What is the solution when you start burning too much oil?
Discussion in 'Gen 3 Prius Technical Discussion' started by Higgins909, Nov 12, 2023.
  1. 80eagles
    80eagles Junior Member
    Port Charlotte, FL
    I have always been using pennzoil platinum synthetic 5w 30 in all my 3 Priuses
  2. 80eagles
    Port Charlotte, FL
  3. 80eagles
    Port Charlotte, FL
    I have always been using pennzoil platinum 5w 30 in all my 3 Priuses
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,068
    6,936
    Texas Hill Country
    1.2 quarts in 370 miles would have gotten you a free set of revised pistons and rings in the first five years or 60k miles. Toyota knew the issue early but some seem to forget that fact. You got a lot of miles out of it since you are just now throwing additives in it starting at 198,000.
    Your high mile engine is a poor candidate for a rebuild. The cylinder walls can't be repaired and continuing to dump oil in it just means your $1800 catalytic converter will clog as well. In the meantime the engine will recirculate even more hydrocarbons, further carboning up everything.
    A professionally rebuilt engine is far better than a questionable jdm engine, some of which have proved to be domestic junkyard engines with high miles.
    Get a rebuilt engine and cruise for another 200k without engine issue. Or punt rather than going for 4th and long if your brake booster or hv battery has not been replaced.
    #22 rjparker, Nov 23, 2023
  5. Priipriii
    Priipriii Member
    231
    67
    At this point id just do a junkyard engine swap
