What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    No disassembly was nevessary. 2013 and 2018 harness end-plugs are identical. You just have to peel back the cargo area inside plastic cover to get at the point where the harness plugs in. Wear gloves so you don't slash your hands like I did. That was the hardest part. The rest was a slam dunk. And as mentioned, you'll need 2 red LED modules: per, one for the brakes, and one for the parking light. I don't have pictures of the assembly, but if anyone really needs it, I can take it apart and snap some.
    Anyone want my old taillights? They're in perfect condition.
    #1301 frenzee, Jan 6, 2019
  2. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    DDEAFC1A-67AB-45F9-94CB-5996885D97CD.jpeg C2A0D0AA-C567-4471-923D-EF6BF63ECC04.jpeg I installed blue anti glare side mirror glass.
  3. Christophers
    269
    105
    Honolulu
    2015 Prius c
    A8844AEF-F6C4-4294-8554-BB87DB5CE149.jpeg D64BC32A-9220-404B-BA81-16F6DDFD1F19.jpeg Since I put after market fogs from eBay I have had issues with the lens with moisture. So I ordered Morimoto fogs. Yeah there’s a slight gap compared to the eBay ones since it’s a universal fog. But I’m pleased on how it looks and the color since it’s close to stock.
    Brandon Most and dubit like this.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
  5. Edwin B Batacan
    Edwin B Batacan New Member
    Las Vegas / Chicago
    2014 Prius c
    Only a few mods. But will replace with an OEM rims/tires later and lower the car.
    Current mods, LED headlights, LED License Plate light, Blaupunkt Navi (Cheap Navi), LED Domelight.
    dubit likes this.
  6. Christophers
    269
    105
    Honolulu
    2015 Prius c
    I go to japan yearly and I have Prius c (aqua) owners as friends up there as well who send me parts.
    I do have parts that just chilling in my house where I’m not going to put it on my car if people are interested.
    #1306 Christophers, Feb 4, 2019
  7. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    I got my windows tinted today. 50% up front and 20% in the rear. A little more privacy and security. The dog likes it too.
  8. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    I was tinkering around inside the car and decided to add a little bit of additional mass to the door panel. This will give it a more substantial feeling and reduce any unwanted vibrations from the speakers. A little goes a long way.
    Looking at the design the plastics are pretty thin and there are 3 pieces of thinsulate type material for noise reduction. In comparison, I think my previous Rav4 had a larger section of only jute padding. The thinsulate is lighter and I believe more effective.
  9. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    Today it was sunny and I had some time to pull the rear door panel. Inside is some jute padding instead of the thinsulate type up front. I noticed there was no door edge foam gasket. Does anyone know where to source some factory style foam gasket? I have speaker surround foam but it doesn't compress like the oem stuff. The factory type is either really soft or squishy foam. Also discovered what appears to be a fabric covered honey comb style sound absorber. I didn't bother adding any extra mass on the rear panel since nobody sits back there and the volume output seems to be less than the front.
  10. Leadfoot J. McCoalroller
    8,157
    7,661
    Pennsylvania
    2018 Prius c
    I think that honeycomb is a crash gasket. If somebody T-bones you, the force goes into the reinforced battery cage instead of deforming the door (as much).
    will the engineer likes this.
  11. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    Here is the Kagu (maxpider) rear floor mat. Nothing wrong with the OEM 2 piece rear floor liners but they were a bit thicker in spots and probably weighted twice as much as the Kagu. Keeping the OEM ones up front for the durability.
    Edwin B Batacan likes this.
  12. Edwin B Batacan
    Las Vegas / Chicago
    2014 Prius c
    Where did u buy it and how much did u pay for it?
  13. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    I purchased it off of Autoanything using one of their promotional discounts combined with an intro-tech sun visor. The 3D Maxpider Kagu floor mat rear only is 64.69. You might be able to find it cheaper on eBay "make an offer".
  14. Augie Doggie
    Augie Doggie Junior Member
    Palookaville
    2015 Prius c
    Looks good! I'll be getting this exact same thing done in the near future.
    CoolPrius likes this.
  15. Augie Doggie
    Palookaville
    2015 Prius c
    Replaced my 12V battery. These suckers are expensive!! :eek:
  16. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    IMG_2826.jpg Today I swapped the standard halogen H11 bulbs in the fog lights for Philips CrystalVision Ultra H11s I had laying around after I upgraded the headlights low beams to LEDs. They are whiter but probably not worth it over quality LED bulbs.
    dubit and CoolPrius like this.
  17. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    Picked up the Prius C rubber storage mats in blue on eBay. I couldn't locate if a Left Hand Drive set was available, looks like only the overseas Right Hand Drive (no armrest Aqua) set is produced. No a huge deal but would have been nice. I'll likely use the ones that don't fit as a template and try to do something custom. If you just want a OEM cup holder liner then part 58817-42010 (bottom image) or similar would also work but the whole Chinese set it cheaper. Here is mine after I washed them.
    I was thinking of a good material to use for a DIY console and upper glove box liner. Anyone have any ideas? I first thought of a felt like material but anything with an adhesive backing might get sticky in the summer time. Maybe cork, drawer liner or some kind of textured rubber. Something to jazz it up a bit visually would be cool.
    PCSpaceShip likes this.
  18. Edwin B Batacan
    Las Vegas / Chicago
    2014 Prius c
    Tinted the whole front windshield 70%, I know it's not legal, but I had it on my BMW for 2 years w/o any problems, ill take my chances again.
  19. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    CoolPrius - yes, do the one with the lightsaber!!
  20. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I like shiny things....
