What if tow trucks carried tire plugs and could 'fix' (some) flats?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davekro, Dec 20, 2013.
  1. frodoz737
    frodoz737 Top Wrench
    4,699
    2,496
    33
    frodoz737 said:
    This argument is utter nonsense and anyone who does a "plug only" repair is either broke, ignorant or both. Out.​
    :( This type of statement lends nothing to a good discussion.
    :)2012 PriusPIA:D80%EV:cool:R3VOLTN
    Actually it is spot on. Broke..when you have little or no money, so even though know better your only option is cheapest. I can not help you there. Ignorant (not stupid) meaning you don't know no any better, as in "well they said it was alright on PriusChat, so it must be OK". Repair it right or not, but you have been educated on the proper methods per RMA and the Tire Mfgs...but what do they know.
    Wishing everyone a Merry Christmas.
  2. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Just as a thought, I'm not a terribly small guy (6' and 170 lbs) and I work out some / do yard work.
    I went to patch a tire a few years ago and the leak was over the steel belt. It took all I had in strength with 3 tools at my side to punch through the steel belt enough to be able to use the plug.
    That was with the tire off the vehicle as we couldn't find the leak until running water over it after pumping it up to pressure twice. I'm not sure if we had found the leak that I would have been able to find an angle to be able to apply the pressure while the tire was mounted because my effort with the tire off used a considerable amount of my body weight and if gravity wasn't assisting I don't think my arm strength alone would have pierced the steel belt.
    Did I mention the original leak site looked solid after pulling the metal out and I had to enlarge the hole before I could plug it? It doesn't take a large or even medium sized hole to let the air out but it takes at least a medium size hole to get the plug in.
    I felt like the plug was sufficient after I was done with the kit but it took me well over an hour, an air pump, a supply of water, the plug kit, taking the tire off the vehicle, gravity assist and all to get it done.
    I imagine the average roadside assistant / tow truck driver would rather drive the tire and/or car back to the shop to fix any tire that requires that much physical force to properly plug.
  3. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
  4. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Everyone should find and get the smaller (1/8") diameter plugs. They can be hard to come by. I found a Slime brand plug kit* that came with six. When they run out, I'll go to Ebay where I found a 100 pack for about $6 IIRC. On the hole my wife just learned how to plug on, on our Prius (at home, wheel on car), the normal plug would NOT go in. My procedure now is to try a regular plug (3/16"), but if it cannot be made to go in, toss that one and use the 1/8" plug. On my one tone box van a few years ago, I was unable to get the (standard sized) plug thru all those steel belts, so I had to use a cordless drill to make the hole big enough to accept the plug. That is the process that you are told to do, but I much prefer to 'KEEP' the smaller hole and use a smaller plug! ;)
    (Frodoz, your disgust at this repair is already duly noted. We'll agree to disagree as noted before on how highly or not to regard the letter of the law in this instance. I think most people support the idea of speed limits, but not the idea that going 3-5 mph over will immanently be the sole cause of their or anyone else's death (like a plugged tired would :rolleyes: )
    *Slime "11 piece Deluxe Tire Plug Kit" (Walmart and Amazon $5.97)
  5. frodoz737
    4,699
    2,496
    33
    "(Frodoz, your disgust at this repair is already duly noted. We'll agree to disagree as noted before on how highly or not to regard the letter of the law in this instance. I think most people support the idea of speed limits, but not the idea that going 3-5 mph over will immanently be the sole cause of their or anyone else's death (like a plugged tired would :rolleyes: )"
    My apologies as my intent was not to express "disgust"with improper repair. My intent is towards safety. I have seen the results of to much shade-tree maintenance over the decades, property and personal. Though my practices my seem anal by the standards of a non-mechanic, you need people like me to help assure safety and honesty within a trade that is sometimes marred with disingenuous financial motivation, both ways.
    Again my apologies, especially during the holiday season, but I practice what I preach and what I preach here is correct.
    Merry Christmas :) Out.
  6. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I can appreciate that you must see some hum dingers cross your path when some DIY selfer's have royally messed up their (or other's) vehicles. Being a certified (that may be certifiable ;) ) anal retentive, I choose to do most of my own auto repair to avoid the occasional oversight in a repair by a shop as not all take the pride in their work that you do. Besides, I have the time to spend twice as long on a repair than a shop would double checking things as I go. I believe a $1,000 saved on a car repair (times many in many years and many cars :) ) is a $1,000 earned. But I know my limits. I replaced the timing belt et al on our 2000 2.5L Chrysler Sebring convertible, but when the same job came due on the 2005 Hyundai XG350 3.5L dual overhead cam... I was extremely happy to pay $800 to a shop I trust because that was NOT a DIY job! :eek: :)
    A very Merry Christmas to you frodoz and all here on this wonderful forum. The wealth of knowledge and willingness of so many to share their experience and insights is such a gift. I truly appreciate the generosity of everyone here.
    Peace on Forums and Goodwill to All. :)
    Dave
  7. frodoz737
    4,699
    2,496
    33
