What is the best octane of unleaded to use?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by KRISTJAN ANTALIC, Nov 12, 2018.
  1. KRISTJAN ANTALIC
    KRISTJAN ANTALIC Junior Member
    16
    SAN ANTONIO, TX
    2018 Prius Prime
    The compression ratio of the Prius Prime engine is 13:1, which is kind of high.
    When I think high compression ratio, I tend to think higher octane.
    What are you using? What are your thoughts?
  2. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Regular unleaded, that's what the car was designed to run according to the manual and I've never had a problem with it. No knocking at all. It's an Atkinson cycle engine and I think that changes things a lot.
  3. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    Regular Unleaded as indicated in the manual, that means around here 87 with 10% ethanol.
    #3 Salamander_King, Nov 13, 2018
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    It's been a while since I've seen the Prius manual.
    But I ran mine on regular octane...most of the time.
    Never had a problem, never felt performance was hindered in any way.
    Superstition and ritual, would have me very rarely run a "premium" tank of gas, which was probably just a waste. I can't say I ever really realized a huge difference.
    With my Honda Fit, I still follow the same ritual. Which is operating on regular 99% of the time, with only very rare premium tank fill ups, and occasional Techron Fuel additive treatements.
    Both actions which I admit upfront may have more placebo or superstitious value than tangible value.
    But that's how I "fuel" my vehicles.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Indeed. That 13.1 "compression ratio" doesn't work like it does with a conventional gas engine.
    Absolutely, positively NOTHING to be gained from a higher octane.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    13:1 would be high in an Otto cycle engine. As already mentioned, the Prius engine is an Atkinson cycle, which changes the equation. Use what's called for in the manual.
  7. schja01
    schja01 Senior Member
    1,821
    1,208
    Chicagoland
    2024 Prius
    Limited AWD-e
    I put premium in mine. I makes me feel good. I can afford $2 extra.
    I get a Smiley on the MID.
    KRISTJAN ANTALIC likes this.
  8. sam spade 2
    7,035
    2,799
    2017 Prius c
    You would do a lot more good if you put that $2 each time you fill up into a can and gave it to a worthwhile charity once a year.
    Or you could send it to me.
    Either one of those should make you feel even better.
  9. ETC(SS)
    6,958
    I do not have a pet hate for oil companies, but I'm not going to give them extra money for a product that's labeled "premium" just to amp up their profit margins.
    +1 on finding better things to do with the $2.
    Even lottery tickets would be less wasteful because there is a MUCH better chance that we'll see you on TV holding a poster-sized check than there is that putting "premium" gas into a Prime will benefit it in any way - and dot.gov might 'statistically'....or even ACTUALLY spend some of the lottery money on.....education and junk.
    This is late 2018.
    Car makers can get by with compression ratios of 13:1 (in both Otto and Atkinson cycle motors) without their buyers having to drive to the drag strip to get gas because engines are fuel injected these days and air-fuel ratios are monitored and controlled.
    What Is the Atkinson Combustion Cycle, and What Are Its Benefits? – Feature – Car and Driver
  10. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Octane not important but use of TopTierGas.com can ensure you getting adequate detergent additives. Energy content relates to MPG and that could vary slightly in your area.
    Consider what gasoline region you are in, per below map:
    https://www.api.org/~/media/Files/Policy/Fuels-and-Renewables/2016-Oct-RFS/US-Fuel-Requirements/US-Gasoline-Requirements-Map.pdf
    I believe you are in conventional gasoline area, which means you could see slightly more energy-content variations between stations and between grades, with no particular trends, trial and error testing. Those of us in Reformulated Gasoline areas have more steady diet between stations and grades.
    triggerhappy007 likes this.
  11. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I agree, use top tier gas. The stations that sell top tier around me are Shell, Mobil, and Exxon and they are only about 5 cents per gallon more expensive than non top tier. Plus many of you are only getting gas every one or 2 months so it's not that much more for top tier. And don't waste your money on Premium, it's not required.
  12. KRISTJAN ANTALIC
    16
    SAN ANTONIO, TX
    2018 Prius Prime
    Thanks to all for the fantastic feedback -- this is a great forum.
    Seems all the comments regarding the Atkinson cycle were spot-on:
    jerrymildred and schja01 like this.
