What happens on August 24th?
Discussion in 'EV (Electric Vehicle) Discussion' started by Leadfoot J. McCoalroller, Jul 14, 2018.
  1. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    My understanding is that Elon is "all in" on lithium, including the Semi and model P(ickup).
    52,862
    how much more volume is the gen 4 prius with nimh vs lithium?
  3. Trollbait
    12,831
    Li-ion has the cost advantage along with the energy density. NiMH handles cold better, so it might work for niche products; electric snow machines.
    Space? doesn't make a difference since they are both under the seat, though Toyota could put a larger Li-ion there if they chose.
    Sales? don't know; need sales figures broken down by trim.
    52,862
    sorry, someone mentioned that lithium was more compact than nimh.
  5. Trollbait
    12,831
    It is, but it doesn't make a difference to the car owner in terms of usable space, because the space under the rear seat isn't usable space. The Li-ion takes up less space there than the NiMH for two reasons. The first is because of higher energy density, and the second is that it requires a smaller amount of buffer capacity, so the overall capacity is smaller.
    If you did make it so you could use the under seat space for storage, then you could put a few more things under there with the Li-ion pack than with the NiMH one. However, this is just a hybrid with a tiny battery. For a plug in, the difference in pack size will be more pronounced, more likely it will be seen in the EV range. When the EV1 went from lead-acid to NiMH, GM didn't limit the NiMH capacity to that of the original battery, they increased it because they could fit more of it into the space occupied by the 12 volts.
    If were to replace a BEV of today's Li-ion battery with NiMH, you would end up with less range, or lose car space for the physically larger battery.
    Sapphire Dragon, el Crucero and bisco like this.
