What HAVE TO do for Prime with 100K
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by DeeHaa, Aug 8, 2019.
Tags:
  1. DeeHaa
    DeeHaa Junior Member
    Hi Everyone,
    What I must do (or strongly recommend to do) with my Prius Prime 2017 with 100K miles on it ?
    Currently, everything looks and sounds fine. I do oil change+rotate every 10k miles.
    thanks,
    52,657
    you should be checking/cleaning/replacing cabin and air filters every 15 and 30k.
    brake and other inspections every 5k, and complete brake inspection every 30k.
    look in the maintenance schedule that came with the car for when fluid changes and spark plugs are due.
    maybe add a tranny fluid change
    Arctic_White likes this.
  3. DeeHaa
    Found it.
    Arctic_White and bisco like this.
  4. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I would just follow the MX schedule in the book.
    In addition to the above cabin air filter/oil schedule... the book says to replace coolant for engine and inverter at 100k. Spark plugs at the 120k point.
    I did all of that and more on my 2010 at the same time at 100k. Felt like turning it into a "Prius Day". Not sure how to replace the plugs on the Prime, but I had to take the wipers, wiper motor, and tray out to get to them on my 2010.
    Underneath the car I did oil, engine coolant (super easy), inverter coolant (mine was difficult because the bottom bolt was rusted and the 10mm hex wouldnt fit in there without "persuasion"). I bought a new bolt ($5) to replace the "persuaded" bolt with. I also did the transmission fluid because why not, and I had it exposed and then for good measure did the PCV valve.
    #4 Tha_Ape, Aug 8, 2019
  5. bisco
    52,657
    don't forget the floor mats :ROFLMAO:
  6. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Wow...100K! You very well might be the first one around here that has made it that far. Did you run into any problems along the way? If not, that is a very good sign!
    Arctic_White and jerrymildred like this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Welcome to PC. Yeah, you might be the first 100K milestone PRIME.
    Are you the original owner? Had to be driving well over 40K/year to reach at 100K mark by now. How is your battery holding up for the charge? I know it's not so much of milage, but years, but still I am interested in if you see any degradation. I see absolutely no sign of battery degradation on my 2017 PRIME with 32K.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Where in the us of a are you located?
    I’d be curious to know what the egr circuit looks like ;).
    If out in the Bay Area of California, I’d be willing to help:).
    Good luck with the maintenance and continued mileage growth on your Prime (y).
    Arctic_White and Prius from Dad like this.
  9. DeeHaa
    Thanks.
    No. So far, I don't have any problem with mine.
    I am the original owner. Long way commute to work everyday. The battery is pretty good, it can hold up to 35+ miles per charge now (increase more than original holding). Other than that, everything is running good. Thanks for asking.
    Hi Bisco, Why 'floor mats' ?
    #9 DeeHaa, Aug 12, 2019
  10. bisco
    52,657
    inside joke,
    it's part of the maintenance protocol. goes back 10 or 15 years when people thought the floor mat was riding up under the accelerator pedal and causing it to catch the pedal at full throttle. (never happened)
    ever since then, even though toyota added clips to hold the floor mats, it has been on the very 5k inspection
    Arctic_White and noonm like this.
  11. DeeHaa
    :eek:
