What if I push the power button while in motion?
Discussion in 'Gen 2 Prius Main Forum' started by exces6, Jul 8, 2005.
  1. exces6
    exces6 New Member
    97
    Houston, TX
    Does anyone know what would happen if someone pushed the power button while the car is moving?
    Thanks.
  2. IALTMANN
    IALTMANN New Member
    725
    Don't know, interesting question, just today someone asked me what would happen if PARK was pressed while the car was moving ahead.
    I would think if Toyota designed the car right, that in both cases NOTHING SHOULD HAPPEN. In a normal car, turning off the ignition cuts the engine, and yes some cars can be shifted out of the FWD gear on the AUTOmatics, but don't know if you could get past REV., you can go to Neutral, but not REV or Park, cause you can damage the transmission. Honnestly, I never tried it, I would not advise experimentation. Maybe someone can answer you or you can ask Toyota. The question about the Park button was asked of me because someone feared they would push it by mistake while the car was going ahead and fast...
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    [font=Comic Sans MS:6335d9097d]If you just press the power button quickly, like if you brushed it, nothing happens. If you press and hold you do an emergency shutdown (only do this in an emergency).
    Pressing Park while you're moving shifts into Neutral, I think. I haven't done it in a while. Shifting into Reverse while moving forward doesn't happen, you go to Neutral.
    Trust the Prius, Luke. It knows what it's doing. :mrgreen:[/font:6335d9097d]
  4. Tideland Prius
    16,155
    Unlike a regular car, the Prius is smart. In a normal car, shifting to Park or reverse will destroy your transmission. All the Prius does is, hey what the heck are you doing? <shifts to neutral instead>
  5. IALTMANN
    IALTMANN New Member
    725
    Though so., no way Toyota and Prius is gonna let you screw up!!
  6. NCPrius
    NCPrius Junior Member
    Charlotte, NC
    Pressing the "Power" and "Park" buttons simultaneously activates the Hyper Drive. Make sure you have your towel.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Are you confusing hyperDrive with Improbabiliy Drive? The former I believe you need a Wookie, the LATTER you need the towel.
  8. IALTMANN
    IALTMANN New Member
    725
    Hey do the wings come out when you press PWR and Park at the same time...need to get out of these trafic jams
  9. NCPrius
    Charlotte, NC
    <div class='quotetop'>QUOTE(DanMan32\";p=\"105468)</div>
    Man, I hate when I get my geek wires crossed.
  10. Arizona Charlie
    Arizona Charlie New Member
    55
    San Francisco
    Re: What if I push the park button while the car in motion?
    WHAT HAPPENS IF YOU ACCIDENTLY HIT ‘P’ THE PARK BUTTON WHILE DRIVING FASTER THAN 5 MPH?
    Absolutely Nothing. The engineers at Toyota figured that someone was bound to do it and they set the Pri up so that it will not go into park while you are driving the car.
    Do not try this if you are driving a PNDLR auto unless you need a new transmission and are planning to donate the car to Goodwill Industries.
    Do not hit the P button when driving at less than 5 MPH since the transmission will go into park mode and will cause transmission damage.
    Arizona Charlie
  11. Bill Merchant
    4,096
    81
    [font=Comic Sans MS:cb17b86ad6]Thanks for restating the previously stated, Charlie.[/font:cb17b86ad6]
