What is a safe max trailer load?
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Jul 30, 2020.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    I have a 2010 prius. Also a 5x8 ft tractor supply trailer. Currently i pull it with a Jetta tdi. Could i also pull it with my prius? And with what load? It would be for trips of not over 50 miles and only a few times a year at most.
  2. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    I acknowledge that Toyota says "don't tow with a Prius" and I have towed with my own Prius, and I've never had a towing-related mishap.
    I stick to the published weight limit for the car which (from memory) is around 900lb for my version of the car. That's what the car's brakes are built to stop, so that's the limit I honor.
    After allowing for my own mass and any planned passengers, the trailer and its load gets the remainder; yes some trailers will max it out before you even put a payload in them.
    And that's the point.
    scona likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    This has been a huge talking point for the Prius for a while.
    The bottom line, DO NOT TOW ANYTHING.
    But there are always those who will do it anyway. Just because someone tells them they can't.
    Putting innocent people at risk, and themselves also.
    Just because you CAN do something, doesn't mean you should.
    Just because "I've never had a problem" doesn't mean it's safe.
    When I use to listen to commercials, some use to say most accidents happen with 2 miles from home....
    Don't know how true that is, but they don't say who's home. :)
    spiralhelix likes this.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Speed is a huge part of the safety question also. The force of an object is equal to its mass times its acceleration (F=ma) -- or in this case de-acceleration.
  5. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Most accidents happen near "your" own home because that is where most of "your" miles are.
    And you are more comfortable near your home and not always paying attention as much when you are elsewhere
    Mike
  6. ASRDogman
    8,067
    4,089
    Not me... 98% of my driving is away from my home....
