What is the usable power in KWh ?
Discussion in 'Gen 3 Prius Technical Discussion' started by szgabor, May 9, 2012.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    You have to account for Peukert's for battery charging/discharging, and other inefficiencies in regen, like MG winding resistance, IGBT switching losses in the inverter, etc. Maybe 75% of the regen braking can be captured and re-delivered to the wheels later -- and that is a very optimistic estimate. The main point is that conversion of potential and kinetic energy is not very efficient, and adding weight will be a net loss. Otherwise, the process violates the First Law of Thermodynamics.
    To the original poster, please tell your wife that she is getting lower MPG than is possible by trying to keep the battery fully charged, and in fact will cause it to wear out faster that way. These batteries do not like to be fully charged -- this is one reason why the car will start to burn off charge at full SoC.
  2. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I kind of disagree first I think 75% is probably not the most optimistic but at the minimum efficiency. This includes 2 times inverter losses plus some on the generator and motor mode .... those are VERY efficient with the modern magnets and very efficient control of the inverter .. I would actually say the battery loss is more than anything else ... but not more than 25% in most of the time.
    And if the new added battery is the lighter variety like the PiP uses the weight definitely not an issue ... Just think about it adding 100-200 lb to the car which curbside weight 3000+ lb !!! Come on!!! Your argument makes no sense ... actually what the hybrid regen system (let just call KERS Kynetic Energy Recovery System) can do is really adding to the mpg more then the EV part ... and if your "bucket" to recover into is bigger in certain driving condition makes a HUGE difference.
    Sure I agree with you on the facts.
    I am not sure if you are married, but I would NOT dare to tell my wife this .... arguing about driving especially when your spouse drives is a very undesirable proposition :) :D YMMV:D
  3. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    The numbers that Plug-In Prius drivers report when they take long trips is proof that more battery DOES NOT result in higher MPG. Everything that goes into the battery, if not from a plug, comes from the ICE. For a non-plug-in, you only need the battery to start the ICE, provide assistance for acceleration, and have enough capacity to capture the regen when braking from 80mph to 0. The battery is about 2.5 times larger than that to allow for a long lifetime. Any additional capacity is unnecessary excess weight. That's one reason that the C has a 144V system, instead of a 202V system.
    It is simple physics. I have a Physics Ph.D. but I've given up on expecting to convince you.
  4. szgabor
    994
    175
    Oceanside NY
    Please listen ... I am not talking about long uninterrupted highway speed like 60-65MPH !! There there is absolutely NO advantage to have a hybrid (KERS) capability ... except the aerodynamically well designed car ...
    I do not drive my Prius that way .. and most people doesn't either ...
    I do understand physics as much needed as the Prius concerned (no PhD) I only have an MS in EE ...
    So you are pushing a scenario to prove that bigger bucket makes no sense .... but that is NOT what I asked in the first place ....
    Since you know physics you know math too right ? ...
    You said that if SOC is about 80% prius start "burn" that charge ... but if by an addition that can be extended ... would you agree that energy will be advantageous later ??? By any rate of efficiency you would agree. The weight argument just not hold water. We are not substantially increasing the car overall weight ....
    Otherwise you have to admit if two people in the car you would DROP MPG substantially. Which, I can tell you, NOT the case the way I use the car. I commute sometimes alone for some weeks/months but some other times with my wife she is over 100lb but less then 200 lb. There is no statistically significant difference ... average temperature is more, a lot more, of a factor than 1 or 2 person was riding .. I have almost 3 years of data ....
    But OK we do not have to agree at all. I actually got the information I was trying to get and I can make a better informed decision at this point...
    BUT I will get a PiP or something with a larger battery, which as a substantially higher bucket next time .... BUT of course this takes in account how I USE THE CAR ...
  5. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Since you are an engineer, calculate the optimal pack size given the (1) weight of cells, (2) Peukert's constant for those cells, (3) minimum and maximum acceptable charge levels for those cells (4) estimated efficiencies of MG1, MG2, ICE, inverter, (4) any other factors you think are relevant. Feel free to use either lithium or NiMH.
    Here's a hint: if more is better, then your solution will converge to infinity.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Another way to look at the effect of battery capacity relating to efficiency is to look at Argon Labs testing of the conventional Prius. Argon found that mileage remained effectively the same even at half battery capacity. Put another way, the conventional Prius has twice the needed battery capacity. Presumably this was done to allow for good performance even as the battery degraded.
    Extrapolating from that, one wouldn't expect better mileage from the PiP, other than the charge introduced from the wall. In fact one would expect some drop in mileage due to the extra weight. It's not a lot of extra weight, but even one extra passenger makes a measurable difference.
