What is the correct tire pressure for Gen 4 195/65R15 91H
Discussion in 'Gen 4 Prius Technical Discussion' started by booke02, Jul 12, 2016.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    No directional tires in the US.
  2. Trollbait
    12,526
    There is, but rare to see them as OEM.
  3. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    So today after a few days of owning my new Three w/ ATP, I decided to stop by the local service station and I checked all my tire pressures (I use both a digital and a analog) and low and behold all tires were at 32.5lbs???? But what's nuts is I have been getting phenomenal mpg's these last few days. Lol.
    I went a paid the $1.50 for air and bumped them up to 42 front and 41 rear (44max per sidewall, 36f / 35r recommended) and then went on a 25 mile drive. Not sure if I like em that hard as on the highway I think I felt some sway? I've alway ran all my old Prii in the higher range, not sure what's up.
    Maybe I will lower the psi to 40f / 39r and see how that feels...
    What's everyone else with the 15's running?
    Does anyone know why the recommended difference between front and rear is now only 1psi? It used to be 2... Weight distribution maybe?
    Oh, btw I have the Dunlop Enasave tires equipped.
    Coast Cruiser likes this.
  4. booke02
    booke02 Active Member
    391
    415
    Israel
    Maybe due to the changed rear suspension?
  5. Mendel Leisk
    41,408
    That's one of the red-flags-to-a-bull* in my life. The other is having to pay for parking at hospitals.
    What's the spec, in the door jamb? I would take the higher value (assuming Toyota's still saying one value for front, a lower for rear), add a pound or three, no more, and try that on all four. I used to set ours (low profile, unforgiving 17"') in the teeth rattling 40's, then dropped to 36 all around (spec is 33/32 front/rear) and, suprise suprise: little or no noticeable change in mpg.
    I have an unsubstantiated hunch too, that running significantly higher pressures is going to shorten the lifespan of suspension components.
    (* Up here Chevron still has free air.)
    Coast Cruiser and lar.smith42 like this.
  6. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    As stated in my post above the recommended pressure is 36 front and 35 rear...
    Directly across the street from where I paid for the air there is a wawa with free air, but it once emptied my tires when attempting to fill due to a faulty nozzle...
    So I either pay the $1.50 or I use my good bicycle floor pump.... It's in the 90's today feeling more like 100 so I opted for the lazy route and paid. Lol.
    Actually my drive home from running errands today with the higher pressure wasn't too bad. I still might lower it to 40/39 one the tires cool down but we shall see...
  7. Mendel Leisk
    41,408
    I've noticed of late Chevron's air sometimes seems to crap out, will barely raise the tire pressures. My guess is when they replace the compressors they're cheaping out.
    My perspective is biased by having 17" too. In winter with 15" snow tires I keep them over 40 psi, they're much more forgiving.
  8. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Also keep in mind that the Eco's recommended tire pressures are 39 front, 36 rear, I believe. So, that might be a decent baseline.
    Blizzard_Persona likes this.
  9. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I went back down to the recommended PSI on my 15" tires, ( or just 2 over) and my car feels "right."
    Smooth as silk, and 62 mpg in town.
    (Now I just wish I had quiet tires!)
    lar.smith42 likes this.
  10. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Thanks.
    But...
    Recommended Tire Pressure is 3 psi apart on the Eco?? My door jam on my Three w/ ATP says only 1 psi difference. 36/35? Could that 60-70 lbs weight savings of the Eco not having a spare and wiper equate to the 3 psi difference for weight distribution?? I wonder...
    Further are all three's / fours suggested psi 36/35 or are the ones with ATP different due to a little extra weight?..
  11. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    You got stuck with the toyo's? Right?:rolleyes::confused:
    I lucked out and got the Dunlop Enasaves. They seem wonderful. I would not call them loud in the least..
    :p:D
    sitaprius and Coast Cruiser like this.
  12. Coast Cruiser
    2,267
    2,571
    Yep, 15" Toyo. 36/35. Pretty good handling tires. Smooth, steering is good, cornering is good, braking is fine. I just have to try and avoid the noisy roads.
  13. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    So I went a lowered my tire pressure today from the 42 front / 41 rear to 40 front and 39 rear...which I raised originally from the dealerships 32.5 yesterday morning...
    Heading out now on a drive through the Amish Countryside and I will report back with results..
  14. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    You can get pumps that plug into your lighter socket, which enables you to do your tires at home when they are cold. I kept the one out of my Sonata Hybrid and that thing's a lifesaver. I bumped mine to 42/40 after I got the car, based on the recommendations here.
  15. Coast Cruiser
    2,267
    2,571
    That's exactly what I've been looking for thunderstruck. Can you tell me where you got it? What is the brand name? Will it also plug into a regular wall socket? Thanks.
  16. thunderstruck
    154
    151
    Port Charlotte, FL
    2022 Prius
    It was included with my HSH since the car didn't come with a spare tire, just an inflation kit. I've seen them at Wal Mart and I bet you could get one from Amazon too.
  17. TinyTim
    TinyTim Active Member
    383
    235
    Seattle
    Not to revive an old thread but I need input on tire pressure for my 2017 Prius. 15" wheels and Toyo tires. I ordered an electric pump and I want to top them off but not to the point where the tire pressure or components of the tire and car lose performance. I was thinking 38 front and 37psi on the rear tires. Thoughts?
  18. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I'd say experiment with what works best for you.
    I'll note that the Two Eco specifies 39 front, 36 rear out of the box, and the tires are actually the same as the One/Two/Three/Four (which call for 36 front, 35 rear).
    RCO, TinyTim and Prodigyplace like this.
  19. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I've tried different pressures between 32 and 40ish - I didn't see much difference in handling, but the 32 gave a little better ride. I didn't keep the pressures long enough to see if they had an effect on fuel use - I felt 40 was a bit too hard for use all the time on varied roads. I've just left them at 36 all around.
    TinyTim, Mendel Leisk and Raytheeagle like this.
  20. Tande
    Tande Active Member
    537
    321
    Mich.
    I use this .......works as advertised.....
