What is Techstream?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Feb 21, 2016.
  1. working1
    working1 Active Member
    121
    112
    Check the Setup, VIM Select option. It should show 2 options. Be sure correct one is selected.
  2. drives
    drives Junior Member
    49
    Hampshire, U.K.
    My copy of Techstream on Windows 10 seems to be working finally. Had a bit of time today to test it out. Jeff- are you able to give a quick guide re: how you got that print out for the HV battery check? Struggling to find it. When I click on the health check it just runs for error codes by the looks of things and just comes back with a blank screen with no data
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As I recall, I just clicked on "HV Battery" to see the data, right clicked to "select all" and copied/pasted into notepad so that I could upload the text file.
    JeffD
  4. Roger559
    Roger559 Junior Member
    Central California (Clovis)
    I helped a computer user recently bypass the driver auto update - It was a Lenovo with hotkeys to brighten and dim the screen. I had to back the driver out to a version for Win7, then disable the updates - all done without internet connection, until after the update disable step. Check the "how to geek" website for "block updates and drivers on windows 10" (sorry, I'm to new to post a link)
    hope this helps.
  5. eman08
    eman08 Active Member
    360
    192
    US
    Don't expect to do any kind of computer flashing with those cheap counterfeit cable's as you can protentionaly brick all the computers in your car. You get what you pay for using pirated junk from Chinese scammers.
    TechStream Lite with the Mongoose Pro cable only cost $495 from Drew Technologies compared to the full TechStream that comes with a Toughbook that cost $5,799. You need a TIS subscription to have access to calibration files and firmware images anyway to do any type of ECU, body control module programming.
    Roger559 likes this.
  6. ChapmanF
    19,027
    By "body control module programming", do you mean the tweaking of the car's customizable behaviors like reverse beep or unlock on park? Techstream can happily do all that stuff without phoning home. Now, anything that involves actually flashing new firmware, yes, that would be a different story.
    -Chap
  7. Asif Subhan
    Asif Subhan New Member
    South Carolina
    I
    Did anyone try activating or adding another key to your 3rd gen Prius using techsteam ?
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Yes, if you search this Forum you’ll find posts about it.
    From what I recall, it’s not too difficult as long as it’s truly a new key. But if it’s a key that’s been used in already in a different Prius, it’s either impossible or very complicated.
    Raytheeagle likes this.
  9. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I did. I bought an unlocked fob on eBay for about $100. It worked like it was new.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I helped a member out here (as well as a coworker) pair a new key to their Gen3 using version 10.30.028 and it worked well:).
    About a 3 minute activity if you know where the menus are(y).
    SFO likes this.
  11. Prius fob programmer
    Phoenix
    I am looking for the cable and the software for my windows 10 on eBay. Do you have the links for these items and the instructions to install in windows 10. Is this better than having a locksmith program the fob or is this the same thing a locksmith uses?
    I watched this guy erase and program a new key. How does the system know the new key and only erase it and not the old key he has taped?
  12. Prius fob programmer
    Phoenix
    I watched this guy erase and program a new key. How does the system know the new key and only erase it and not the old key he has taped? On the Chinese clone software will it have the same instructions as the guy that used techstream on the link below?
  13. Prius fob programmer
    Phoenix
    If you have the exact link for the clone software and the cable great????
  14. Prius fob programmer
    Phoenix
    Did you find techstream software and cable that will work on windows 10 or can you just install it in windows 10 and run it in windows 7 compatibility mode?
  15. Prius fob programmer
    Phoenix
    Can I install techstream in windows 10 and run it in Windows 7 compatibility mode. I do not want to edit my registry to install it?
  16. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Check CL for a laptop running XP.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Check the newspaper yard sales section for windows 98 laptop.
  18. James Analytic
    414
    63
    Michigan
    Great detail and good to know. I just asked the question regarding what is detailed regarding the battery. I'm mainly at the moment wondering what is all detailed in regards to more than the ODBLink SX USB. Guessing these cheap MiniVCI's can detail the wipers metrics, any verification by anyone and what vers of software used for a 2013?
  19. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I don't know about the wipers. What are you wanting to adjust?
    I'm running version 8 and it works fine on my 2013.
  20. James Analytic
    414
    63
    Michigan
    Basically, wanting to see the wiper circuit metrics if any and not adjust anything for now.
    Going by this reply that there is some sort of metric or settings reported:
    2013 Front Windshield Wipers Not Working | PriusChat
