what is the voltage of your 12v battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by arewethereyet, Mar 17, 2012.
  1. R-P
    R-P Active Member
    804
    288
    Netherlands
    Brandless 55Ah (not 45Ah).
    Charging now. Will follow up, although today is the only day this year it is actually freezing :) so that may skew the results.
  2. tampaite
    tampaite Member
    237
    42
    FL
    2007 Prius Touring model : 11.9v(engine OFF) and 14.3v(engine ON)
    2007 Prius Regular model : 11.8v(engine OFF) and 14.3v(engine ON)
    No issues with starting the engines with the 12v battery at 11.8 or 11.9v
  3. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    12.1 is kinda low for a new battery. May need to fully charge it? I think your car in ready mode should be higher?
    My 3 1/2 year old battery measures:
    1 push: 12.5
    2 push: 12.3
    Full load (full blast heater, rear defroster, headlights on): 11.1
    Ready mode: 14.7
    iPhone ?
    51,968
    mine almost 4 year old is 12.4 dead cold measured at the jump post.
  5. luckyboy
    luckyboy Member
    204
    29
    My 2007 (base with original small OEM battery) was measuring mid 11v in the morning and dropping to 9v and killing the car when starting with headlights and defroster on. Needless to say I am in the process of changing the battery. Ordered a new AGM from Rural King that just arrived showing 12.7v, I put it on the trickle charger and will drop it in the prius tomorrow (well will probably require some modification to accommodate the larger battery since mine came with the smaller, non-smart key battery).
    #25 luckyboy, Feb 11, 2016
  6. bisco
    51,968
    rural king?
  7. luckyboy
    luckyboy Member
    204
    29
    #27 luckyboy, Feb 11, 2016
  8. bisco
    51,968
    wow, that's the best i've heard, by far.
    luckyboy likes this.
