What I don't like about the Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by cproaudio, Mar 23, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ...I wanna 6 kWhr Prime v wagon
    stephane and bisco like this.
    51,932
    they could probably bury 8 in the v without affecting storage.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    #203 Sergiospl, Apr 22, 2016
  4. DavidA
    2,345
    1,821
    Chicago western burbs
    Extremely unlikely. Possibly in Japan, as a high cost option. Won't happen in North America.
  5. Trollbait
    12,539
    Already an option on the PiP in Japan. Then next year's Mirai is supposed to get the PTD(the P is for power, don't say plug:cool:), but the Chademo EVSE needed for it to power your house might be nearly $10k.
    So, if we get a high power inverter(my Matrix had a low power 110v, single outlet one) on the Prime, expect it to be like a nav system. Much cheaper to go aftermarket than factory.
  6. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    What do you mean by this, no solar panel on roof of car?
    I'd rather do solar charging from home panel but maybe it could be tied in
  7. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    I wasn't aware that the Matrix had a low power outlet. What was its output? I think that the outlet available in Japan isn't very large, maybe under 1000 watts.
  8. bisco
    51,932
    i think it's a prime option in japan.
  9. Trollbait
    12,539
    Don't recall. It wasn't much, maybe enough for a laptop.
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Solar panel on the roof of the car is an option in Japan but not in the US. So is the DC fast charging option. For many of us, there's no option to charge at work. Having a solar panel on the roof can add at least 2-4 miles range in 8-9 hours of sitting in the sun. It's not a lot but it adds up. If you work double shift where you can get a full day of sun light, you could add 4-6 miles to the range.
    Gen 3's solar is rated at 215 watts using only half of the roof. Gen 4 is using the whole roof so it should be able to get at least 400 watts. If not, at least 300 watts. Lets say it's able to charge 1kw in 3 hours, That's 3 kw in a work day if you count the 1 hour lunch break. 3kw should get you 8-10 miles. Worst case it adds 4 miles to the range.
    wjtracy likes this.
  11. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    I guess we don't know the whole story yet, but my understanding is that there is no battery in the center console (though there might be some other components there); they're all either under the seat or in the trunk. Reading back through comments here the assessment seems to be that Toyota just didn't want that center seat occupied for some reason, not that they actually needed that space for anything. Whatever the reason, I'd agree they're not going to change it for this 2017 car, so it's going to have to compete as is.
  12. bisco
    51,932
    occupying the middle seat would have required more structural bracing underneath, so with a fifth person and the extra steal, mpg's wouldn't have matched the lift back.
    also the charger is under there, but i'm not sure how it affects it. maybe there's no room for cushioning and springs.
    they put a bigger charger in, so it would charge in the same amount of time as the pip.
    i'm not saying it couldn't be done, just don't know all the engineering it would have taken.
    from my point of view, it just wasn't a priority when laying out the new tgna chassis.
    #212 bisco, Apr 23, 2016
  13. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Yep, that's the main point. Starting with a new platform and a relatively clean sheet of paper, Toyota still neglected to design for plug-in models.
    Those guys just hate the grid unless it's being used for hydrogen cracking/refactoring. There's obviously something broken in their brains on this topic. I hope they snap out of it before too much longer.
  14. bisco
    51,932
    no biggie, i'm looking forward to bolt. i hope gm doesn't screw the pooch.
    retired4999 likes this.
  15. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I can't accept the explanation that a person sitting in the middle seat would have structural ramifications. Shame on Toyota if that is true. The new global platform is alleged to be the design for many variations of Toyota vehicles. The Prius can't be the heaviest and/or with the greatest load capacity.
    The best explanation I have heard is the added weight would require Toyota to move up to the next higher rated tire. (I am not the author of that theory) the person that suggested it, quoted load rating for various size tires. It sounded very plausible to me.
  16. Trollbait
    12,539
    Both explanations end with the same result; lower MPG. The weight one is probably the simplest one the convey to consumers.
  17. bisco
    51,932
    it's obvious to me that toyota did not design the chassis with batteries and charger in mind, and everything is an afterthought.
    a toyota exec said they thought people would like a 4 seater, and if it doesn't work out, they can go back to 5 without much trouble. so i'm really confused at this point.
  18. Tideland Prius
    16,556
    At 1,530kg? It's most likely the heaviest vehicle to ride that chassis (unless it's somehow used for the Camry but I doubt it. The Camry will use its own TNGA platform. The Prius' will most likely share it with the Corolla. A Corolla will be in the 1,200kg range and will benefit from the lighter chassis used for a Prius in terms of fuel economy and overall weight.
    Designing a chassis for use with a heavier vehicle means more structural rigidity and therefore a greater weight unless extra cost was spent on lightweight materials. The Prius has a target mpg goal and weight is a big factor. Pretty easy to criticise, right?
  19. bisco
    51,932
    i think the issue is making a hybrid and phev out of the same vehicle. a better alternative might be a completely different vehicle, but that would require a belief in the future of that vehicle.
    Trollbait likes this.
  20. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Yes, quite easy, especially if this ridiculous compromise in utility was just to goose EPA-reported MPG/AER. The idea that the structure is cut so close to the bone that hauling a charger and extra batteries means they need to eliminate a passenger is hardly confidence-inspiring. I don't believe it, of course, and here's why:
    It's comments like these that put the lie to the whole "required for structural reasons" argument. This 4-seater nonsense is nothing but a stylistic affectation, and I think it both pretentious and ill-considered. People can keep defending it as reasonable, but in real life this is going to cost the Prime market points, because in real life it means less value for money, a concern that hangs over the entire Prime proposition.
    I think the Toyota folks have seriously misjudged what the Prime brings (or should bring) to the party. It's clear from the spokesdroids that Toyota perceives the Prime as being more about "cachet" than EV-ness, and I have trouble seeing how such silliness can bring even a shred of extra prestige to the Prius line. The sub-Volt bump in AER didn't disappoint me much, and indeed was outweighed by 50-state availability. What has annoyed me is the slathering on of "premium" touches consistent with the "gold-plated Prius" tone of the unveiling, making a competitive price seem unlikely, combined with the failure to maintain the PiP's advantages of uncompromised passenger and cargo space. The center console in the rear would bug me a lot less if the trunk hadn't also been hit with that raised floor.
    Felt and Trollbait like this.
