What fell down under my Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beccajaya, Dec 30, 2015.
  1. Beccajaya
    Beccajaya New Member
    Lake Tapps washington
    I have a 2008 Prius. We bought it new - first new car ever and I joked I'd drive it till the wheels fall off....well 182K later... Last night I'm doing about 65 on the freeway and there is a horrible grinding noise, smoke starts billowing and the wheel is jitteriness like I blew a tire. I get to the shoulder and get out to see that there is no flat tire. I looked under the car and there appears to be something hanging down from the engine area. When the tow truck came, the driver said it would roll in park and that the transmission was shot. It is now sitting in my driveway, we've had estimates to replace the transmission from $2200 (used with 70K on it) to $5500 new from the dealer. Kkb isn't only about $3000. When I try to push it, it doesn't roll. Does anyone have any ideas? image.jpeg
  2. 48mpg
    48mpg Member
    193
    46
    florida
    I
    cant tell but it looks like the exhaust system, take a picture from the side of the car by the tire, get on the ground and point the camera up with flash..its not physically possible for a transmission to fall out of a car no matter what Billy Bob told you.
    if the car goes into gear and moves on its own even a few feet its not the transmission..odds are he put it in neutral to push it, if you cant push it in park neither did he.
    49,720
    sounds like the wheels fell off.:cool:
    but seriously folks, did you get any dashboard lights? what happens when you press the power button, does it become ready? does the engine start? other than the scraping, does it move in d and r?
  4. Patrick Wong
    18,200
    6,479
    A nice photo of the OP's driveway surface. We need better photos of the car's underside, if the OP expects a reasonable answer to his/her query. In particular, what do the transaxle and half shafts connected to the front wheels look like.
  5. JC91006
    16,496
    8,406
    That $2200 used transxle option sounds like a winner! But I don't think I've heard of any people mentioning their transaxle has fallen off while driving......this is a first
  6. Patrick Wong
    18,200
    6,479
    I think it is likely that a mount which holds the engine/transaxle to the body has failed. If that mount is replaced, that may be all that is required. This is why we need some decent photos.
  7. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Is that the oil pan we're looking at.? OP we need more pics
  8. bisco
    49,720
    is there an exhaust shield?
  9. Beccajaya
    Sorry for the bad photo and late reply. When I turn it on it starts all dash lights come on, maint req light blinks. Engine runs and sounds normal until I put it in drive and let out break, horrible rumbling grinding sound ensues. I shut it off quick. Here's a better photo more car less driveway. image.jpeg
  10. Patrick Wong
    18,200
    6,479
    How about opening up the hood so you can look at the mounts holding the engine to the body. If you see anything interesting, take more photos.
    I think you should have the car towed to your local Toyota dealership or a competent hybrid independent for a diagnosis. It looks like an engine mount has failed which is causing the engine oil pan to sag down. That would cause the transaxle to be out of alignment relative to the half shafts connected to the wheels, and when you try to drive the car, a half shaft may be hitting something to cause the noise that you are hearing.
    valde3 likes this.
  11. 48mpg
    48mpg Member
    193
    46
    florida
    I
    never seen that before..looks like a mounting bracket failed ..maybe Toyota will absorb some of the cost if you contact customer care..( im sure their toll free number is somewhere on line)
  12. Beccajaya
    Thanks! That's what we will do first thing Monday.
  13. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    BTW: I'm sure, Patrick meant flat-bed rather than tow! Good luck!
    Jees! ...an ancient post! ...almost as old as me!!! ...apols!
  14. Mendel Leisk
    38,893
    Yeah likely all sorted by now, but would there be any harm in towing, with front end in the air? I'm thinking it's ok.
  15. WilDavis
    2,492
    2,153
    49
    True, but I'd rather be safe than sorry!!!
