What is going on with my baby
Discussion in 'Gen 2 Prius Main Forum' started by Bad55Taco, Jun 23, 2018.
  1. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Well, you are at the dealer after all.
    Here is the work up for the DTCs that you've posted :
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21avn/cic12414.pdf
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21avn/cic12565.pdf
    You'll notice that the work up for DTC C1241 shows four (4) possible INF's (sub codes), and that DTC C1256 shows two (2) possible INF's (sub codes), having access to the sub codes (INFs) can help with narrowing down the issue. Look on the dealer supplied work order / repair estimate for any additional three (3) digit numbers near or after the primary DTCs.
    bisco and Raytheeagle like this.
  2. Bad55Taco
    Bad55Taco New Member
    Winterhaven fl
    Well I got Techstream yesterday and read the codes seems to show the dreaded p code. Idk why the dealership didn’t see it. Bc honestly is the bread aviator has a short in it then shouldn’t it throw the p code or no
  3. Bad55Taco
    Winterhaven fl
    Btw cleared the p code triangle went off but car still won’t start. Only way to start is to unplug battery and reset.
  4. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    We have many dreaded p codes around here, which one were you referring to exactly?
    (when in techstream click the little cloud/flower icon to display any INF sub codes)
    Raytheeagle likes this.
  5. Bad55Taco
    Winterhaven fl
    P3009 showed up under hybrid tab and under abs tab. Cleared all codes triangle light went off vex light didn’t. Scan showed no active codes. Shut car off turned back on car would not go into ready
  6. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
  7. Bad55Taco
    Winterhaven fl
    I did not but tomorrow I will.
  8. Bad55Taco
    Winterhaven fl
    Kk this is what I got
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Hybrid battery
    Use search forums button up top search that code. There's like 12,978 posts about it.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Make that 12,979:p.
    But whose counting (y).
    edthefox5 likes this.
  11. Bad55Taco
    Winterhaven fl
    I agree however the battery charges perfectly and holds its charge. I get great gas mill ave also. But why would the vacation light come on with it
  12. Bad55Taco
    Winterhaven fl
    Also when I plug-in text stream and I clear all the codes and then disconnect from text stream and try to restart the car it won’t restart
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
    It’s unhappy most likely all the interconnect in the hybrid battery box is corroded all to hell. With that code it has to come out and take the cover off and you’ll see what’s what.
    Before you tear into it take a lot of photos.
    What’s a vacation light? You mean the RTOD. Red triangle of death?
    #33 edthefox5, Aug 3, 2018
  14. Bad55Taco
    Winterhaven fl
    Sorry scroll through and you will see I believe I took a photo of it. The red triangle is on the VSC light is on and the yellow explanation point (I) is on all comes on at the same time then it won’t start after shutting off. No loss of breaking or troubles accelerating. Litterly if you taped over the lights you would not know if there was a problem. Unless you shut the car off it won’t start or go into ready until you reset it via pulling battery cable.
  15. ski.dive
    ski.dive Active Member
    964
    242
    Hutchinson Island,FL. Mt. Snow,VT
    Normal ''AGE'' problems are starting to happen===
    You have a 14 year old 2004 Toyota Prius with the dreaded ''P'' code,
    your Prius is also 'using oil' =[ it was 2 qts low]
    and the Prius has 280,000 miles...
    #35 ski.dive, Aug 3, 2018
  16. Xtine000
    Xtine000 Junior Member
    27
    Milford, PA
    Oh yeah I've been terrified by that red triangle due to the door not being closed too. :( The Red Triangle is the worst, so scary.
