What Is "Normal?"
Discussion in 'Gen 3 Prius Main Forum' started by Maine Pilot, Mar 31, 2011.
  1. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    Arrgh! I was afraid of the responses, and you guys didn't disappoint me!
    Actually, I did read the entire manual and quite a few of the threads in your forum, (especially the one on newbies), before making my post here. I couldn't find any references to what the "normal" mode was in the manual, but the response above does make sense.
    As it's currently snowing up here in ME right now (about 4" here on the coast), the Prius is staying safely in the garage, so I won't have a chance for a day or two to try out the "NORMAL" mode.:)
    By the way, what % decrease in MPG might one get, (as opposed to Eco mode) while driving in "Normal?" Also, would you get more acceleration, ala "power mode" in "normal?"
  2. Exponent
    Exponent New Member
    22
    Kansas City
    If you drive based on how pedal feel (i.e., you tend to determine how much you're going to accelerate based on how far you feel is appropriate to press the pedal in any particular circumstance), then you might save some in ECO mode versus normal, as long as ECO doesn't cause you to become too conservative with your acceleration. (Yes, being too conservative with your acceleration can reduce efficiency. In particular, always attempting to avoid causing the engine to turn on is actually not a good idea, except perhaps in a few very specific cases.)
    If you're like me however, and judge acceleration by the feel and sight of the accelerating motion itself (along with watching the HSI), then your choice of mode doesn't matter (much). In ECO mode, to accelerate at a certain rate, you simply need to press the pedal a little bit farther than you would need to in Normal mode. But nothing changes as far as engine operation is concerned. It's all a matter of what pedal position is mapped to what level of power request to the engine. Once the car figures out how much power you're asking for based on your mode and pedal position, the engine does the exact same thing no matter what. Additional power in PWR mode is an illusion, technically, since nothing prevents you from getting the same amount of power when in ECO mode; just press harder on the pedal. (If you floor the pedal, it doesn't matter what mode you're it; they all produce equal power at that point.)
    There are a few real benefits to ECO mode, such as altering how the AC runs, when the engine shuts off at a stop, et cetera, so there is a true but small difference between the efficiency of ECO and the other two modes. But in terms of basic engine performance/efficiency, there is really no fundamental difference.
  3. joemiata
    joemiata New Member
    New Jersey
    Did I miss something. I don't think I've seen a reply with a good explanation of "normal mode" (absence of dash light selection EV,EC, or PWR). This is going out on a limb, if I select ECO and it lights up on the dash fine. Now if I press ECO again the dash light goes out for ECO. Is it possible I'm still in ECO just driving without the annoying ECO light lit up?? I wonder if my theory will prove true in PWR mode, if PWR on dash is lit then I press PWR again light goes out will I still feel that available power ? Forgive me if I sound foolish, just a newbie learning.
    Thanks Joe
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    If the mode lights are out you are in normal mode.
    Tom
  5. Rstaton
    Rstaton New Member
    60
    Watsonville, CA
    Are you certain that the maximium "floor" power is the same in all modes? I ask because it seems like I read somewhere that the maximum power was limited in the ECO mode. :confused:
  6. JeffyJosephNorCal
    JeffyJosephNorCal Formerly JeffyJosephNCa
    86
    Elk Grove, CA
  7. ETC(SS)
    7,504
    I don't think so. I'm pretty sure that when the car is at WOT (Wide Open Throttle) you're going to get the same output regardless of operating mode.
  8. qbee42
    18,058
    3,081
    Northern Michigan
    Yes, it is the same. I was personally told this by the Prius Chief Engineer when we were talking in Detroit.
    The reason is obvious. Regardless of mode, if you need to move in an emergency, you need full power. Taking time to hit a button is not a good option.
    Tom
