What is "normal" HV battery SOC?
Discussion in 'Gen 2 Prius Technical Discussion' started by mr_guy_mann, Jan 24, 2021.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    So, as I use my 2006 as a daily commuter for the past 4 months and 5000 miles after refurbishing the HV battery to about 5.5Ah, I have noticed that the "battery gauge" stays at 6-7 bars . Dr Prius or a scantool show SOC staying somewhere between 60-70%. I drive about 80 miles per day, 1/2 on interstates at 80mph and 1/2 on local highways at 40-60 with moderate hills. I don't pulse, glide, or hyper-anything. I flog this low powered beast to keep up with traffic and have little concern for the actual mpg.
    My question is, what is a "normal" range for SOC on a healthy battery under different conditions? Should I occasionally force the battery down some then let it charge up again? I imagine a car in slow traffic with AC on is different vs local cruise on the flat vs highway with hills. Just trying to learn what "good" is so that I can find the bad when I see it.
    I have read that the ecu tries to keep SOC between 40-80%, but that's a pretty broad range and doesn't match what I see on my car.
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    That is pretty normal for a well balanced battery.
    You maybe have misunderstood. The battery ECU will only use the available range of 40% SoC (lower limit) to 80% SoC (upper limit). But it tries to keep the battery at around 60% SoC to allow room to store energy from regeneration but still have enough reserve for demand from the battery.
    So, from what you have said, your battery is acting pretty normally.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That looks perfect!
    Nooooo!!! Unless you want to wear out the battery faster and get worse mileage to boot. The computer knows what to do. Let it do its job.
    Actually, the car insists on keeping it in that range. That's how they can offer such a long warranty on the battery. It will not let it go above or below that. (Except that I've read of people running out of gas in Gen 2s and continuing to drive on battery till the battery is totally dead.)
    Quite different. The car uses 6 bars as sort of a home base. If you're stopped in a traffic jam and the A/C runs it down to about 2 bars, the ICE will start and charge it back up. Having bars 7 & 8 available gives room for storage of energy regenerated braking or descending hills. I like to think of it a little like a spring that can compress or stretch. If it was kept fully compressed, it couldn't absorb energy in one direction. If it was stretched out, it couldn't absorb it in the other direction.
    Here's a very helpful document from @john1701a. John's Stuff - Toyota Prius User-Guide (Iconic)
    flynsqrls likes this.
  4. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Correct. The indicated range on the display only shows the actual charge from 40-80%.
  5. drbojo
    drbojo Junior Member
    Frankfurt
    2002 Prius
    I
    MAIN warning light ON. SOC 17%. Car won't start. Any suggestions?
  6. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    What are the codes?
  7. ChapmanF
    19,019
    17% might be below the limit where the ECU stops trying to crank the engine to avoid draining the battery further. If you read the trouble codes, I won't be surprised if there's a P3000 with INF code 388 or 389.
    That would mean you need to recharge the traction battery (or replace it with a known good, charged one) before you can continue trying to start the car. That will require the high-voltage battery charger your Toyota dealer can obtain from their regional center, or some other alternative high-voltage charging solution you might be able to read about here with a suitable search, and has to be done by someone using suitable safety practices.
  8. Mendel Leisk
    42,343
    If you're fully warmed up, driving at steady moderate speed on level road, the car is going to reliably run you down to two bars. Same story if you're tooling around a parking lot looking for a spot. Other'n that, 2/3 to 3/4? Oh except on a steep downhill.
