What I don't like about the 2016 Prius
Discussion in 'Gen 4 Prius Main Forum' started by cproaudio, Sep 9, 2015.
  1. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Perhaps you saw one without the "Touring Grade Unique Rear Bumper Treatment".
    KrPtNk and krmcg like this.
  2. tzx4
    tzx4 Active Member
    164
    148
    Here are three nits to pick.
    1. The cruise control pops up a window that is all graphics with small print at the bottom showing the speed that is selected. Turns out this window and the speedometer do not agree. The cruise control window is 1MPH higher than the speedometer. (roll eyes) I wish I could make it go away as they allow with the instructional window that pops up every time the cruise control is turned on.
    2. The headlights are nowhere near as good as the ones on my 2013 Prius c I traded in. The difference between low and high beams is apparently little mechanical shutters that block the upper half of the high beam to keep it from blasting oncoming drivers with full intensify light. Sorry Toyota, but when I drive over a gentle rise or hilltop, that full intensity "low beam" is shining right in oncoming driver's faces. I have already had a couple blink their brights at me in this situation. Adding insult to injury, the high beams are not as bright as the dedicated ones in the '13 Prius c.
    3. I miss the c's conventional gear shifter and hand pull parking brake. Far simpler, and intuitive than pressing a separate button for park and pushing a foot pedal for the parking brake.
  3. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    Whoever uses a parking break? I actually like the parking break on the floor mostly because my last car had a pull one and I found the location to be annoying and I can probably count on 1 hand how many times I used it.
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Things I don't like about my 2016 Prius Four w/ ATP and PCP:
    1.) The steering is too light. My 05 Prius drives much better on the freeway because the steering is heavier. The 2016 moves side to side on the freeway with the crosswinds.
    2.)The steering wheel is three spokes. I like to set my hand on 6 o'clock and leave it there. Now i set my hand on 5 o'clock.
    3.)The rear seat is much smaller than my 05 Prius and is much less comfortable, but the cargo space is bigger.
    4.) I would have liked to have gotten the Four Touring, but it doesn't come with the sunroof and HUD. I would have liked to have the nicer bumpers (fog lights), wheels, and handling.
    5.) The front and rear seats are not as comfortable as I would have liked.
    6.) There is no dual zone climate control, no power passenger seat, and no cooled seats.
    7.) The sun visors are designed terribly. The visors are almost as tall as they are wide.
    8.) Sending text messages works with an iPhone 5s but not an iPhone 6. There is no Apple CarPlay or Android Auto.
    9.) The voice commands still don't work well even after the voice set up.
    10.) The Prius isn't available with full leather seating and the center console is too small.
    TonyWilkey likes this.
  5. PeterKG
    PeterKG Member
    62
    79
    Playa Vista, CA
    Four Touring
    Every time I drive mine I marvel how Toyota managed to make every bit of the car new and better than the old Gen 2/3, and they succeeded IMO. You actually drive it and long for the ride and featureless 11 year OLD version, and complain about features you know the 2016 didn't have when you bought or leased it. I don't get it at all.
    bisco and krmcg like this.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    So what's the Jack for when there's no spare tire to change?
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    To remove the flat for repair. A simple patch can quickly be done by a tire-shop without the need for a tow or driving with a donut.
  8. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    And that is doubtless super-handy when you get a flat tire in front of a tire-shop ;).
    krmcg and energyandair like this.
  9. cproaudio
    2,401
    762
    CA
    I have never seen a tow truck or a tire shop without industrial jacks. They won't ask to use the OEM jack.
  10. Tideland Prius
    16,678
    I think there's a setting in the SETTINGS menu to turn that DRCC screen off. Check with the owner's manual. I vaguely remember reading it (I don't have a 2016 so I can't test it for myself)
    I find it hard to believe that the LEDs aren't as good as the halogens on the 2013. That being said, the projector lens have gotten pretty good over the years. The Gen 3 has good low beam halogens (though that never stopped people from upgrading). It's too bad about the headlight aim setting. It's similar with the new Corolla. The LED low beams are just at the limit so a tiny bump with have them flicker or a loaded car will have it point up. The problem is that they're used as DRLs in Canada so every Corolla has those lights on by default. However, from the driver's seat, they're fantastic - surprising on a compact car. The previous gen Corolla had just barely adequate low beams.
    I use it all the time and have done so since I got my licence. It saves wear on the parking pawl and when you're in a hilly area, you want that parking brake to be the main source of resistance to hold the car and not the parking pawl on the transmission.
    krmcg likes this.
  11. john1701a
    12,840
    5,312
    58
    I've seen flats three times now on family members cars happen in the driveway. Two of the times there was no reason to bother with a spare. We just jacked up the vehicle and quick got the tire patched.
  12. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    Yeah if you park on a hill but I rarely have to do that.
  13. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    I have used the parking break in my Prius every time I have parked for over 9 years. Something about just pushing a button wasn't enough peace of mind for me. Stupid? Probably but it became a habit so much so that I didn't even realize I was doing it.
    krmcg likes this.
  14. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    [​IMG]I carry a kit with a tire inflator!
  15. ATHiker
    644
    560
    Massachusetts
    Four Touring
    What is the smaller tool in the lower right hand corner with the turquois band on it?
  16. bisco
    52,847
    epipen, in case you're allergic to flats.
    Merged .
    you actually have to jack up the car to use toyota's gunk and compressor. it's a really easy and pain free process. :rolleyes:
    #296 bisco, Feb 29, 2016
    breakfast and DtEW like this.
  17. ATHiker
    644
    560
    Massachusetts
    Four Touring
    I have used a compressor (without gunk) and Fix-a-Flat (with gunk) without jacking up the car. The one time with the compressor and the several times with the can worked wonderfully.
    Why would Toyota's compressor (which must always be used with gunk -- hate that) be any different?
  18. Mendel Leisk
    42,343
    Tread depth gauge. Cheap, good to have.
    ATHiker likes this.
  19. bisco
    52,847
    no idea, that's just the instructions. there's a video, if you can find it. the whole ordeal is excruciating. that's why i carry a spare.
  20. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Excellent point. Allow me to amend my earlier comment:
    And that is doubtless super-handy when you get a flat tire in front of a tire-shop or in your driveway :ROFLMAO:
    Thanks for the real answer to that one - and a reminder of what a swell solution a tire repair kit is :cry:
