What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Awesome, thanks. That'll give me something to do today.
    djdawn likes this.
  2. mrpinkie
    mrpinkie Junior Member
    31
    North Carolina
    2015 Prius c
    I finally debadged the rear hatch. Had to get some 3M adhesive remover to get the foam double sided tape off. That stuff was no joke. I used the dental floss method and managed to separate the badges from the foam, leaving all of the sticky foam on the car.:mad: I want to black out both the front and rear Toyota emblems but the rear one is attached with the same double sided tape. So I did the front today, and I will come up with a plan for the rear one. I used black Plasti-Dip and carbon fiber "look" vinyl, and I am really happy with how it turned out. 20151129_134628.jpg 20151129_134558.jpg
    AQUA-K, orenji and djdawn like this.
  3. mertechperformance
    532
    126
    Nor-caL
    Next time use a heat gun little to no residue will stay attached to the car.
    orenji likes this.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Did you paint hatch wing black, or has it always been black?
  5. mertechperformance
    532
    126
    Nor-caL
    Painted it. Didn't know if I wanted to go panda with it or paint match. I like it black so far. Just plasti dip
  6. orenji
    5,887
    3,488
    I am thinking about one still.......:) I just wish the Toyota emblem could be viewed.
  7. mrpinkie
    31
    North Carolina
    2015 Prius c
    I started using a heat gun, and decided to stop. When I pull the rear Toyota emblem I will use the heat gun to get it off. I was pretty annoyed to find out it was attached with double sided tape and not clipped on like the front is. But this may have to wait until it gets warmer, winter seems to have set in around here so temps are too low to paint outside.
  8. mertechperformance
    532
    126
    Nor-caL
    Annoyed? Lol. Taped on rear emblem isn't much to get annoyed about. It's SIGNIFICANTLY better than holes. As holes require lots of money, time and paint to fill. I'm THOROUGHLY annoyed they used locating holes on the front fenders for the hybrid badging...
    #768 mertechperformance, Dec 4, 2015
  9. orenji
    5,887
    3,488
    With the triple digit speeds the C can obtain, the holes/clips make sure the emblems are secure. ;)
  10. mertechperformance
    532
    126
    Nor-caL
    There are no clips... and yeah. You do know the prius c CAN best 100 mph right?
  11. orenji
    5,887
    3,488
    Clips as in the attachment prongs. Yes, I do know it can exceed 100 mph.
  12. mertechperformance
    532
    126
    Nor-caL
    Fender emblems do not have any clips or prongs. Just bits of plastic that protrude into the fender they do nothing to attach. But seriously I so wish I could have no emblems on them but g's emblems I sprung for as still significantly cheaper than fill and paint.
  13. orenji
    5,887
    3,488
    I have the hybrid and G's emblems....
    Prongs,clips, bits of plastic.....whatever you want to call it.
  14. mertechperformance
    532
    126
    Nor-caL
    Same here. Neither has prongs to hold them in. Just plastic pegs that fit loosely in the fender locating holes. Damn toyota.
    SM-N910T ?
  15. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    I had to make use of the circular blank on my C1 that higher trims use for the start button.
    Got one of these:
    Took it apart to separate the goose neck section from the base. One screw at the bottom of the base, then two small screws to separate the goose neck section. Removed the circular blank from the dash and drilled a hole in the middle. Used some hardware to secure the goose neck base to the blank.
    The pictures show the shorter goose neck version of the phone holder. I later ordered the longer neck version, but is installed the same way, so the pictures are still appropriate. The final pictures are of the final project. I needed the extra length so that my steering wheel doesn't block the phone and the wiper switch doesn't hit the phone.
    [​IMG]Untitled by tk_1971, on Flickr
    [​IMG]_DSC0483 by tk_1971, on Flickr
    #775 tk1971, Dec 16, 2015
  16. apriush
    apriush New Member
    CA
    2015 Prius c
    Bought black seat covers
  17. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    just got done installin my gauges, it took a lil bit longer then what i inspected !!
    that was the wrong pic
    Blindhopes likes this.
  18. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    You disabled the side curtain airbag in the A-pillar?
  19. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    nope
  20. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    What did you setup your gauges to monitor?
