What is B Mode for?
Discussion in 'Gen 3 Prius Main Forum' started by James Hz, Nov 16, 2016.
Tags:
  1. James Hz
    James Hz New Member
    Bastrop County, Texas
    2013 Prius Plug-in
    So, I just became the second owner of a 2013 PIP. Since my previous vehicle was a 2003 GMC Sierra, I feel like I'm trying to figure out a space shuttle. :) I'll do my best to seek answers in previous threads, but please be patient if I ask what seem like stupid questions.
    Here's the thing. I read in the manual about Engine Brake (B) mode, but I'm not quite sure exactly when a driver would use it. Can anyone enlighten me?
    Thanks!
    James
    Coast Cruiser likes this.
  2. Mendel Leisk
    42,259
    Coming down super long downgrades, where there's a danger of fully charging the battery, long before the bottom of the hill.
    Using B will delay the fully charged condition, and reduce the time the car has to rely on friction brakes only, possibly overheating.
    Other'n that I would leave it in D, all the time, use the brakes as needed.
    WilDavis and Hong Kong Prius like this.
  3. bwilson4web
    16,512
    I would add we don't have a lot of metrics for the PiP which uses LiON batteries. Certainly the NiMH equipped Prius suffered from 'heat pumping' where descending would charge and heat the batteries. We just don't have similar data for the LiON.
  4. Mendel Leisk
    42,259
    Completely missed that OP has a Plug-In. B mode application is somewhat different in that case?
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    That happens when the thread is in the wrong forum. (Gen 3 vs Gen 1 Plug-In)
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    "B" mode use still applies even though it's a PIP.
    Because the Prius will "take off" down steep grades (very low drivetrain friction/loss) you can use "B" to help control the speed without excessive use of the brakes. Note that cruise probably won't work in "B" mode, though I forget the details (hardly ever use "B" as it's "wasteful").
    The "save energy" and "control battery temp" part is for us fanatics. In truth the car will take care of itself just fine. ;)
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It takes a very long hill to fill the PIP battery, 3000 foot vertical drop vs 600 ft in a Prius.
    fuzzy1, Mendel Leisk and bwilson4web like this.
  8. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Yes️ I notice coming down a 4000ft grade at 3000 the battery is full at this point and down hill speed goes above 80mph I shift to B mode instead of using the breaks.
    iPhone ?
  9. qdllc
    qdllc Senior Member
    1,377
    400
    It sprouts special grip tires for traction over any kind of terrain. At the same time, 5,000 horsepower is distributed evenly to all four wheels.
  10. James Hz
    James Hz New Member
    2013 Prius Plug-in
    Thanks, everyone.
    qdllc--Your answer made me laugh.
    Prodigyplace--Sorry, I didn't realize this was the wrong forum. I thought any 2013 would be considered 3rd Gen. I'm still learning a lot about Prii.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is only the wrong forum because we would give you the wrong answer. A 'normal Gen 3 fills the battery during a 600 foot vertical downhill. The Prius PHV takes over a 2000 vertical drop, so B is much less likely to be needed.
    Prodigyplace likes this.
  12. fuzzy1
    10,687
    During model years 2012-2015, the PiP group here actually was a subforum under Gen3. Only when the 2016s came out and the different models moved out generational sync did the PrisuChat architects move the PiP off separately, no longer a GenX subforum.
  13. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I have only used B-mode once in my PiP, and that was coming down from Yosemite after the battery fully recharged and the grade was still very steep.
    If you know you will be descending a very long and steep grade, use your EV range up to deplete your battery before beginning the descent. This will give you the most regen capacity, save some brake wear, and improve your MPG.
    I would say it usually takes 4,000 feet of elevation drop to charge an empty PiP battery. The last couple miles are slow to regen since charging tapers off near the end. You will notice the engine comes on periodically on extended downgrades for what appears to be no reason. Whenever the EV light turns off, you know the engine has turned on. B-mode always turns the engine on.
    #13 Redpoint5, Nov 22, 2016
  14. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …ah, the "B-mode" - I seldom use it, however I have been known to employ it to slow down without giving the game away to a persistent tail-gater (…i.e. slowing down without using the brakes (…and brake-lights! ;))), but treating the would-be butt-sniffer to a laundry-experience they so rightly deserve! (BACK-OFF, and please change yer underwear when you get home!!! (…pheeeewwwwww!!!)
  15. WilDavis
    2,493
    2,155
    49
    Well, congratulations on buying a decent car, and getting rid of the junk! :rolleyes: …and welcome to PriusChat! I've found one of the least mentioned, but most useful uses of the "B" mode is to give any would-be tailgater a well deserved LaundryExperience of the first order in the event of me not being able to see their front registration-plate in the rear-view mirror! (…think of it as the opposite of flicking on the marker lights to simulate brake-lights - think "Eiger Sanction (1975) (Clint Eastwood)" (…the chase scene in the desert?) It is also curious as to how often I'll attract a tailgater just before my windshields (both front & rear) need a good wash! :sneaky: :) ;)
    #15 WilDavis, Jan 3, 2017
  16. qdllc
    qdllc Senior Member
    1,377
    400
    I really used B mode for the first time last weekend in NC. Coming down the mountain, I didn't want to put all the strain on the brakes, so I used B mode to scrub off a good bit of downhill roll in a couple of places.
    Redpoint5 and Prodigyplace like this.
  17. fuzzy1
    10,687
    This is no different than any traditional car. All of them can be downshifted. And nearly all of them have larger engines that enable slowing down more sharply than a Prius will.