    Tom
  7. markabele
    5,084
    1,782
    Nebraska
    I had never even thought about that, but it's nice they made it as big as they did so we can enjoy great FE for years to come.
  8. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    The only time a much larger pack is useful is if you're either charging it from the wall, or if you regularly go up and down mountains. Even on mountains, it may not be useful; I've gotten pretty good on some of my regular (small) mountain drives at draining the battery just before the peak, and then just barely hitting 80% SoC (full) by the time I'm at the bottom. In city driving, it's nearly impossible to reach 80% SoC, unless you're driving absolutely terribly (in terms of efficiency) - like by accelerating towards red lights at each block. In that case, it's more efficient (and cheaper) to modify your driving habits than to add a larger battery. Until you reach 80% SoC, you don't need the extra capacity.
  9. szgabor
    994
    175
    Oceanside NY
    Again you missed the two biggest points (on purpose???)
    1. It is not the weight of the battery (plus the rest of gear needed) but the ratio to the original pack...
    2. The way the car is driven is very big factor in this. NOT just by the driver techniques, but the terrain and roads (highway, city, suburb and time). This is why some people never even see the advertised MPG.
    Opinion from here:
    Just think about this. Prius C is a LOT LOT smaller car. They put a smaller system in it and more or less achieved the SAME MPG rating .... and just take a look at those who put conversion kits different sizes NONE reported what you suggests "the weight penalty" ... why? Because all of the above is more or less eliminated ... same person drives more or less the same way at the same general routes !!! But yes just by principle there IS an optimal ratio for any given system (you listed them). I just think that Toyota for mostly cost put less than optimal size of battery for MY DRIVING .... but they wanted to sell 1million+ car not just the one I am driving daily in this particular environment.
  10. szgabor
    994
    175
    Oceanside NY
    If you have a link please post just so I can read the same. Because this would be the contrary to anyone who put extra packs in .... especially with Gen II where the max EV speed is very low....
    One extra passenger (averge size of course) doesn't make a significant (measurable maybe) difference on my driving. What I am finding is that dropping ambient temperature by 10 degrees like Sept vs. Oct is more than one passenger. Four people with some luggage is DEFINITELY significant and measurable (800-900lb is close to 1/3 of the curb weight !!)
  11. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    The bottom line is, energy stored by the pack comes from the ICE. Yes, there may be peculiar circumstances that occasionally result in 80% SOC (the car tries very hard to put it to the wheels above 70%), but the vast majority of miles are spent in the steady state of 60% +/- on the highway, so larger battery will not help, unless you plug it in. This idea has been beaten to death so many times already over the years.
    If you think your pack is too small, go ahead and experiment. Scientific and engineering advances only happen when someone challenges best practices.
    Your Fuelly shows 51 MPG. Research driving techniques here to improve that. It takes courage to tell your wife that she is doing something wrong, but you will get better MPG if she doesn't try to keep the pack full. That implies a lot of hard braking, which is energy wasted. The pack will accept charge current to a certain level (about 25 kW) then the pads and rotors have to do the rest.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I cannot follow the reasoning because of the poor english. Rewrite please.
    Talking of fuel economy,
    The cost of a larger battery is its weight;
    The benefit is additional regen capacity people who drive in hilly terrain might take advantage of, and (?) less conversion losses.
    Net net, I suspect a little benefit for some, a little penalty for others, and not much difference for most. As others have pointed out, the PiP is good empiric proof against the idea in general. Wayne Brown put a lot of work into this idea 5 years ago by adding capacity to his G2 Prius, and IIRC reported some benefit. Perhaps he could be contacted and asked for details.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    kwh is not a unit of power, it is a unit of energy.
  14. szgabor
    994
    175
    Oceanside NY
    Now I can see why we have such a big different in opinions ... I DO NOT spend 60% of my driving anything near steady state of speed or even moving state ... I DO DRIVE IN THE CITY 70% of the time .... and I can not modulate most of my acceleration either ...
    Actually this is NOT the case at all. It just takes pushing the gas pedal harder than needed ... believe it or not ..... there are people here how "power" charge the prius by pushing the gas and break pedal at the same time....
    You can "fill" up the battery by nothing else but pushing the gas .... no breaking necessary ... sorry to break this to you....
  15. szgabor
    994
    175
    Oceanside NY
    Yes, if you do not do PiP. But the current car "saves" by reclaiming the otherwise wasted energy .... and what I am arguing is a LOT MORE for certain driving condition COULD be reclaimed. And you are saying it is NOT...
    The weight argument is bogus even at 75% efficiency.
