What is the total hybrid system torque rating?
Discussion in 'Gen 3 Prius Main Forum' started by toronado455, Jan 15, 2015.
  1. toronado455
    toronado455 Member
    179
    22
    Southern California
    All I can find is separate specs for the elecric and gas motors.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  3. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Can't you just add them together for total? Gas motor: 105 lb-ft + electric motor 153 lb-ft.
  4. fuzzy1
    10,335
    Because they are at different gear ratios from the wheels, that sum is a completely meaningless number.
    Oscaracciato and CR94 like this.
  5. toronado455
    toronado455 Member
    179
    22
    Southern California
    400 lb-ft at 0 to 500 RPM? That can't possibly be correct.
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I think it is 400 ft-lb from a stop at the wheels; 153 ft-lb at the motor times a reduction gear of 2.636 gives 403 ft-lb. Like most electric motors, the peak torque is at a standstill. The engine hits peak torque close to its software-enforced "redline".
    I'm still not certain what's going on in that chart, though, because obviously the engine can't run at all below about 900-ish RPMs, and the MGs can go over 5,000. I think the Prius's transmission makes it rather hard to say what the torque is at a given RPM without applying some other constraint(s) as well; there are too many variables to be able to solve for torque off of just a single fixed variable (RPM).
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Rated "redline" of the ICE is at or close to 5000 RPM. The car will try to not exceed that, and that "shutdown" also applies to the electric motors.
    400 ft-lbs sounds high but is the oft quoted value. Why do you think they need "traction control"?
    Not all electric motors have peak output at 0 RPM. Most DC ones do, and the three phase electric motor in the Prius acts like a DC motor with a commutator. A two phase electric motor has low torque at 0 RPM, and uses a capacitor to derive the "second phase" when starting. For example, many table saws use this type of motor. It can be held at 0 RPM without too much trouble (don't do it though), but can be hard to stall once at operating RPM.
    The Prius motors loose torque due to "back EMF", which opposes the input power. It increases with RPM.
  8. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Are you sure you can use the 400 lb.ft of the MG2 like that? Since there is a reduction in the PSD between the MG2 and the ICE, the 400 lb.ft of the MG2 does not appear like that at the wheels.
    European Prii get quotes as having 207 Nm (152,6 lb.ft) of torque from the electric motor. Also 100 bhp at 2000 rpm seems a lot, seeing how the car accelerates.
  9. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Mg2 is coupled directly to the wheels through the reduction gears, and it's torque output of 153 ft-lbs at zero speed is multiplied by the reduction gears to 400 ft-lbs. This has nothing to do with the ICE.
  10. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Nobody seems certain what's going on with that chart, because the variables are not well defined.
    Torque from a a stop at the wheels must be more than 400 ft-lb for the car to be able to climb a steep hill. Maybe that number is maximum torque at the input to the final reduction gear?
  11. FuelMiser
    1,342
    922
    Monument, CO
    Anybody ever take their Prius to a dyno? This would measure HP and Torque at the wheels, right?
  12. fuzzy1
    10,335
