what is RPM range? and does anybody else miss their tach?
Discussion in 'Gen 2 Prius Main Forum' started by derekderek, Oct 16, 2014.
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Ah, my Prius spends 99% of its day 'engine on' (45 to 70 MPH speed limits) so I do not spend much time at 'engine off' so a tach makes more sense in my use.
  2. Justin Walter
    Justin Walter New Member
    Stonehaven
    Hi John - thanks for putting my mind at rest. However I would still like to fit a live diagnostics monitor and just cant find a plug on the Prius that mine will fit. Can you let me know where the plug is located and if there are different plug pin arrangements for these devices
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    The connector-port is directly under the steering-wheel, at the very bottom of dashboard covering.
  4. Justin Walter
    Stonehaven
    Thanks John - I'm just getting to grips with all this high technology stuff and need just a little bit of coaxing now and again. I'm very grateful for your help.
  5. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Check this out:
  6. Daves09prius
    680
    161
    Gettysburg, PA
    Hey! none of my amazon links posted? what gives PriusChat???
