What feature do you wish your Prius had?
Discussion in 'Gen 2 Prius Main Forum' started by norbert, Nov 28, 2004.
  1. prius04
    prius04 New Member
    1,161
    NorthEast USA
    I like the idea of jumping to the head of the line after a Prius MVA. This seems quite fair and appropriate.
    Some ideas above are outside the realm of possible. This seems especially doable.
    Good Idea Patrick
  2. norbert
    norbert New Member
    39
    A mute button for the sound system. I really miss that.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I miss the sunroof I had with my Saturn. I believe it helps cool the car down after being shut up on a hot day. Can also be romantic on a star filled night.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(norbert\";p=\"54162)</div>
    I miss the "attenuate" button my old Kenwood system had...didn't mute completely, just decreased the volume by about 75%.
    You CAN turn off the entire system by pressing and holding the MODE button on the wheel and it comes right back on with a brief press....that's the best alternative.
  5. DanMan32
    3,799
    27
    Tampa Bay, FL
    Yeah, my Aiwa did that too. Was in combination with the power button. To turn it off, you held the power button for 2 seconds.
  6. richard schumacher
    7,683
    1,066
    United States
    1. The climate controls should all stay exactly as they were set before the car was shut off (as it is, if left in "defrost" and "recirculate" before powering down, it will switch to "outside air" at the next power up).
    2. the "wash and wipe" setting for the rear window should be adjacent to "off", the same arrangement as for the front window. As it is you have to go through the wipe settings to get to "wash and wipe". (Sure, one can "wash" and then go through "off" to a wipe setting, but it's an additional action and a pointless annoyance.)
    3. A way for the user to adjust the steering wheel indicator brightness other than asking a dealer to do it with a scanner.
  7. pepa
    pepa New Member
    102
    Rockford, Illinois
    As I stated elsewhere, I drove my first 150 miles in Prius today...
    So here is my only wish so far: I wish that Toyota modified the shift lever so when you want to go forward you would shift UP, and when you want to go backwards you would shift DOWN. I can't believe that in Prius you have to do it backwards - against common sense and standards used by the industry for 100+ years.
    I almost ended up in my driveway ditch today because of this nonsense.
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    to go forward it's been down or back on every auto tranny I can think of in the auto industry since time began. The only industry to do it different is the forklift industry, where forward is up and reverse is down, or push the shift lever forward to go ahead and pull back for reverse. Most new users always comment on it.
  9. Kablooie
    Kablooie Member
    273
    La Canada
    I want an ejectable passenger seat and blades that come out from the hubcaps.
  10. norbert
    norbert New Member
    39
    <div class='quotetop'>QUOTE(pepa\";p=\"54189)</div>
    The way it is the way it should be. Think of a floor automatic. It goes down to drive and up to reverse.
  11. Bill60546
    Bill60546 Member
    388
    Chicago
    OK, here's my list too:
    1) Leather interior
    2) Moon roof
    3) Bose stereo (not even levinson comes close)
    4) Lockable glove box
    5) 16" Euro wheels
    6) Outside handle for hatchback
    7) Inside hatchback release toggle near the gas cap release toggle
    8) Change the Drive and Reverse locations for the gear shift (yes, I agree its alittle confusing; Drive should be forward and Reverse should be back)
    9) Body side molding
    10) Wheel well protective trim
    11) Rear disk brakes
    12) Nuke the gas tank bladder (great idea gone wrong)
    13) Increase the illumination or intensity of the toggles/switches at night; all toggles or switches should be illuminated
    14) Nuke the cold weather indicator (we already know its getting colder and 37* isnt considered cold anyway)
    15) Windshield washer level indicator (current size is great but how much is left?)
    16) Separate on/off switches for the rear defroster and outside rear view mirrors
    On the whole, its a fine car thats helping drive positive change and is only going to get better. Is it too early to place an order for an 08?
  12. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Pepa,
    Another poster awhile ago commented on the way the shift is down to go forward and how counter that is to the usual and at first I thought they had a point. But now that I've had my car for 3 months, I prefer it this way. Sometimes on a long downhill I'll shift into "B" and then back into "D" at the bottom of the hill. I now find the pressing down MUCH more comfortable. I guess it's more "ergonomicly" correct.
    I think you may agree once you get used to it.
  13. daniel
    14,487
    1,519
    Spokane, WA
    I wish my Prius had a passenger. Specifically an attractive, good-natured female passenger. Alternatively, she could drive and I'd be the passenger.
  14. bruceha_2000
    bruceha_2000 Senior Member
    3,055
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(Bill60546\";p=\"54232)</div>
    How old is your car? I haven't gone through winter yet so maybe it will be a problem when it gets colder. So far I haven't had any issues with the gas tank bladder. If it keeps gasoline vapors from forming - good. It might also reduce/eliminate the possibility of water vapor forming and potentially causing gas line freeze-ups.
  15. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    :icecream: & sirens!
  16. sforshey
    sforshey New Member
    Columbus, OH
  17. ml194152
    ml194152 Member
    135
    Katy, TX
  18. noisebeam
    noisebeam Junior Member
    64
    Arizona
    Passenger seat belt warning
    <div class='quotetop'>QUOTE(daniel\";p=\"54235)</div>
    When I put my briefcase on the passenger seat I get an alarm (flashing icon on dash) that it hasn't put on its seatbelt. I haven't go used to it yet - it keeps catching my eye.
    Al
  19. noisebeam
    64
    Arizona
    Padded center armrest
    Someone mentioned a window arm rest. I'd be happier if the center console armrest was padded. After a 1hr drive it feels like my arm/elbow is resting on concrete. I have a mini pillow now. Other cars I've driven actually have a pad in the armrest, not just a cloth covering.
    Al
  20. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :idea: Another Thought :idea:
    How about a substantially brighter MFD with good sharp contrast...
