficient for each type of motive power.
    if all it did was use up ev then switch to hv, you wouldn't need it because that how the car works by default.
    Tightwad77 and giora like this.
  20. Sam Spade
    2,036
    1,024
    2017 Prius c
    Oh here we go again.
    You think you know more than the scientists and engineers that built the thing.
    Give it a rest please.
    Hint: You don't.
