What exactly happens when you brake?
Discussion in 'Gen 2 Prius Main Forum' started by jamarimutt, Aug 27, 2004.
  1. daniel
    14,487
    1,519
    Spokane, WA
    Except that according to Evan's graphs, it's only on the Classic that friction is applied first. -- But I still say those graphs are screwey because they're trying to relate three variables (pedal pressure, elapsed time, and braking force) on a two-dinensional graph.
  2. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    This would be the correct observation. Brake controls engineer here. Motor response is MUCH faster than friction braking. First are the fluid compressive delays, then the master cylinder actuation delays, more compressive delays, then the caliper piston or drum actuator expansive delays, then the compressive delays for the lining material, then the frictional force is finally realized. The Prius controls, as documented, take advantage of a pedal travel transducer and a pressure transducer. The rate of pedal apply, the pedal travel, and the actual master cylinder pressure are used to determine the amount of hydraulic (frictional) braking and regenerative braking to be used. For a given pedal travel which is less than a predetermined amount, as mentioned in the brake control sequence, the target brake force is calculated. Unless this target force exceeds the regenerative force capability, only regenerative braking is used. Refer to the '04 graph where it shows no friction braking during initial pedal travel. The tricky part of the control algorithm is the process of beginning to meter the hydraulic fluid to the calipers and drum actuators to allow for a seamless transition to part or all hydraulic braking, as is done below 8 MPH. This transition depends on the target brake force calculated, the brake force realized, the charge on the battery, the rate of pedal apply, and the amount of travel. This is not easy to simply explain for all braking conditions. It depends on what is happening at any given moment versus the algorithm targets. The need for ABS, traction control, VSC, EBD, and brake assist all affect the speed, rate, and total amount of hydraulic and regenerative braking that is used. The hydraulic braking force is controlled at each wheel while the regenerative braking affects only the front wheels as a pair. Shall I go on?
  3. richard schumacher
    7,686
    1,068
    United States
    Yes, the Prius brake pads could last much longer than those in a conventional car. I write "could" instead of "will" because Toyota may have taken advantge of the greatly reduced brake pad wear that occurs in the regenerative braking system to design thinner or less durable brake pads for the Prius.
  4. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    mdacmeis- Thank you for your insights. I am sometimes frustrated by posts that just say thanks for what you said, but that was a fine post sir.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    One thing to remember in time vs. pressure comparison is that 60 amps (max) of regen translates to alot more decelleration force at lower speeds than it does at higher speeds. At higher speeds, more hydraulic braking is required to get the same negative acceleration forces. Once the car slows down, if using constant pressure, the hydraulic brakes can let off a bit and let the increasing regen force take over. Now of couse, once MG2 RPM's drop below a certain point, it's no longer possible to generate 60 amps, and then hydraulic braking must take over again.
    The graphs are somewhat representative of this phenomenon.
    hope this helps,
    -Rick
