What is this connector?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, May 12, 2023.
  1. SB6
    SB6 Member
    324
    71
    EDIT: I think it might be something to do with the wheel speed sensor or something, because cruise control isn't working.
    Driving on highway and the front right wheelwell fender liner came off (bad install job by me). Traction control, ABS, and brake warning light came on, and regenerative braking isn't working.
    Found this connector hanging in the same front right wheelwell. Any ideas where it goes?
    #1 SB6, May 12, 2023
  2. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    It goes to the ABS sensor. The part it mates to is part #: 89542-47030
    89542-47030 - Google Search
    Code:
    https://www.google.com/search?&q=89542-47030&tbm=isch
    SB6 likes this.
  3. SB6
    SB6 Member
    324
    71
    Pretty certain that's the one. Will try to see more in the morning. Hopefully it didn't completely rip out, and I can simply reconnect it...
  4. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I just take the wheel off If it is ripped off use two Scotch lock two port connectors the red ones push the wires in unstripped push the red part down push the plug back to its connector and plug it to the strut or where it normally sits and leave it alone should be good to go fender liners getting loose will do this.
  5. SB6
    SB6 Member
    324
    71
    I found this cable with a black wire and a white wire zip ties to I think the brake line. I wonder if it was already ripped before, and someone had simply fed in the bare wire into the other side of the connector, then zip tied to the brake line?
