What I hate about the Prius
Discussion in 'Gen 3 Prius Main Forum' started by Tom183, Apr 21, 2010.
  1. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Sorry, but regeneration zero during hill descents, never would be approved by safety reasons. Everything else, as hypermilers would advocate, is bypassing this requirement.
    Prius is a car, to be driven by people, numb or else HV "understander", MUST in any case be prepared not to slide down hill.
    If so to, then the driver should take an option at his expense. It's up to the driver's choice.
  2. Tom183
    Tom183 New Member
    652
    65
    Maine
    Exactly... Most of the things I consider "dumb" are things they've done to "foolproof" the car. Designing to the lowest common denominator is a waste of good engineering...
    In this age of computerized everything, why can't we have CHOICE? Simply because some people still have VCR's flashing "12:00"?
  3. thbjr
    thbjr Member
    326
    63
    Phoenix
    The only thing I HATE is the ICE warm up phase. My trip to work is 13.5 miles each way. It takes about 25 minutes and of that the first 4-5 the ICE runs anytime the car is moving. I love the 65+ MPG I'm currently managing to squeeze out of it going back and forth to work, but with a pre-warmed engine, I can add another 15% to that MPG. I HATE loosing, no wasting, that much fuel to "warming up" an engine that is going to warn up eventually anyway...and even if it didn't, haven't I put less carbon into the atmosphere by the ICE running less total time?
    I think if someone came up with a hack to flash the computer so the ICE would always operate like it was in stage 5 of warm up, I'd be one of the 1st in line to get it.
    Tom
  4. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Get a block heater.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    To answer that question look no further than lawsuits. If products aren't dumbed down to the lowest possible level, companies get sued for operator's stupidity. Our overly litigious society has ruined many good things.
    Tom
  6. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    True, but Spiderman is in Alaska. His problem is most likely that the battery itself is too cold to allow EV mode. The reason is displayed on the dashboard display (multi-information display).
    The UK cars have had an EV button since Gen 2. The Gen 2 cars do not have a different speed limit for EV when the engine is cold. I believe the third-generation cars do. It may be that Toyota have decided to stop you running the battery down to nothing before attempting to start the engine, and discovering that it won't start.
    Our EV mode speed limit is 29mph for Gen 2 (US: 34mph if you fit an EV button) and 31mph for Gen 3 (US: 25mph).
    The thing I hate - apart from the damned touchscreen - is the NHTSA-mandated application of the brake pedal to a) turn on and b) shift out of Park. No European car has this mechanism, and it catches a lot of new drivers out.
  7. dogllama
    dogllama New Member
    118
    Los Angeles
    What is the legal difference between giving me the ability to make changes like turning off the reverse beep versus having the dealer do it?
  8. thbjr
    thbjr Member
    326
    63
    Phoenix
    First, it would do nothing for my trip home, where I loose mileage for the first 2 miles coasting down hill (Grrrr)...and wouldn't it just waist electricty on a car parked in a garage in Phoenix overnight...? This morning it was 61F in the garage:p
  9. qbee42
    18,058
    3,081
    Northern Michigan
    No legal difference, which is why some things are not configurable even by the dealer. For example, in the USA you can't disable the NAV lockout, and neither can the dealer. The reverse beep was user configurable for the Gen II in the USA. The process is rather convoluted, so switching to a dealer tool for the Gen III is probably a matter of convenience for Toyota, not a legal issue.
    Tom
  10. mwok86
    mwok86 New Member
    203
    16
    usa
    It's fragile. I drove with my brother in law in his Ford Escape Hybrid 2008...it was extremely rugged. The interior was plastic...but it was strong plastic. You could just slam the door and nothing would happen. If you slam the door on a Prius, it will fall apart/creak.
  11. Tom183
    Tom183 New Member
    652
    65
    Maine
    But it KNOWS how much battery you have - it's displayed right on the dash. So if you have a full battery, why can't it wait to start warm-up?
  12. Tom183
    Tom183 New Member
    652
    65
    Maine
    It has also protected us from dangerous products that regulators missed (or ignored).
    And while that might be justification for making the dumbest mode the default, it doesn't explain why choice is not allowed.
  13. dogllama
    dogllama New Member
    118
    Los Angeles
    When I was at the dealer for the 3rd time because they kept messing up the settings that I wanted changed, the head technician came out and changed them with me to get it right. He thought it was stupid that I couldn't change them myself and that he had to waste their time on my personal settings. I agreed.
    Seems pretty inconvenient to me.
  14. qbee42
    18,058
    3,081
    Northern Michigan
    Sure it does. Put yourself in the manufacturer's shoes: The surest and safest way to avoid a lawsuit is to make sure something never happens. In any lawsuit seeking damages, you always go for the deep pockets, which in this case is Toyota. They have a lot more money than any individual Prius owner. So say the owner of a Prius makes a dumb choice and decides to play with his Nav system while driving, and ends up killing a blind crippled kid being escorted by a nun. Who do you think will be the main target of the resulting lawsuit?
    I don't agree with it, but what I don't agree with is how our legal system works. And while I don't like it, I do understand why Toyota takes the sure way out and simply avoids options that may trigger lawsuits.
    Tom
  15. dogllama
    dogllama New Member
    118
    Los Angeles
    Best example EVER.
    (however I fail to see how this is any different than fooling with a radio dial 10 years ago. seems as if there should be a set of standards instead of a ridiculous guessing game.)
  16. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Good explanation to me. In the current Toyota environment, I understand this much better than I did a few months ago.
  17. qbee42
    18,058
    3,081
    Northern Michigan
    I agree completely. The application of this sort of nonsense seems capricious at best. I suspect it depends largely on which Toyota executive is making decisions at the time, with little regard to what makes sense.
    Tom
  18. Tideland Prius
    16,679
    Press DISPLAY. You'll see the settings for Brightness and Contrast as well as a SCREEN OFF option. If your headlights are on during the day, there will also be an additional button called DAY MODE. That's the button your dealer used.
    +1. Nearly everything on that customization list in the manual is adjustable by the driver in the HS250h, yet we have to take it to the dealer (and not every dealer is willing to do it, yet alone do it for free. They'll charge hourly rates)
    Like someone else said, get an EBH. If your garage is 61°F, it shouldn't take 5 mins to warm up. Now that it's warmer (daytime highs from 10°C-25°C (it was 25.. now 10 thanks to a cold front), it takes less than a minute before it shuts down.
    US: 10mph/25mph cold/warm thresholds
    Jpn: 20/31mph cold/warm thresholds.
    methinks your British model has the same 20mph lower limit. It makes it much more useable than 10mph.
    Must be a push-button start thing. Regular cars with keyed ignitions don't require brake pedal application AFAIK
  19. anneg2010
    anneg2010 New Member
    Columbia, MD
    Many thanks for the instructions. Will do.
  20. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Tideland Prius has the instructions correct. With the map up, press Display. Turn headlights on and a Daytime Mode tab will appear the top of the screen. Turn Daytime Mode to ON to keep the map in the white background mode with the headlights on.
    I went to check mine and could not get the Daytime Mode tab to come up even with the headlights on. I had to read the Nav manual and it states that if you have the instrument panel light wheel all of the way to the top, the Daytime Mode tab will not come up! I turned my instrument panel wheel off of the uppermost position and the Daytime Mode tab came back on.
    I prefer the white background to the black background. Some have said the light is too bright at night but it does not bother me.