    The ICE clrearly puts out more power than (in crtain times) needed so the output can be saved for later day WHEN ICE IS NOT EVEN ON ...
    But OK we just disagree....
  16. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    You are incorrect on many of your points:
    1) There is not a LOT more energy that could be reclaimed - there is some. As you stated you only reach the 8 bars occasionally. You would only improve overall energy consumption when you are at 8 bars and you have to waste energy that would otherwise be wasted.
    2) The weight of any additional battery does cause extra energy to be consumed just to carry the battery around:
    For example if the battery weighs 100 lb (same as existing Prius battery) and the rolling resistance coefficient is 1% (some LRR tires may be a bit better than this). Then it requires an additional 1 lb of traction thrust to move the battery @ 60MPH. This requires 88 ft-lb/sec of power. This is equivalent to 0.16 BHP (550ft-lb/sec is 1HP), ~120 Watts
    The optimum efficiency of the engine is ~230g/KWh.
    The extra weight of the battery would therefore require the consumption of 27.6g/hr of fuel.
    If we assume that in steady state conditions on level ground the Prius has a fuel consumption of 60MPG @ 60mph then it consumes 2760g/hr of fuel. This will increase by ~1% with the added weight of the battery. (i.e. a reduction from 60MPG to 59.4MPG).
    The battery would have to improve fuel consumption by more than 1% for there to be any overall increase in MPG.
    3) The engine very rarely produces excess power - if it did the ECU would reduce the throttle setting (and fuel consumption) to lower the output until it matched the demand.
    Why would the engine be set to produce more power than needed?
    There are a couple of situations where it may be done too advantage:
    If the power output would be so low as to be less efficient than running on electric power and the battery has a suitable state of charge (SOC) then the engine is stopped and the car runs on electric power. If the battery does not have a high enough SOC then yes the engine is run to provide power to propel the car as well as restore SOC in the battery.
    4) The best efficiency from mechanical - electrical - chemical - electrical -mechanical is probably in the 60% region. The motor/generators each have a best case efficiency of about 90% so there is only ~80% efficiency mechanical - electrical and back. The battery itself has an efficiency of 70-80%. 90% * 90% * 80% = 64.8%
    5) The hybrid system does give an improvement in fuel consumption even o freeway driving. The engine size required in a car has to allow for reasonable drivability. Without the the hybrid system the engine has to be size to be larger than necessary to accommodate the extra power required for hills, passing, accelerating etc. With the Prius those transient loads can be provided by the battery so the engine can be sized for the average load - it is no coincidence that the Prius has the best freeway fuel consumption of any car sold in America.
    Toyota will have modeled the Prius under multiple scenarios to obtain the optimum battery size and it will be a rare situation where a larger battery will have an advantage (unless you charge it from the wall as in the PIP).
    kevin
  17. szgabor
    994
    175
    Oceanside NY
    Again this is absoultely amazing analysis ... except I DO NOT drive the car this way and most people doesn't either ...
    By the way if all these were true the hybride KERS wouldn't make sense at all. The Prius is (usually ) not driven at 60MPH for infinity times ..Then you would only have the nicely designed aerodynamically sound car which the Prius is since Gen 2 .. :)
    What you need to account for is that real life driving. It is like I WANT TO RECLAIM most of my breaking and slowing down energy ... because I can not really really accelerate at my "way" ... so I MUST "over" use the ICE when I do not really want.. that energy (including the added weight passanger or battery) can and possibly reclaimed .... (60/65/70/75/80%) but a lot more than nothing ...
    THAT what a bigger battery will help to do for ME..
    So as I said (and you as well) before Toyota built Prius not optimally to my way of use ... but that is it ... not the I am wrong ..
  18. macman408
    1,179
    368
    Perhaps you need to tell us what's so different about your way of driving, then. I have never even come close to filling the battery in city driving, and highway driving will always leave me almost exactly at 60% SoC. Only going down long hills is enough to fill the battery.
    Another question; does your car ever start using engine braking on its own? Even when the battery reaches 8 bars, the battery isn't full yet. Without a gauge of some sort, the easiest way to tell is that the engine will typically remain on until you are stopped (whether accelerating, coasting, or braking), and will spin up to high RPMs while you are braking.
    If you're not regularly hitting this condition, you're not regularly filling your battery, and so there's no need for more capacity.
    Also, keep in mind that when the Prius shows 6 bars out of 8 filled, you might think that the battery is 75% full; however, the battery is roughly 43% full at that point ([60-45% SoC] / [80-45% SoC]). Like most gas gauges, the bars are not all sized equally, and they will show full or nearly-full when they are not even close.
