What Is The One Thing You Would Change?
Discussion in 'Gen 3 Prius Main Forum' started by HybridKingdom, Aug 9, 2009.
  1. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'll bet there's a Toyota umbrella that fits perfectly!
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Unless equipped (such as on Canadian Prius), it's advertised only as auto-off on U.S. Prius so it's not a manufacturing defect.
  3. Tideland Prius
    16,678
    that looks fantastic! How'd you manage to cover the notch? It looks like one whole piece to me. I assume there are multiple pieces?
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It is many little pieces. I used paper templates, then cut the small felt pieces. The felt looks like one piece when you’re done.
  5. Judgeless
    1,821
    257
    Cleveland, OH
    My next project is full auto lights. I ordered the kit yesterday. I am going to follow halkmoon77 install info. This should have been standard in the Prius.
  6. HybridKingdom
    HybridKingdom Junior Member
    24
    Iowa
    Update: Just had my 5,000 mile oil change. Nothing else done and the total cost was $57. I was accustomed to pay $25 every 4,000 miles, so this is a little much. Not a deal breaker though.
  7. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Colour on the radio and HVAC read out, the screen makes me think of $1 calculator:rolleyes:
    Dual Zone HVAC ( wife is is her 50's)
    Memory/power seats
  8. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I've owned it for four weeks and two things are really starting to bug me. It is a different car and things are different and I can adjust to buttons and knobs being in a different locations.
    Like the Cruise control I'm use to it being on the right stock but no biggie that they move it to lower area under the steering wheel and it is just different.
    1. The stocks on the steering wheel are driving me nuts.
    It is the angle that makes them not a natural feel. That 60-75 degree angle is odd to say the least. They need a S arm so that the stock sticks out at a 90 degree angle in the same position. It would have a more natural and comfortable feel.
    2. There has to be a way to get the display to be brighter when the lights are on. Here in Pennsylvania when driving through a construction zone you must have your lights on. Well in day light with the lights on the display will not get bright as when the lights are off. And if the sun is at the right angle in front of the car it washes out the display. And yes I have the dial at full bright. When that knob is at full on the display "should" be as bright as when the lights are off.
  9. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    There IS a way to make them brighter. Slide the roller switch all the way up, and then press a little harder...there is a setting above that, which will click. Then the display will be lit up just the same amount as when the lights are off. (just remembe to switch it back down at night...the display is REALLY bright if it's all the way up at night.)
  10. LoraJ
    LoraJ Active Member
    507
    68
    2018 Prius Prime
    On XM with the NAV, I wish you could always see what the song and artist playing are no matter what screen you are on: map, presets, etc.
  11. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Thanks Denise
  12. scooper11
    scooper11 Junior Member
    Rhode Island
    The key fob should include a button to open the hatchback!!
  13. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    If you're talking about unlocking the hatch, you have that already. If you're wanting a power hatch opener, forget that... the motor and mechanism to do that is too weighty and we're already pushing EPA weight ratios...
  14. millerjl26
    millerjl26 New Member
    33
    Connecticut
    The glasses holder on the 2010 is significantly smaller than the earlier models so does not fit wraparound sunglasses. The 2nd complaint I have about the sunglass holder is the notch for the glasses bridge is far too wide for normal glasses so it rests on top of it rather than nestled around it. The third and last issue is the rattling around of my glasses when I take a sharp corner because of the 2nd issue and the lack of soft material surrounding the glasses. I just attempted to solve the rattling issue by using double stick tape and some thin sheets of a rubber material to cover as much of the inner surfaces of the holder. May not solve the sound issue completely but it can't hurt.
  15. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Aesthetically, I'd change the steering wheel. It's pretty ugly.
  16. MidWestGirl
    MidWestGirl New Member
    50
    Kansas City
    The only thing about the steering wheel that I don't care for is how it feels. It's awfully rough against my hands (I'm used to a smoother-textured steering wheel). But I know you can easily fix that with getting steering wheel covers.
  17. Vapor
    Vapor Junior Member
    Chicagoland
    I'm thrilled to be at 100 miles with my first hybrid. Still got that Christmas morning feeling. That said, the center storage consule bugs me with sliding the lid back so far. Also, I realize there's covers and plugs, but I worry that the 12v socket and the Aux input jack will get crud in them since they're on the bottom rather than a side...I'm not an immaculate car person.
  18. bwilson4web
    16,531
    "Check engine" light when the last of the gasoline is gone.
  19. rctech
    rctech Junior Member
    46
    Chicago
    It would be nice to have an additional fuel consumption measure. Instead of by 1 and 5 minute intervals. Also have fuel consumption based by the last 1 and 5 mile intervals.
    In the end, I would rather know how much gas it took me to go those past n miles, rather than based on how much stop and go (traffic, lights, etc) I had.
    Sorta like the instantaneous mpg, but based on distance instead point or minute of time.
    rich
  20. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    I'd change the navigation system to a Garmin-like system with intuitive functions and reasonably priced updates.
