What gas do you put in your Prius Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by charliebrownsprius, Dec 22, 2020.
  1. charliebrownsprius
    charliebrownsprius New Member
    17
    2020 Prius Prime
    It's nearly time for us to fill the tank on our 2020 Prius Prime plugin in hybrid. In my neighbourhood, we have access to regular, mid-grade and premium gasoline.
    What grade of gasoline would you put in the car and why?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Mendel Leisk, MTN and TGrracie like this.
  3. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    Regular top tier, usually Arco.
    TGrracie likes this.
  4. eatriceyo
    eatriceyo Member
    45
    32
    Honolulu
    regular 87 from costco
  5. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Wait a minute. I have had my Prime for almost 4 years and now you are telling me it also uses gas???
    lbligh, phlack, rickd24 and 9 others like this.
  6. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Charlie, there is no benefit in any engine to using a higher Antiknock Index (AKI) gasoline that the engine maker specifies. 87 is spec'ed, and 87 works fine. There is no detriment to using higher AKI gasoline other than the cost. There are perpetual discussions about the wisdom or not of using gasoline without ethanol. Most of us use E10 (10% ethanol) 87 AKI gasoline with good results.
    Ethanol increases deterioration in old engines where the fuel system elastomers aren't adequate for ethanol. All modern engines are fine. Ethanol blended gasoline will hold more water in suspension, and in some small engines...lawnmowers, etc...in storage for months that can cause problems. Modern cars with sealed fuel systems don't have those problems. Ethanol has fewer BTUs per gallon, so there is a slight hit to gas consumption. Ethanol is the cheapest, least toxic way to increase the octane rating.
    Top Tier gasoline contains additives that exceed the minimum required by the regulators. It is wise to use it. Here's more: https://www.toptiergas.com/licensed-brands/
    ETP, jerrymildred and TGrracie like this.
  7. dbstoo
    dbstoo Senior Member
    1,331
    707
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I typically use Chevron Regular. Occasionally I'll use Shell or Costco instead.
    My typical driving pattern is to drive 3 to 20 miles a day, but once a month drive around 1000 miles. Depending on your driving pattern, it might be worthwhile to add Stabil gas stabilizer. :) I topped off my gas tank on the way home from one of those long trips last winter. I realized in October / November that I'd used NONE of it. I have since deliberately forced the car into hybrid mode to use up enough to add fresh gas. When I top it off this time I'll add Stabil, just like I do for my emergency generator.
    Dan
  8. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    same
    Arco near my house is normally mobbed, so about 1 in 4 tanks ends up being Chevron/Shell at 30% more (gasp) but feel I'm hedging my bets to get some Techron or whatever from truly top tier.
    Liz Waters likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Hmm. It's been a while. Gotta think back to August. Just kidding. I always use 87. As said before, there's no benefit to using a higher octane than called for in the manual.
    Hicksite likes this.
  10. OptimalPrime
    OptimalPrime Member
    107
    74
    Keene/Nashua
    I hate making a fool of myself, and if someone else wrote what I'm about to write, without my having had the same experience personally, I'd be skeptical at best.
    In my normal driving, whether local or highway, whether pre-COVID or now, I routinely use 87 octane. Pumps around here (New England) don't specify ethanol level, just the maximum allowable ethanol level "up to 10%". I'm pretty sure it's hit or miss as far as what percentage of ethanol is in 87 octane here, or any octane for that matter, though my impression that 89 octane is the most likely to contain much of it. The few times I've used 91 octane, no noticeable effect on mpg in New England driving.
    However, on long cross-country road trips, typically covering up to 1000 miles per day mostly at 84mph on cruise control, (or 74, 79, 89, or 94, depending upon what state I'm in) I have found that I get considerably better (say 8-10% better) mpg using 91 octane. It's not a placebo effect, as I was never expecting that, and certainly not hoping for it. All I can figure is that at higher throttle settings when fully warmed up, or perhaps when at higher altitude than I live at, the computer can get to some better timing/oxygen/lean-mixture points on the performance map that it can't get to without knock on 87 octane. Or that states out west simply don't put ethanol in premium gas, and I'm getting the higher energy density also. In any case, I'm a cheapskate driving near sea level at home, but you'll never catch me with less than 50% of the gas in my tank being 91 octane or higher when out west. I avoid 89 octane anywhere that doesn't specifically label it as the only E0 choice, figuring it's probably 87 with ethanol added.
    Maybe a little bit of it is psychological, not wanting to risk knock when turning off the cruise and doing more spirited big-mountain driving than I get to do at home. But in any case, I won't put 87 into an empty tank when driving the car hard, though I'll top up with it if stopping for food with a half tank of 91 in there, at a place where premium is unusually expensive.
    I realize this is anecdotal and hand-waving, but on vacation I don't feel like doing an engineering study to prove or disprove even my own anecdotes, despite being an engineer.
  11. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    87 octane usually 6-7 times in row, then once in awhile I’ll fill with 93.
    Also, I’ve found my fuel efficiency
    improves perhaps 3-6MPG when filling with 93 octane. Whether or not that’s worth $2.58 a gallon vs $2.92 a gallon is debatable.
    #11 Storm88000, Dec 26, 2020
  12. plug-one-in
    plug-one-in Junior Member
    24
    29
    usa
    2015 Nissan LEAF
    that is pretty good. I will try this 91 octane next time I pump gas.
  13. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    What jerrymildred said.
    jerrymildred likes this.
  14. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    I have found that 3 of the Prii that I have owned had significant problems when getting going in cold temperatures (about 20 degrees F or lower). The car doesn't accelerate and it sounds like you're ruining the engine. The problem goes away when the engine heats up.
    This happens in my 18 prime and the 15v and also happened in my 15 II. I didn't have any issues of this sort that I can remember with my 11 II.
    Topping off the tank with "Hi Test" seems to solve the problem, so we run some premium fuel in the cars during the cold weather.
  15. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    On a recent drive up a long incline at around 20° F. I noticed what sounded like preignition knock when trying to accelerate. It stopped when I backed off the accelerator.
    I thought the knock sensor would prevent this. Maybe I got a tank of substandard gas?
    In this case I'll try some high octane fuel to see if this goes away.
    Anyone else experience this?
  16. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Gen1 PIP, so Prime-wanna-be here, but I'll respond since I didn't see that anyone else mention this. 87 octane and always ethanol-free if possible. Fortunately the closest gas station to us, less than half mile away, only sells ethanol-free.
  17. Gokhan
    Gokhan Senior Member
    4,656
    1,866
    Paramount CA
    The dealer fill was generic 87-octane. Currently I have Chevron with Techron® 87-octane. The next (third) fill could be Mobil Synergy Supreme+™ 91-octane. The octane ratings are 87, 89, and 91 here. The ethanol content, which is an mpg-robber, is apparently typically 10% here.
  18. SciRunner
    SciRunner Junior Member
    48
    23
    Charm City, USA
    Shell 87 or any top tier 87. I avoid non top-tier gas as previous cars always seem sluggish to move. I also avoid getting gas from New Jersey since some attendants continue to pump after the automatic fill closes.
    TGrracie and Gokhan like this.
  19. Gokhan
    4,656
    1,866
    Paramount CA
    LOL Should I avoid New Jersey altogether? I've never been there. Is it any different than New York, which I've never been to either?
    Also, do you have attendants filling gas over there? I've never seen any in California or any other state I've been to.
  20. Salamander_King
    10,975
    8,868
    New England
    NJ does not allow self serve. You are at the mercy of the attendant to stop the pump at the auto-stop.
    Gokhan and jerrymildred like this.
