What Is The One Thing You Would Change?
Discussion in 'Gen 3 Prius Main Forum' started by HybridKingdom, Aug 9, 2009.
  1. dan77459
    dan77459 Toyota fan
    Pearland, Tx.
    2012 Prius+ MPV
    I would get rid of XM radio and go to Serius. With XM trial I can not get Howard Stern. Howard is extra with XM. I mss my Serius - hate XM!!!
  2. scalz
    scalz New Member
    CT
    You need the XM Premium package. They'll let you upgrade your trial period for $10 so that you can get Howard 100 & 101.
  3. Brett.
    Brett. Junior Member
    134
    26
    I can't see out the windshield at night because the glare on the windshield from the gauges which is reflected off the dash board is right in my line of view.
    To remedy this, I'm going to lay down a piece of felt to make light reflection off the dash impossible, that should put an end to it.
    The gauges also don't go dim enough. They are kinda either on or off, the dimmer is pretty worthless at night.
  4. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I would ditch the "premium" nav and get a good navigation system. Or even go back to the one I had in my 2005. It work well.
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Change A-pillar so that it stops blocking so much of my view.
    Go back in time to 1940 and return the seats to the manufacturer who made them.
  6. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    After 12K miles since last August:
    - More comfortable seat
    - More power
    - Less road noise.
    The Prius is fine in small doses, but after a couple days of driving it I can't wait to get back into my GS350.
  7. NiHaoMike
    NiHaoMike Member
    98
    16
    * The HVAC should have A/C only, heat only, and fan only modes, just like home HVAC systems. Really annoying to have to turn the temperature all the way down and the A/C off in the morning, only to have to turn the A/C on and the temperature up a few miles later.
    * The clutchless CVT, while very smooth and reliable, feels like it has little low end torque. The fact that MG2 is always connected by a fixed ratio means it doesn't get a low end torque boost like the Sonata Hybrid's modified DCT does.
    * No tachometer. Additionally, there should be an "engine efficiency" meter that gives useful information while accelerating or going up hills.
  8. El Dobro
    El Dobro A Member
    7,105
    3,282
    It would be nice if the driver's inside door handle was flush with the panel so my knee wouldn't keep hitting it.
  9. fjpod
    fjpod Member
    419
    72
    New York
    I would like to be able to lock the car from the keyfob BEFORE I close the door. Every other car on the planet works this way. After I close the door, my hands and arms are full of whatever I am carrying and I can't reach into my pocket or use the touch sensor on the door handle.
  10. d2mini
    d2mini Active Member
    519
    106
    Houston
    The button lighting/colors on everything but the electronic screens.
    I can't believe toyota is still using the green lighting and the radio screen with green background and gray text.
    Almost impossible to see, especially in broad daylight.
    Please take a page from Audi/Vw's playbook in this area. Soooooo much better.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    More soundproofing
    Drafty01 likes this.
  12. Drafty01
    Drafty01 Junior Member
    42
    Auckland, New Zealand
    or at least an option to decrease or disable it.
  13. ES44AC
    ES44AC C.A.U.S
    319
    77
    I agree, the visibility both front and rear makes the car difficult to park. No matter how close I think I am to curb or concrete bumper when I get out I am farther away than I thought.
    Oh and less "plastic" rattles or buzzing noises would be nice too!
    I know that's 3 things so pick the one you like :D
    ES44AC
  14. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    If I could only have one thing:
    Window sill line
    Flatten and lower the sill line of the glass at the sides and at the front corners.
    The present arrangement obstructs near field vision badly and makes alignment of the car when backing much less intuitive.
    A high and sloped sill line may be current fashion but in my view it is both ugly and dysfunctional. The split rear window on the other hand doesn't bother me at all as it is functionally necessary to minimize highway fuel consumption and vision directly to the rear seems fine.
    If I could have 2 more they would be:
    A bit more silencing of interior noise
    More practical surfaces in the trunk area. The present light colored finish to which things readily adhere is very frustrating, particularly when there is no apparent benefit in either function or cost saving.
  15. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    1 more soundproofing
    2 try to put more read-outs in front of steering wheel; less to the side
    3 put in water temp gauge
    4 more storage space or cubie holes for cards, phone, ect.
    5 do away with center island
    6 have bigger & better battery, to increase EV mode from 25 MPH to 35 MPH.
    7 another light in trunk area
    8 built-in power inverter (12 volts dc to ac 115 volts
    9 seats....more support for lower back
    I have two 2011 Prius!! I have made changes to # 1; #7 ; #8 and #9
  16. michinnom
    michinnom Member
    162
    29
    build quality, i.e. rattles, cheap plastics galore, and that stfu rear split.
  17. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    After going from my '10 to a '12 I want my old nav back. Never thought I'd say that.
