What is this button???
Discussion in 'Gen 3 Prius Main Forum' started by RastinoSLOVAKIA, Jul 24, 2022.
  1. RastinoSLOVAKIA
    RastinoSLOVAKIA Junior Member
    Slovakia
    Hello Do you know what this button can be used for? I buy my car in march and I find it in motor place. I'm afraid the push it ☺️
  2. Tideland Prius
    16,681
    We don't have that in our North American specification. It looks like an aftermarket addition with some extra fuses.
    RastinoSLOVAKIA likes this.
  3. nicoj36
    nicoj36 Active Member
    518
    162
    It looks like custom work. Do you have aftermarket parts installed like lights or radio
  4. RastinoSLOVAKIA
    Slovakia
    the cables lead to the cabin, and there are 2 buttons in it that I don't know what they are for. see photos...
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    The stuff in the engine compartment is interesting -- we are all saying aftermarket because it's not like anything we've seen. OTOH, you live in Slovakia, so who knows if it's OEM over there, although my guess would be aftermarket.
    Engine compartment guess: Someone has installed an electrical bus with two 15A circuits and two 5A circuits -- not insubstantial. The big read button is an on/off for the bus.
    Button on dash clearly aftermarket as it's not very well done and certainly doesn't look OEM.
    RU sure the item by the mirror is a button? Could it be an IR motion detector or camera as part of an alarm system? From the pix it almost looks translucent.
    Just my two cents.
  6. drbtz
    drbtz Member
    102
    51
    United States
    It's most definitely a toggle switch the "dot" being the on position... or would be if wired correctly. As said button by the fog light dial is definitely after market and really rough at that haha
    Buttons of this nature are generally for auxiliary lights. It is possible that the previous owner had light bars and etc and upon trading in the vehicle (or deciding to sell it) remove the accessories. Look for drilled holes, zip ties, brackets, things that would not normally be there.
  7. RastinoSLOVAKIA
    Slovakia
    I suspect that the car was previously used as a taxi, because the number 19 is written in marker on the key, and that would also explain the button near the mirror where the taxi sign was probably turned on
  8. RastinoSLOVAKIA
    Slovakia
    I also suspect that all the doors on the car open without any positions... Is it normal??? Also under the steering wheel I can't think of a button to start the alarm, which I could only stop by disconnecting the battery...
  9. bisco
    52,857
    what do you mean by 'without any positions'?
    there are no switches for the factory alarm. if it goes off by itself, check the fob for a bad button.
  10. hill
    9,038
    RazorDon, ukulelegeek, Mr. F and 3 others like this.
  11. RastinoSLOVAKIA
    Slovakia
    ze ked dvierka otvorim tak sa plynule otvoria uplne, ze nema 2 ani 3 zarazky
  12. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Maybe the car was a ex law enforcement, those were for flashing lights.
  13. RastinoSLOVAKIA
    Slovakia
    that when I open the door, 2-3 won't stop
  14. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    It's relatively neatly done, so probably was a taxi or cop car as others have said.
    Can you the Ministry of the Interior for a history check?
    >>>> How to find infor...
    That might give you some clues about its past life
  15. RastinoSLOVAKIA
    Slovakia
    car is from Germany
  16. bisco
    52,857
    won't stop what?
  17. drbtz
    drbtz Member
    102
    51
    United States
    I'm assuming OP means the door opens completely without standing still when open partially. This is because either A) your door check is worn or B) your door check is missing.
    bisco and RastinoSLOVAKIA like this.
  18. Todd Bonzalez
    250
    160
    Ireland
    It triggers the alarm? It's a panic button. Definitely a taxi
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    In case you’re working on your car and a thief tries to steal your number 10 socket!
  20. RastinoSLOVAKIA
    Slovakia
    Mystery solved! It's TAXI! By intax.de
    ukulelegeek, Tideland Prius and bisco like this.
