What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    Jealous!! :D
    Sir Drives Alot and ztanos like this.
  2. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Finished the right side tail light retrofit.
    For those interested, this is an exact fit for 2016 and prior so no mods are necessary, however you do need to replace the wiring hardness as well as purchase the parking light LED and the brake LED module, which is no longer integrated into the light assembly. Expensive, I know, but if you gotta have it, here are the part numbers and my cost from Tustin Toyota:
    -- PER SIDE --
    (1X)
    8155552D50 $ 28.52 SOCKET & WIRE SUB-ASSEMBLY
    (2X)
    8153652D50 $ 49.92 LED, REAR COMBINATION LAMP
    (1X)
    8155152D60 $ 114.91 LENS & BODY, REAR COMBINATION LAMP, RIGHT
    or
    8156152D60 $ 114.91 LENS & BODY, REAR COMBINATION LAMP, LEFT
    I also changed the low-beam headlights to LEDs:
    STLmayor, Ikarus, audiodave and 4 others like this.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    What LEDs did you use for the headlights?
  4. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    E589D968-F628-44D4-A0C3-33CFEEFAEF76.jpeg Installed my screwdriver shift knob from japan and got bored so I cut up a crown royal bag to make a shift boot.
    michael.sfo and ztanos like this.
  5. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    That is very original! lol
    ztanos likes this.
  6. Christophers
    269
    105
    Honolulu
    2015 Prius c
  7. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Supernova V.4 LED Headlights, H11 / H16 Bulbs
    These use the latest Cree chips, so they're more expensive than the typical eBay or Amazon varieties. IMO, both color/temperature and brightness is comparable to a 50W HID, and there's no yellow margins, and it has crisp cut-off, and of course instant on-off. High beams are next, but they're back-ordered right now.
    ztanos likes this.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I'm getting tired of my HIDs... I've had a bad batch the last few bulbs. My first bulb lasted me 5 years (moved from my last car) and 100k miles. This ballast and bulb set didn't even make 10k miles... :( LEDS run hotter than factory bulbs?
  9. michael.sfo
    michael.sfo Member
    52
    42
    San Francisco
    2015 Prius c
    I love this! Did you have to remove the position indicator housing?
  10. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Not if they're working properly. With incadesent bulbs, including the OEM H11 halogens, all the heat comes out the front, i.e. the filament, in the form of IR. With LEDs, all the heat comes out of the back of the LED chip. The heat sink transfers this heat to the back of the module, where a small fan dissipates it to the ambient air. If that fan fails, the LED will fail soon, so you do have to keep it clean, and cover it if you're going to wash the engine bay.
    ztanos likes this.
  11. Leadfoot J. McCoalroller
    8,232
    7,735
    Pennsylvania
    2018 Prius c
    Winter tires. 4 new 175/70R14 General Altimax Arctic on a set of 14" rims I had left over from another car. They fit great and ride well. Hoping the traction is everything claimed.
  12. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    hmm - while I like the LED's my C came with, if they fail, I'm converting to regular ol' halogens. Seems everyone has
    Question for you: Being those tires are an inch shorter, did you have to adjust the computer to account for the difference?
  13. Leadfoot J. McCoalroller
    8,232
    7,735
    Pennsylvania
    2018 Prius c
    It's not that much smaller. Stock is 24" diameter, these are 23.6". Original is 842 revs per mile, new is 853. It doesn't get much closer without actually matching. A 185 would have been closer to diameter, but the width would have gone up a lot.
    dubit likes this.
  14. Christophers
    269
    105
    Honolulu
    2015 Prius c
    78E18936-89EE-41A5-B90E-A246B101D63B.jpeg 9F2C8726-447E-401A-9E83-F9E0CEC73F89.jpeg Installed my ion interior thing. Since I’m a cook and my car kept smelling like work.
    TheBippi likes this.
  15. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Interesting. Did you buy this locally in Hawaii? I don't suppose you (or anyone) can translate at least the brand name so I can see if it's available elsewhere. Or is this an actual Toyota accessory? And more importantly - how well does it work?
  16. Christophers
    269
    105
    Honolulu
    2015 Prius c
    I got this in japan. This is universal toyota accessory that you can buy at any car place up there (super autobacs). The brand name is yac same as the japan cup holders or accessories for our car. It actually works pretty well my car doesn’t smell like a kitchen anymore so far.
  17. rjdriver
    411
    172
    Rhode Island
    Thanks. After a brief search, I think that's going to be a difficult find here on the mainland. Will keep looking.
  18. Christophers
    269
    105
    Honolulu
    2015 Prius c
    Installed the valenti super slim drl also led under the head lights that’s I got from japan. Decided not to sell the drl and just throw it on. The led under the head lights I got a 8 click switch the changes the brightness of the led.
    #1278 Christophers, Nov 25, 2018
    dubit and audiodave like this.
  19. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    I keep my tire pressures at 40psi for better economy. I think many do. I drive on rubber that is more grippy in both dry and wet conditions, and has a more aggressive thread pattern than the OEMs, so safety is not an issue. However, just about every time I take her to the dealer for an oil & filter change, even though I specifically tell the SM not to do it, the grease monkey dude deflates my tires down to 30psi. To combat this oil conglomerate conspiracy, I found these "child-proof" caps on Amazon. Let's see if my attempt at reverse child psychology bears any fruit. I wish instead of TRD, it said "DON'T ******* touch this!", but then again, if the grease monkey dude could read, he would have read the service request. which clearly says not to mess with the tire pressures. Ayyyayyay!
    michael.sfo likes this.
  20. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    That's one way to do it I suppose. But should you lose traction in a wet weather situation, this post is not going to help you in any lawsuit a money hungry attorney is going to try get for your injuries and/or loss of property. :LOL:
