What is this hose?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by fatboyardee, Apr 21, 2026.
  1. fatboyardee
    fatboyardee New Member
    Tampa
    2013 Prius v wagon
    bottom line: I can't figure out what hose connects to this, and where the other end is. I think it's either the low side of the AC compressor, or a heater hose.
    Rest of the story: my 2013 V-5 started throwing P261B errors and overheating. I replaced the IC water pump and thermostat, and it starts and runs no problem (no leaks). I'm not letting it run very long, however (like 5 mins at a time), since I can't figure out what this one pipe connects to, and I don't want it to start dumping coolant, or worse, killing the AC compressor (AC is currently OFF).
    Yes, I'm an idiot. I took pictures of some of it during disassembly, but not this part (it was towards the end of pulling the water pump and tstat, and I was getting frustrated, and pulling whatever to be able to get to it). I've looked at various shop manuals (alldataDIY), but can't quite determine what it is using those.
    Any help more than welcome.
  2. Brian1954
    Brian1954 Senior Member
    2,513
    1,005
    South Central PA, USA
    The hose that goes onto that metal tubing is a vacuum hose. The vacuum hose connects to the VSV (purge) valve. You need to remove the air intake box to see the plastic valve, which is located under the engine air filter box
    #2 Brian1954, Apr 21, 2026
    rjparker likes this.
  3. notspam3
    notspam3 Member
    119
    65
    Toronto
    2024 Prius Prime
    XSE Premium
    Next time use an arrow instead of a circle containing two or more hoses in each photo
