What is the bump-during-braking oddity I keep reading about?
Discussion in 'Gen 2 Prius Technical Discussion' started by ChapmanF, Apr 3, 2008.
  1. fuzzy1
    10,722
    Does that mean that Brake Assist, or its equivalent on the 2005, would leave actual seat belt bruises on passengers, not merely chest pain as DW has suffered in my 2010?
    I was unaware that there was any more friction available in the tire-pavement interface to create stronger braking. It felt as if the tires were already pulling gravel out of the asphalt.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    FWIW, in Consumer Reports tests, the braking distances were no worse on dry pavement for the 3rd gen vs. 2nd gen. Wet was a mixed bag.
    For 60 to 0 mph, dry, here are their results in feet:
    '10 IV: 133
    '08 touring: 133
    '04 base: 143
    For 60 to 0 wet:
    '10 IV: 147
    08 touring: 140
    04 base: 152
    The tires on their '10 were Yokohama Avid S33, size P195/65R15 89S.
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I slowly worked my way up from 35 to 50 PSI over the period of several months and a change of tires and never noticed the braking bump transition until seeing mention on prius chat and then going out and looking for it.
    After several tries I finally found some railroad tracks on a curve at the bottom of a hill so that I could be braking and turning as I crossed the tracks. Normally I'm coasting (no arrows) or light regen (no foot on brakes, foot hovering over gas pedal) and since my foot isn't on the brake pedal I can't notice it?
    I tried braking harder and harder each day as I crossed those tracks (but hesitant to brake too hard as there might be cars behind me and I didn't want to wast gas getting back up to speed). Eventually after several tries I found a speed/braking combination that gave me a slight sensation that I could describe as being the one in question. If I didn't go looking for it I would have never found it. I'd guess the front tires were around 45 to 48 PSI when it happened but I didn't check and if I hadn't read about it I wouldn't have given it a second thought.
    I suppose if I were in a true emergency braking maneuver the transition might add to the stress of the situation but I can't imagine it ever bothering me under normal driving conditions.
    Maybe the effect varies in intensity from one Gen II to another? Maybe only those who are heavy on the brakes to begin with are likely to notice it?
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I've never really had a problem with this before. Just a few days ago however I did have it (momentary loss of braking) happen to me and I noticed something in particular about the uneven road surface that caused it.
    This road surface had a join between a concrete road section and an asphalt section, and the join was uneven (concrete sticking up slightly higher than the asphalt). More importantly however was that the join didn't run directly (perpendicularly) across the road, but rather it ran at about 30 degrees off perpendicular.
    I thought that this might have been important because many times previously I've hit irregularities in the road but not noticed the loss of braking so clearly like this time. I'm guessing that the two front wheels hitting the irregularity at slightly different times did something to confuse the traction control. Anyway I'd describe it as a momentary loss of braking, but I can see how some people could mistake it for a "forward surge".
  5. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    Maybe you don’t feel it, but I bet if you had a scangauge monitoring Bta (Hybrid battery amps) you would “see†it all the time.
    I am constantly frustrated when driving around the city by just how easily regenerative braking kicks out when you are braking and hit even a moderate bump in the road. You can see the scangauge go from -40 or – 50 (regenerative charging) to positive +3 to +4 (using charge to run the lights / AC etc). I try to let off the brake and press it again to reset it, but unless you press on the accelerator (enough to coast or more) regenerative braking will not reset. Rarely do I have time to get it reset before needing to stop at a light (or whatever).
    Given the climate here (freeze and thaw all winter long) the roadways near stoplights are always in sad need of repair. I have learned to “feel†the transition long before the scangauge updates to show it, but it happens a lot and I know it will take a toll on the brakes. Maybe where you all live the roadways before stoplights are nice and smooth, but if they are not, then your just missing it when it happens.
    R-P, getwellsam and uart like this.
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    That's interesting jpadc. I've often wondered how much regeneration I might be losing when I hit a rough patch regenerating downhill. I didn't know about the problem with "resetting" regenerative braking.
    As for why I felt it on that particular occasion and not on others, I suppose it must be related to how hard you're braking at the time.
  7. getwellsam
    getwellsam Junior Member
    22
    Pittsburgh
    Other people who complain about this issue.
    2008 Toyota Prius Traction Control System Problems | | Page 2 CarComplaints.com
    It appears to me that some people classify this issue as 'when the regenerative brakes are stopped and you are left with the friction brakes.' Whatever you call it, at least a huge amount of your braking power goes away.I am turning off the traction control soon. This traction control system issue has been one of my biggest complaints with this otherwise great car. It is way too sensitive over bumps. It appears to me that outside of being in the snow and spinning the tires in snow for long periods of time (which can screw up something related to transmission I believe) I am better off with this system off.
  8. ChapmanF
    19,053
    The behavior in this thread isn't really about the "traction control" per se, it is just a matter of coordinating the regenerative braking with the antilock braking system. (And yes, ABS is a system concerned with maintaining traction, but it's not the same thing as TRAC. The TRAC is about maintaining traction under conditions like acceleration, and also protecting the transaxle. ABS is about not losing grip while braking.)
    Under ordinary light braking, the car will make a pretty smooth transition between regenerative and friction braking, so you don't really notice it. But when you hit a rough spot, something that makes the sensed wheel speeds different and fools the ABS into thinking the traction might be iffy, the ABS has to react extra fast.
    Because all the braking force from regen operates on the two front tire patches, whereas friction braking can distribute the same force over four tire patches for the same deceleration rate, when the speed sensors suggest any possible problem, it is safest to switch from two-wheel to four-wheel-braking as quickly as possible. It can take a moment for the friction braking to reach the same force, because under light braking, the friction system wasn't really being applied yet. But the car drops the regen braking force right away, because the wheel sensor input suggested a skid might be imminent, and that's the way to avoid it. So the slight delay between the regen braking force dropping out and the friction brakes coming in at the same original force is the "bump-during-braking oddity" discussed in this thread.
    -Chap
    SFO likes this.
