What is a good average volt for battery cells?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Champy22, Jun 2, 2023.
  1. Champy22
    Champy22 New Member
    United States
    So I drive a 2007 basic 2nd gen Prius, I've been able to get over 266,000 miles out of it so far and would like to keep it going as I use it for daily commute to college and back because of the good mileage it still gets. After notice some interesting behaviors of the battery, for example when sitting idle not in park with the battery low and a/c turned on, it will start to charge itself for around 10 seconds, stop for a few seconds and repeat this cycle. So I downloaded the torque pro app to get a voltage reading for the 14 battery cells in the hybrid battery, and I'm not sure what a good reading is for them. All of the blocks are reading from 15.8-16.0 volts, and looking at other posts and videos, I see that the average voltage of blocks for other people is around 12 or 14 volts, and I'm unsure as to why mine is so high. Just looking for any input from others to see if I actually have a problem here or not.
  2. BrokenPipe
    BrokenPipe Junior Member
    34
    NorCal
    Nothing to worry about unless you see a check engine light come on and read the code as bad hybrid battery. The voltage can vary from time to time due to a range of factors: temperature, atmospheric air pressure, humidity etc. Keep in mind when you see 15.8 volts or whatever you measure, it's showing the voltage of TWO modules, so divide by 2 to get the actual per module votage.
    All that matters really is how much CURRENT is being stored into the modules during regen and how much current is coming out when the engine ecu and battery ecu work together to drive the motors. The battery ecu constantly monitors all that and it will definitely let you know there's a problem by throwing codes and lighting the CEL.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The symptoms you are seeing are normal. The AC compressor is driven by an electric motor, which gets power from the inverter and HV battery. If you're sitting in idle, the AC will slowly drain the HV battery until it hits 2 purple bars on the display. The engine will turn on to recharge the HV battery until it shows 3 blue bars, then the engine will turn off and the cycle repeats.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Is this the original battery that shipped with the vehicle? If so, you may want to do a top balance, or charge/discharge cycling to rejuvenate it.
    FYI : you're moderated until you've posted 5 times.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,104
    2,005
    NJ-USA
    Your battery - charging behavior is normal for a Gen2 when the State Of Charge is low (gauge at 2 bars). The hybrid control ecu will not "waste" gas by putting more power into the battery than absolutely necessary when the car is stationary.
    It's expected that the battery will be charged while driving and braking.
    As far as block voltages, the pack on my Gen2 will vary from around 200V (low SOC) to 230V (high SOC), or 14.2 to 16.4V per block. This is READY but "at rest" while the car has near zero amps battery current.
    Those voltages will be (momentarily) lower when the battery is discharging, and higher when charging.
    The important thing to monitor is any difference in block voltages. Good packs have that difference under 0.3V for 99+% of the time.
    Dr Prius is a handy app to monitor HV battery voltages.
    Here's a thread that reviews several scantool apps and devices.
    https://priuschat.com/index.php?posts/3290690
