What I don't like about the Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by cproaudio, Mar 23, 2016.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Some insider notes on the 2017 Prius Prime | Page 2 | PriusChat
    I must have missed it. Can you show me where you got this information?
    In the Periscope walkthough video where the rear seat was shown at 8:40, the rear center console has a storage compartment that looks to have some depth to it. There's also 2 cup holders in front of the storage compartment. I still think that given the Prime is over 300lbs heavier than the regular Prius, they had to decrease seating capacity down to 4. It's possible that removing the rear seats would yield the same space as the regular Prius. I guess we'll find out when it's released and someone took apart the rear seats.
    #21 cproaudio, Mar 24, 2016
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    The only reason I'd get another Prius Plug In would be for the EV range. I'm hard pressed to get 10 miles EV range on my 2012. Twenty two miles EV is too low for a 2017 vehicle. Premium price for minimal EV range. Just don't see a market for the Prius Prime. A regular Prius, other EVs, or high mileage gas vehicles, or a used Gen 1 Prius Plug In at a steep discount are better choices.
    Bay Stater and Silver bullit like this.
  3. cproaudio
    2,401
    762
    CA
    In the Periscope video at 5:30 it shows a black tub but still has the white Darth Vader mouth and white base cap steering wheel.
    mrlebop likes this.
  4. cmth
    cmth Active Member
    279
    142
    UK
    The external design is certainly better than Liftback but I can see issue 1 (no 5th seat) affecting a big chunk of the market. As someone who was (unrealistically) waiting for NS4, I would say I am disappointed. However I am hoping some of the other tech in the Prius Prime will make it to other models like the C-HR.
    One thing I find difficult to understand is why buyers are overly critical of pure EV range. There are the nissan leafs and bmw i3s out there that can do that very well and cheaper. IMO the standout characteristic of the Prius Plugin is (and has always been) to be able get from A to B with minimal gas & emissions by using energy stored from external electricity. Let's say I have to commute daily 30 miles each way, I would not drive the Prius Prime on pure EV mode but the normal mode and what I anticipate is that the ICE will not do much work but it will come on from time to time to help. And waking up the ICE from time to time is a good thing because just as with any internal combustion engine, you would want the ICE to get a regular "exercise" to keep fit and efficient.
    I think it is actually the fault of Toyota failing to explain the main use-case (and benefit) of the Plugin so everyone keeps comparing it to other EVs out there.
    Bay Stater and Trollbait like this.
  5. MattNiem
    MattNiem Junior Member
    52
    Finland
    How is it possible that this PiP weighs 300 lbs more with such a small battery?
  6. inferno
    inferno Senior Member
    1,072
    405
    How much more does the 2nd Gen weight vs the 1st Gen?
    One thing that's slightly different is it has the same gas tank size as it's brethren unlike last gen. Don't know if that has anything to do with it.
    Raised floor bed is kind of disappointing. Would rather see 18 miles ev, 5 seats, flat bed and solar charging which could easily tour 2 miles recharge every 2 hours.
    Would've loved to see the charging meter on the screen at that point along with regen break. Imagine if trickle charge came to regular prius. It'd probably be 70+mpg
    Oh, and did someone say there was a spare tire in there?
  7. bisco
    52,888
    someone said it, but no confirmation. and where would they put it? why would they add a spare and raise the deck?
  8. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    Look at the ninth entry. It says 30 kg.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Can't be a spare tire in PiP2. Look at non-PiP, soon as a sunroof and power seats are added (weight), poof, there goes the spare tire. 8.x kWhr battery and its extra weight? No spare tire, plus nowhere to put it. But, needs to be confirmed.
  10. inferno
    1,072
    405
    I wasn't sure if the weight gain was verse 4th gen prius or PiP 1st.
  11. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I wouldn't be too concerned about the EV range,it is rated 50 km in Europe which would be roughly 30 miles in the US .
    The gen 4 Prius is ratet with 52 mpg but it can get way more as we already know !
    I am sure they could have done a better job with the rear cargo area though.
    Maybe they really couldn't make the battery smaller or devide it,but they could have at least redesigned the opening area so that the battery would have been flush with it instead of making it look like an amateur aftermarket solution .
    I remember that's the way the 3. gen Prius Plug-in looked at the first showing,but that wasn't a production model and they fixed that before it was officially launched .
    #31 civicdriver06, Mar 24, 2016
  12. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Battery, charger, Space & weight, they fixed last Gen by reducing 5 kwh to 4.4, now double that, purple line!
    #32 Sergiospl, Mar 24, 2016
  13. Trollbait
    12,832
    My first guess on the 4 seats was weight reasons.
    20 mileish is probably the best balance of range, ICE fuel economy, space, and price at this point. The Energi's got 20 miles 3 years ago, but with more cargo space loss, and a reduced MPG figure compared to the hybrid models. The Sonata PHEV has 27 miles, but is a larger platform with more space for stuff to begin with, and it is far from the Prius' fuel economy.
    Small? It's a 8.8kWh pack. That is roughly 8 times the size of the Li-ion one in the hybrid model.
  14. KrPtNk
    323
    283
    Pacific Northwest
    I think the 4 seating was because Toyota wants to position the Prius Prime and Mirai as their models that lead into the future. That point was made in the reveal's presentation. The Mirai is a four seater with an emphasis on comfort and luxury and so is the Prius Prime.
    For me two comfortable rear seats is preferable to the optional third seat. The further improvement in quietness is also a big plus as well as the ability to drive on battery alone. I like the looks. There are just a lot of reasons for me to be positive about the plug in. I think that the car is a major step in the right direction, at least it is from my perspective.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The only thing I don't like about The Prius Prime is that I live in an apartment building where nightly charging would be impossible. Thus making ownership of a plug in, something I can't realistically consider. Otherwise? I think it would be The Prius I would want.
  16. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Same for me. 5th seat (which would be without comfort anyway) or some inches lower floor are no issues for me. Plus I have 2000 kWh production more than I use per year. I am trying to compare upgrading to this one to keeping my 2013 PiP. Is there anybody who knows how maintenance cost increases with age of the car?
  17. Much More Better
    Much More Better Active Member
    655
    163
    I'm ok with the EV range. It works for me to go to work and back each day without relying on the ICE too much. I'm also ok with the 4 seat arrangement because I rarely carry passengers. I like the charge port where it is. What I'm unsure of is the "two-tiered" deck when seats are folded flat. I much prefer the flat deck of the Gen 3 and I'm sure Prius campers would agree.
    Ultimately, I don't think I can get over the styling and it's not worth going back to making car payments for. Front end is decent but rear is too polarizing. I also don't like the roof peak nearer the front, like Gen 2. The lower stance of the car also makes it a bit more treacherous in Cdn winters. I've never been stuck in my Gen 3 but close. No 17" rims in US so maybe not Cdn either. So that will be more cost. I love my Gen 3 Touring too much and it does nearly everything I've asked it to do.
    mrlebop likes this.
  18. bisco
    52,888
    you're unlikely to have any maintenance issues, at least up to 150,000 miles, unfortunately for you.:p
    mrlebop likes this.
  19. Jan Treur
    240
    168
    Heiloo, Netherlands
    Too bad, you slap one of my possible justifications out of my hands...
    So, I should focus more on the gain I can have by using my own cheap kWh's instead of the much more expensive ones at public chargers. And on the difference in remaining value of the car for the two options after 5 years (I am considering the period from 2017 to 2022).
    #39 Jan Treur, Mar 24, 2016
  20. bisco
    52,888
    it's a tough decision, and one that likely won't pay off in the short term, even with free kWh. can you sell them back to the power company?
