What is the idle check ceremony?
Discussion in 'Gen 3 Prius Technical Discussion' started by Prius NZ, Aug 30, 2013.
  1. Prius NZ
    Prius NZ Junior Member
    70
    27
    Auckland, New Zealand
    I have read a lot about people referring to it in here but no one I can find says what it is or what its for. Especially on Gen3 as that is what I have :)
  2. Former Member 68813
    3,524
    983
    US
    Prius checking if engine is still there and responding to commands? I don't know.
    52,891
    never heard of it, but that doesn't mean anything.:cool:
  4. DomoDriver
    DomoDriver Junior Member
    28
    New Mexico
    It's in S3, right here: Gen3 warming up stages | PriusChat
    I think this is where the car calibrates the O2 sensor. It can't do this while the car is cold.
  5. Prius NZ
    70
    27
    Hmm still not much wiser. I see that a gen 2 has to be stopped to do it. Gen 3 can do it while coasting. But not what the result is if you don't allow the conditions for it to happen or even what it is. All very strange. :)
    Why would it have an oxygen (O2) sensor?
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I've always figured that the idling check ceremony is a combination of a bad translation from Japanese plus carrying a concept over from the 2nd gen that doesn't really exist on the 3rd: Hit 70°C, and the engine will turn off when you're off the accelerator. I don't really see much of a "ceremony", or anything else that's particularly different. As far as I'm concerned, S3 doesn't exist at all, at least as described.
    What does exist, as I've noticed, is that after reaching 68°C, the car is much more amenable to shutting the engine off during a glide; it can be done with almost 100% success. Before hitting that point, I'd say the success rate is probably ~50% or so for any given attempt to glide.
    hybridbear likes this.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I imagine after that point the mixture is leaned and the timing advances... since that cat and coolant is warmed.
  8. DomoDriver
    28
    New Mexico
    It's needed to adjust the amount of fuel injected so the fuel/air mixture is correct. I think they've been around in the US since the 80's or so, but I don't have a source for that: I'm just going from memory.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Ceremony ensures super wonderful good time!
    cwerdna and hybridbear like this.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    At least the early 80s. My '81 Olds had one. I believe the Prius has two, one before the cat and one after it.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    looks like the O2 sensor has been in some cars since the late 70's.
    Oxygen sensor - Wikipedia, the free encyclopedia
    By measuring exhaust gases, you can perfect the fuel/air mixture. The Prius measures before and after the catalytic converter.
    The idle check is much less a problem in Gen 3 than in Gen 2.
  12. N2MPG
    N2MPG Junior Member
    30
    Radford Va
    Um.. all modern cars have O2 sensors..
    There is definately a difference in s3 and s4..
    The idle check ceremony has something to o with the car seeing what conditions the catalyst is iin. Emissions is king and if the car isn't at peak operating temperature then the engine will continue to use fuel while gliding. The difference is thst under 46 you can still do a zero fuel glide even in s3.
    You have to be in s4. to get full warp stealth at interstate speeds.
    HUGE difference.
  13. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  14. Former Member 68813
    3,524
    983
    US
    So, basically, you are saying that no one knows?
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    From what I'd heard, the answer was sensor calibration.
    telmo744 likes this.
  16. bwilson4web
    16,552
    The good news is this control law no longer exists in the current Prius. The description is a left over from the NHW11 and NHW20 last sold new in 2009.
    It is an ambiguous Japanese-English artifact:
    • "idle check ceremony" - original description
    • "idle check protocol" - more English-like translation
    In the earlier model Prius, the engine would at speeds under 34 mph continue to run until it passed the "idle check:"
    1. engine coolant at or above 70C
    2. car stopped for ~10-15 seconds
    We still commute using our 2003 Prius so I'm partial to routes that have a stop where I can trigger this test, this protocol, to occur. Sometimes, I'll stop at a light and knowing the car has not yet gone through this mode, I'll hold the brake and pulse the accelerator to get the engine spinning. Within 10-15 seconds, the engine will auto-shutdown and the car is in full 'hybrid mode.'
    CTpriusV likes this.
  17. Prius NZ
    70
    27
    Gosh. Quite complex. Pleased they managed to eliminate that one. Thanks
    bwilson4web likes this.
  18. Kasun Gamage
    Kasun Gamage New Member
    O2 Sensor also call it as lamda sensor.Toyota Prius has two lamda sensors with advance E.G.R. mechanism( Exhaust Gas Recirculation)These two sensors are situated after and before of the catalytic converter.It measures catalytic converter doing it's job.Reduction of harmful gases by measuring input valve and output value."three-way catalytic
    converter introduced in 1975 typically it needs a lamda sensor.
  19. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I have noticed that when I go on a longer trip and then stop at 170F or more for a short stop, then after turning the car on (the SGII still reports temp around 170F), I find the engine doesn't want to stop during glides. It takes a few minutes of engine running yet, a time or two, for it to want to turn off during glides. Whereas according to the Warmup Stages sticky, I should be in S4 if I switch the car on above 140F...
  20. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Are you in ECO when this occurs?
